| hjdowning |
 hjdowning L Plate Warrior
 Posted: 22:29 - 24 Feb 2019 Post subject: Yamaha RXS100 - Crankshaft Oil seal |
I have been trying to tidy up an old RXS100 that I've had sitting in a shed for years.
I noticed the gear oil level keeps dropping, but there is no puddle of oil under the bike. Would it be fair to assume the oil is leaking into the crankcase? The bike is very smokey which would support this theory?
I have removed the crankcase cover to gain access to the oil seal.
My questions are:
1. Do you think replacing this seal will resolve the issue
2. Can I remove the seal with a pick or do I have to split the crankcase?
3. Could the oil be getting into the crankcase from elsewhere?
https://i.imgur.com/Ys14AFa.jpg
https://i.imgur.com/v6xt4zK.jpg |
| Pete. |
 Pete. Super Spammer
 Posted: 22:45 - 24 Feb 2019 Post subject: |
It's certainly possible though if the seal is shot then likely the bearing is too. Does it idle an run well? If it's sucking oil then I'd expect a poor idle.
Another option is the vertical joint in the cases. This has to be perfect to keep the crank case sealed. Sometimes there will be burrs raised on the casing where some monkey has levered them apart with a screwdriver etc.
Seeing as it's a fixer-upper anyway I would order two new main bearings and two new seals and a tin of gaskacinch or yamabond etc, split the case, check the faced for raised spots and remedy as required then rebuild it. ____________________ a.k.a 'Geri'
| hjdowning |
| bikenut |
 bikenut World Chat Champion
| bikenut |
| hjdowning |
| bikenut |
| bikenut |
The last post was made 7 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
