Brake fluid check and rear brake feel
Simian
PostPosted: 20:55 - 24 Feb 2019    Post subject: Brake fluid check and rear brake feel Reply with quote
I'm finding it hard reading the brake fluid level on the front and rear reservoirs. To me it looks way below the minimum as I can't see the fluid, but if the fluid is a clear colour I just might not be seeing it
https://imgur.com/QGQhzo1
It also feels like the rear brake has a bit of play before it starts to bite. I can push the pedal maybe half an inch before feeling anything on the wheel. Is this something I'd adjust with the fluid? The pads look fine..
Riejufixing
PostPosted: 22:33 - 24 Feb 2019    Post subject: Reply with quote
Why not just get the lid off (after cleaning around it) and have a look in?
PostPosted: 22:49 - 24 Feb 2019    Post subject: Re: Brake fluid check and rear brake feel Reply with quote
Sometimes the breather hole gets blocked and no air is allowed into the reservoir. As the pads wear a bit it pulls a vacuum in the reservoir and you lose feel at the lever.
Take the lid off the reservoir and see if the feel improves. Check the level whilst you're at it.
The last post was made 7 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 36.3 Kb
