Help Needed!!!
Neil030912
PostPosted: 17:46 - 01 Mar 2019    Post subject: Help Needed!!! Reply with quote
Hey all im new here,
firstly Hi all,
now down to business, i have a 2002 Honda Nes 125cc which is a nonrunner, bought it as a nonrunner, been stood for a few months apparently,
Drained the 1mm of oil that it actually had in it and topped up fully, gave it coolant which also was none existant, took the spark plug out an binned it, gave it a new lease of life, charged the battery fully but still getting no spark?
what else can i do?
TIA
Neil
jaffa90
PostPosted: 18:23 - 01 Mar 2019    Post subject: Reply with quote
Where did all the oil / coolant go?
What safety cut out switches does this scooter have to kill the spark?
Why did you bin the spark plug?
Neil030912
PostPosted: 18:26 - 01 Mar 2019    Post subject: Reply with quote
Binned the Spark Plug as i bought new 1, Oil was basically none existant like the cooler,
Bought it as a none runner but was expecting it to have a bit of them both, but nope none
Neil030912
PostPosted: 18:27 - 01 Mar 2019    Post subject: Reply with quote
Think the only cut out is the side stand but i have been using the centre stand while been working on it
Grubscrew
PostPosted: 18:28 - 01 Mar 2019    Post subject: Reply with quote
Welcome.
Ignition switch faulty maybe. Have you checked the battery voltage even after it’s been charged as it still maybe knackered.
Is there an on off switch on the cluster. If so clean the contacts.
Is the coil accessible, have a look at the wires too and from the terminals.
In view it had virtually no oil or coolant in the bike it would ring alarm bells as to what lies beneath the plastics and tank.
FJR1300/CBR1000F
Neil030912
PostPosted: 18:31 - 01 Mar 2019    Post subject: Reply with quote
ignition switch turns over the bike but dont get no spark.
Coil looks ok but ive ordered a new 1 just incase also debating buying new CDI unit for it just to be safe
cb1rocket
PostPosted: 08:28 - 02 Mar 2019    Post subject: Reply with quote
if it had hardly any oil then the engine is scrap. I hope you paid peanuts for the bike .
doggone
PostPosted: 10:17 - 02 Mar 2019    Post subject: Reply with quote
It's a good sign it tuns over, perhaps it was laid on its side while unused. If the oil blew out while running something bad has probably happened,
bikenut
PostPosted: 10:36 - 02 Mar 2019    Post subject: bike Reply with quote
Do you have a manual and know of cmsnl for the exploded views, they will show stuff like ign system parts and cut out switches etc., very useful info. and free.
The oil that came out of the engine, did it contain "bits" and/or metal flakes etc.. Inspect the old engine oil. Did the coolant cap have any oil there?? and does the engine have compression??
Any mayo seen in the engine??
Get a wiring diagram and use your multi meter.
There may be a manual and wiring diagram on here but also look on cmsnl for clues.
nuts about bikes
cb1rocket
PostPosted: 12:00 - 02 Mar 2019    Post subject: Reply with quote
cdi is rarely at fault on these
Neil030912
PostPosted: 14:24 - 02 Mar 2019    Post subject: Help Needed!!! Reply with quote
So if its rarely the Cdi does that mean the Coil could be faulty??
Grubscrew
PostPosted: 17:32 - 02 Mar 2019    Post subject: Reply with quote
Coils and cdis rarely go down, many bikes made in the 80s/90s still operate on their originals.
Get back to basics with observation on wiring loom, earthlings, connector blocks.
As to my question earlier: is there an on off switch on the handle bars, as some bikes have been known to spin over but won’t fire with the switch in the off position.
Side stand also. Perhaps by pass these items.
What’s the plug cap like? The HT lead(s).
FJR1300/CBR1000F
Neil030912
PostPosted: 17:34 - 02 Mar 2019    Post subject: Reply with quote
Ordered new coil with plug cap waiting for it to come, No switch on handle, side stand i disconnected but then there was no power at all, wouldnt even turn over.
Grubscrew
PostPosted: 17:41 - 02 Mar 2019    Post subject: Reply with quote
Does the neutral light come on?
Have you a multimeter , only a few quid.
This ma help
https://www.geneva-racing.ch/~alains/NSRtips.doc
FJR1300/CBR1000F
Neil030912
PostPosted: 17:44 - 02 Mar 2019    Post subject: Reply with quote
Yes all lights, indicators, horn etc work but just no spark. Picking a Multimeter up on monday
WD Forte
PostPosted: 21:08 - 02 Mar 2019    Post subject: Reply with quote
I wouldn't spend on anything other than a meter at this stage
as the 1mm of oil and zero coolant could mean the engine has been run dry with no coolant and FUBAR.
A few tests with a meter will help you find out why its not sparking
bikers smell of wee
Neil030912
PostPosted: 21:10 - 02 Mar 2019    Post subject: Reply with quote
ok thanks for the info
Robby
Dirty Old Man
PostPosted: 17:19 - 03 Mar 2019    Post subject: Reply with quote
It could also be empty because someone else drained it getting ready for a rebuild, then decided to not bother.
Quite possible that someone else has also tried to fix it, and decided the problem was not worth fixing.
Still, nothing wrong with having a go. Multimeter and wiring diagram, chase through the ignition system until you find a problem.
Neil030912
PostPosted: 17:20 - 03 Mar 2019    Post subject: Reply with quote
Thanks Robby, been a bit wet today to do anything on it so back to it tomorrow hopefully.
bikenut
PostPosted: 10:03 - 04 Mar 2019    Post subject: bike Reply with quote
So no bits in the oil and you are getting a multi meter, even a cheapo one will help.
Without a wiring diagram you are like trying to find your way to Talybont, unless you make your own that is, diagram not Talybont.
Which Talybont by the way??
nuts about bikes
bikenut
PostPosted: 10:05 - 04 Mar 2019    Post subject: bike Reply with quote
You googgled cmsnl yet??
nuts about bikes
Neil030912
PostPosted: 11:19 - 04 Mar 2019    Post subject: Reply with quote
Yes thanks a honda parts website??
Neil030912
PostPosted: 13:48 - 04 Mar 2019    Post subject: Reply with quote
Yes its a Honda Nes 125cc Scooter not a bike
The last post was made 6 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 116.47 Kb
