Lithium battery going (very) flat?
jlparsons
PostPosted: 12:52 - 02 Mar 2019    Post subject: Lithium battery going (very) flat? Reply with quote
I changed over to a lithium iron phosphate battery a couple of weeks ago on my BMW F800GT and after an initial charge everything has been going fine until yesterday when I go out to the garage and find it utterly dead. Not even the clocks flickered when I turned the key - never seen a bike that dead.
I plugged it into a lithium-specific battery conditioner which said it was at very low volts and automatically slow-charged it then fully charged it, so now everything appears perfect again but obviously I need to know what caused it so I don't risk getting stranded somewhere!
The alternator is kicking out 14v and the current drain with the bike turned off is 1.8 miliamps, so that appears all good. Best I can tell there's two options;
1. The battery has had sex and needs returning.
2. My recent short journeys with the heated grips on have drained more than the battery is being charged, causing it to drop. This seems unlikely to me?
Anyone else experience similar issues with lithium batteries?
Fisty
PostPosted: 16:10 - 02 Mar 2019    Post subject: Reply with quote
Sounds like the battery is borked.
Both mine have sat since september last year and started first prod.
Fatter and faster than Fret
doggone
PostPosted: 18:24 - 02 Mar 2019    Post subject: Reply with quote
Is it out of the question something was left on, like the grips. Rolling Eyes
I would see how it goes for a while, you might have something intermittently faulty draining it.
jlparsons
PostPosted: 18:27 - 04 Mar 2019    Post subject: Reply with quote
Not as far as I know. There are heated grips but they're stock not aftermarket and they turn off with the engine. There is an alarm but it has its own battery. Can't rule out something intermittent though of course!
Hong Kong Phooey
PostPosted: 21:23 - 05 Mar 2019    Post subject: Reply with quote
Is the alarm battery for backup only though?
LiFePO4 don't like going flat, parasitic drain of an alarm will flatten it eventually as they don't have the capacity of lead acid equivalent.
temeluchus
PostPosted: 21:58 - 05 Mar 2019    Post subject: Reply with quote
Typically 4AH ish for most of the ones ive seen.
Grubscrew
PostPosted: 22:17 - 05 Mar 2019    Post subject: Reply with quote
One way you can find out if there is a battery drain, if that’s what it is, by exposing fuse box, remove each fuse and slowly put it back, and if you are able to do this in low light levels you may just see a tiny spark across the fuse terminals. Worth a go if it’s possible.
With ignition off
FJR1300/CBR1000F
Motorhate
PostPosted: 14:55 - 12 Mar 2019    Post subject: Reply with quote
Worth bearing in mind that the cold does affect Lithium batteries more than lead-acid / gel type batteries. It's the only thing that's putting me off getting one as they weigh next to nothing.
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
Hong Kong Phooey
PostPosted: 18:40 - 12 Mar 2019    Post subject: Reply with quote
I wouldn't let that put you off, if you ever have problems at low temperatures you just put the headlight on for 30 secs to warm the battery.
I've never had to do it, but a 600cc 4cyl isn't particularly hard to crank.
The last post was made 7 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 61.69 Kb
