Brake pipe blocked solid.
St George
PostPosted: 17:41 - 28 Feb 2019    Post subject: Brake pipe blocked solid. Reply with quote
I fitted a complete new master cylinder to my Honda 250 as it was leaking. Then tackled the seized piston by replacing it with a stainless steel one with new seals. Went to bleed the system and found the brake line is blocked solid. I have ordered a new braided one from Ebay which was not too painful. Just thought I would share this with everyone as I have never come across this before. Regards to all.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:45 - 28 Feb 2019    Post subject: Re: Brake pipe blocked solid. Reply with quote
I have. It appears that it's possible for the internal rubber of the pipe to fail in such a way as to become a one way vakve.
It happened to my brothers bike on the day I moved out of Bath and he had to get it trailered to London the next day.
Triumph Sprint ST 1050
St George
PostPosted: 17:53 - 28 Feb 2019    Post subject: Reply with quote
Soaked it in very hot water, could not even blow through it.
Islander
PostPosted: 20:10 - 28 Feb 2019    Post subject: Reply with quote
It happened on my R850R. The liner of the rubber brake lines collapsed and blocked the lines completely apparently it's not that uncommon either.
St George
PostPosted: 16:17 - 05 Mar 2019    Post subject: Reply with quote
Fitted the new braided pipe, bled the system. Bingo it stops. It is possible that the new master cylinder I bought was not required. Better safe than sorry. The piston and seals, master cylinder with lever and braided hose and pads came to a total just under £80. Not bad for a Jap bike and easy to work on.
steve the grease
PostPosted: 18:44 - 05 Mar 2019    Post subject: Reply with quote
Thats the spirit , and you learned something as well and that is priceless..........
The last post was made 6 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 47.63 Kb
