Is different suspension travel distance important?
imoner
PostPosted: 18:12 - 05 Mar 2019    Post subject: Is different suspension travel distance important? Reply with quote
Hello!
I need to change the telescopic fork on my motorcycle. I couldn't find the exact same part (Kawasaki ER500), but found from a very similar model (Kawasaki EX500).
Both suspensions are 37mm, but mine is 125mm travel distance and the EX500 is 130 mm. Will that be a problem? Is it compatible?
Thanks!
Bhud
PostPosted: 20:39 - 05 Mar 2019    Post subject: Re: Is different suspension travel distance important? Reply with quote
State the year of your ER5 and the year of the EX500/GPZ500S whose forks you want to swap.
I entered 1999 as the year for both bikes into Fowlers parts. The "fork inner" i.e. the 37mm stanchions are the same part number (44013) if both bikes are '99. The ER5 definitely had different fork stanchion diameters in later years, so be wary and check first.
Both of those bikes came with different fork bottoms in later years, I believe. Double disc brake, etc. But, if both bikes were from 1999, the 37mm fork inner (stanchion) would be exactly the same.
First check the year of the donor bike's fork, then check the stanchion was also part 44013 in that year. Then rebuild your ER5 forks using the new stanchion (as I assume this must be bent or pitted, which is why you want to replace) and the original (old) ER5 fork bottoms and fork internals, albeit with new fork oil, seals, dust seals and bushes.
PostPosted: 20:59 - 05 Mar 2019    Post subject: Re: Is different suspension travel distance important? Reply with quote
https://www.ebay.co.uk/itm/Kawasaki-ER-ER5-ER500-Front-Forks-With-Front-Mudguard-2003-2004-2005/202606981095
There are loads of brand new stanchions available for your forks so there's no need to fit something from a different bike.
PostPosted: 07:19 - 06 Mar 2019    Post subject: Re: Is different suspension travel distance important? Reply with quote
imoner wrote:
Hello!
Thanks!
This indicates there is a difference in design between the two, which may mean the parts might not fit. I'd be wary of fitting any part where I know one of the dimensions is wrong.
Actually, I think I just wouldn't do it at all unless I was engineering it that way for a reason (building some kind of special) or I knew it was a commonly done mod.
The last post was made 6 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 41.75 Kb
