Directional arrow on tyre
King29
PostPosted: 18:22 - 28 Feb 2019    Post subject: Directional arrow on tyre Reply with quote
A work friend took his bike for an mot. Mot bloke rang him at work as requested to report outcome and said he's failed it because directional arrow on tyre is going the wrong way?
Mot bloke wants £25 to take tyre off and put in on right way? does that sound legit or is mot place taking the mick? I wouldn't have thought it mattered and was there as a guide rather than YOU MUST DO THIS?
Can anyone clarify?
PostPosted: 18:52 - 28 Feb 2019    Post subject: Reply with quote
It's dangerous to ride on a tyre with the directional arrow the wrong way. This is because the tread on the tyre is directional, and moves water outwards to the edges of the tyre with the forward motion of the tyre. If the tyre is on backwards, the water is forced to the centre of the tyre, basically forcing an aquaplane.
£20 is the usual ride-in ride-out tyre fitting price, so it's not excessive. Why bitch about it? The tester has him bang to rights.
I'm actually surprised you'd even go to the effort of asking about it, because surely the tyre direction arrow is there for a reason, and that's fairly self evident? *shrugs*
TL:DR, he needs to get it swapped, and the MOT tester is right.
King29
PostPosted: 18:55 - 28 Feb 2019    Post subject: Reply with quote
Fair enough, thanks for your help. I asked because I was not sure if it was an mot failure but your explanation make sense. Cheers.
PostPosted: 19:04 - 28 Feb 2019    Post subject: Reply with quote
I think the words on the tyre usually say something like "direction of rotation mount this way only " or something...
colink98
PostPosted: 19:24 - 28 Feb 2019    Post subject: Reply with quote
this was the result of my last MOT
Date tested 13 June 2018
Pass
Mileage 75,077 miles
MOT test number 3580 3094 9302
Test location
View test location
Expiry date 13 June 2019
Monitor and repair if necessary (advisories):
Rear TYRE FITTED INCORRECTLY, DIRECTION ARROW WRONG WAY ROUND Dangerous
So it wasn't a failure as of June 2018 but may have changed since then.
Ride it like you stole it.
Kawasaki Jimbo
PostPosted: 19:29 - 28 Feb 2019    Post subject: Reply with quote
TYRE FITTED INCORRECTLY, DIRECTION ARROW WRONG WAY ROUND Dangerous.
I'd say that's some pretty relaxed MOT'ing.
kgm
PostPosted: 19:52 - 28 Feb 2019    Post subject: Reply with quote
Agreed. I wouldn't ride a bike with a mis-mounted tyre, just asking for trouble if there're any wet surfaces around.
Pjay
PostPosted: 19:56 - 28 Feb 2019    Post subject: Reply with quote
If it's the front tyre and it has dual discs, maybe he's put the wheel on backwards?
struan80 - I'll go first - satisfied tick 1
doggone
PostPosted: 20:50 - 28 Feb 2019    Post subject: Reply with quote
There seems some ambiguity about whether it's a guaranteed fail as tyre patterns aren't always so directional, at least on other vehicles.
PostPosted: 21:23 - 28 Feb 2019    Post subject: Reply with quote
When you tag an advisory with 'Dangerous' you'd think that it would be a fail?
Monkeywrenche...
PostPosted: 11:44 - 02 Mar 2019    Post subject: Reply with quote
It should have, The rules on this one haven't changed for a while, the failure is actually for "A tyre not fitted in compliance with the manufacturer's sidewall instructions" this includes directional instructions and (on cars obvs) "outside" tirewall instructions.
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
PostPosted: 12:00 - 02 Mar 2019    Post subject: Reply with quote
Is it not something to do with the drive as well. As in it's one way for a back tyre and the opposite if put on the front, or have I imagined this?
Triumph Trophy Launch Edition
Monkeywrenche...
PostPosted: 12:32 - 02 Mar 2019    Post subject: Reply with quote
If the tyres marked as "rear" then it falls within sidewall instructions and can't be used as a front. Bike tyres sometimes disperse water differently if they are front or rear specific .
PostPosted: 13:34 - 02 Mar 2019    Post subject: Reply with quote
I was right, Avon roadrunners Embarassed Showing my age now, Laughing
https://www.feked.com/images/detailed/38/IMG_8156-1000.jpg
PostPosted: 21:56 - 02 Mar 2019    Post subject: Reply with quote
Not entirely convinced by that - nor that the tread does THAT much on a lot of bike tyres in that manner. (Where's there's a much smaller contact patch compared to car tyres.)
Now - Avons, I'll agree they are dangerous to ride on!
Regardless; understandable it's an MOT failure.
I have heard of people just cutting off such markings. However a bit late now for that.
£25 seems really excessive to spin a tyre, but normal garages often seem to charge well over the odds for doing stuff with tyres.
PostPosted: 11:14 - 03 Mar 2019    Post subject: Reply with quote
Rear tyres transmit forces in both directions, depending on whether the tyre is trying to speed up or slow down the vehicle.
weasley
PostPosted: 14:36 - 03 Mar 2019    Post subject: Reply with quote
The tread on the front tyre is opposite to the rear too, because when leant over the front tyre clears water to the outside of the turn, so it is not pushing in inwards to where the rear tyre is about to arrive.
doggone
PostPosted: 15:01 - 03 Mar 2019    Post subject: Reply with quote
Don't think that's why.
The rear tyre is driven and doesn't want to lose grip during acceleration, Front wheel is not driven and mainly doesn't want to lose grip during braking.
iooi
PostPosted: 16:02 - 03 Mar 2019    Post subject: Reply with quote
Given you have less contact patch. Then tread design to clear water is even more important than on a cars, with the larger contact area and a extra 2 tyres....
All that is keeping you shinny side up is a couple of patches of rubber. Put anything between tyre and tarmac and the design of the tread is the most important thing as it is designed to clear that fluid, to sllow the rubber contact patch to do its job.
weasley
PostPosted: 19:19 - 03 Mar 2019    Post subject: Reply with quote
Tread is about clearing water though, not for grip. For ultimate grip you have no tread on both tyres and have an optimum compound.
Kawasaki Jimbo
PostPosted: 19:37 - 03 Mar 2019    Post subject: Reply with quote
Tyres aside, I think the front wheels on both my bikes would fit either way but the ZX6R has an obvious directional arrow on one of the three spokes, and it is mentioned in the service manual. The R1 service manual makes no mention but I have found a subtle arrow on one spoke (3-spokes again) and the tyre fitter has matched it. I recall the ZX6R has a circlip on one side whereas the R1 bearing fitment is the same both sides, so the construction is different but they are both directional.
I guess this means the hub direction on at least these two bikes is important because the spokes are subtly designed to resist braking forces. Pjay's comment ("maybe he's put the wheel on backwards") might apply, although you'd expect the MOT guy to know. It could be that simple though.
Looking at drilling patterns I think some brake discs might also be directional.
PostPosted: 21:37 - 03 Mar 2019    Post subject: Reply with quote
More likely the bearing seats are at different offsets so fitting the wheel backwards would move it off the centre line.
The last post was made 7 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 118.11 Kb
