Fuel leaking !!!
Scotsman37
PostPosted: 18:51 - 22 Mar 2005    Post subject: Fuel leaking !!! Reply with quote
See if anybody has got any idea(s) plus a solution to what's causing the problem with my bike;
When the bike is standing upright fuel leaks quickly out of the hose underneath the bike, but when it's on it's side stand it doeasn't appear to be leaking except initially for a very small puddle of petrol the size of a hand that was almost dried out before I stood the bike upright. I checked this puddle and it smelled of petrol which made me suspicious but wasn't sure if it was left behind from another parked vehicle in the same place.
I had not ridden the bike since filling the tank up with petrol yesterday afternoon and it was filled to the normal level as usual.
Any suggestion would be helpfull..... !
mr jamez
PostPosted: 18:53 - 22 Mar 2005    Post subject: Reply with quote
What bike is it?
If it has a carb, the floats might be stuck, causing the float bowl to keep filling up with petrol until it overflows. Seeing as it is coming out of a (I presume) overflow hose I would say this is the most likely thing that is happening. Tapping the carb sharply with the handle of a screwdriver usualy sorts this.
Scotsman37
PostPosted: 19:49 - 22 Mar 2005    Post subject: Reply with quote
Zephyr 550cc
Other suggestion is that there is a hole in the float preventing it from working properly. So either way thanks for the suggestion as I will now be removing the carb to inspect and clean it and to also found out why my idle adjuster will not rotate back/forward as it appears to be stuck !
Bloody Kawasaki's !!!
simon1221
PostPosted: 20:45 - 22 Mar 2005    Post subject: Reply with quote
If it is leaking out of the overflow pipe, then you may have some just dumped in the engine and my find trouble starting it afterwards.
Can you bump a 550cc?
PostPosted: 20:56 - 22 Mar 2005    Post subject: Reply with quote
Agree with the above, most likley is sticking floats, tap the outside of the float bowl and see if it stops.
Otherwise a hole in the float would do it as, would a dirty or damaged needle valve.
Guest
PostPosted: 21:46 - 22 Mar 2005    Post subject: Reply with quote
Depends what the hose is connected to surely? Is there an overflow trap on the filler cap? I'd check that (do a few miles to drop the tank level) before pulling the carbs to bits.
Robby
Dirty Old Man
PostPosted: 12:00 - 23 Mar 2005    Post subject: Reply with quote
My old CB250 RSA did this when it had a carb full of water. Still ran ok, but fuel was pissing out of the carb overflow.
Being a kawasaki of that vintage it could have let some water in through the filler cap. Drain the carbs, give each float bowl a firm knock with the handle of a screwdriver, and see if it behaves.
The last post was made 21 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 50.49 Kb
