TV soundbar and alternatives.
stevo as b4
PostPosted: 01:29 - 21 Mar 2019    Post subject: TV soundbar and alternatives. Reply with quote
I'm just about to by a new 4k TV and I was going to choose a compact wireless/Bluetooth soundbar without a separate Sub.
Is wireless ok? As I've heard that you should used only wired connection to soundbars to eliminate interference? If wireless is ok, then is there any reason why I can't buy a Bluetooth wireless speaker of around 60w and use that instead of a soundbar?
Sorry for the Noob question, but I know nothing about surround sound and soundbars.
PostPosted: 09:49 - 21 Mar 2019    Post subject: Reply with quote
Following; just moved and I'm going to flog the surround system and sub - I'll be shopping for a soundbar soon.
J4mes
PostPosted: 10:06 - 21 Mar 2019    Post subject: Reply with quote
We bought a Samsung TV and soundbar for xmas, used it wireless initially (bluetooth) but found that the sound lagged the picture by a fraction but noticable enough. We bought a 5quid cable and that sorted it.
Make sure you're remotes are compatible, the chap in PC world told us that some makes (LG and Panasonic I think) wont work together so you end up with two remotes, and some units also didn't switch the TV speaker off automatically so you ended up with ghosting unless you set it manually each time you put the TV on.
With regards to buying bluetooth speakers....no idea. Thumbs Up
McHattrick
PostPosted: 14:04 - 21 Mar 2019    Post subject: Reply with quote
I use optical connection.
Wireless will give lag as mentioned already.
Some good advice here.
https://www.crutchfield.com/S-4Nbb3ehCTNq/learn/sound-bar-connection-and-setup-guide.html
If it aint broke... fix 'til it is.
PostPosted: 14:09 - 21 Mar 2019    Post subject: Reply with quote
Bluetooth audio is compressed quite a bit so what you'll gain in sound quality you'll lose in compression artifacts.
doggone
PostPosted: 14:12 - 21 Mar 2019    Post subject: Reply with quote
I'd wait see how it sounds without, some of them have pretty sophisticated adjustment and presets.
weasley
PostPosted: 14:27 - 21 Mar 2019    Post subject: Reply with quote
A soundbar is usually much better than the native TV speakers, especially with a separate sub-woofer. The main unit is usually located right under the TV, so wireless is somewhat redundant - I run mine through HDMI with audio return (ARC). A wireless sub-woofer is useful as you don't have to place this by the TV so can put it anywhere.
That said, if you have a wireless speaker of any kind why not try it out? As above there could be lag and/or quality issues associated with encoding and decoding. You may be able to find an audio setting to shift the audio phasing if this does show up.
However, I'd go for a wired soundbar with wireless sub-woofer. My LG one will also act as a wireless speaker for phone/iPad etc.
RhynoCZ
PostPosted: 14:48 - 21 Mar 2019    Post subject: Reply with quote
I also prefer the optical (toslink) connection and I also do not like Bluetooth audio. The next best thing would be HDMI. I also still enjoy RCA (mainly for stereo setups), however manufacturers just don't use that anymore.
But, to your question, I do believe that things that are supposed to be stationary, shouldn't use batteries and/or wireless signals, unless it's necessary. Not only wireless (and batteries) makes the devices more expensive, they also could be somewhat inconvenient.
Interference = optical audio signal does not suffer from interference. It either works or it doesn't.
NOTE: The optical (toslink) cable is quite brittle and you can't make it do sharp turns.
Soundbars = Yes, they do work and are a convenient solution. There's no need to go crazy though. I got my father Sony HRT3 and it is more than satisfactory.
Baffler186
PostPosted: 17:25 - 21 Mar 2019    Post subject: Reply with quote
Sorry to be negative, but do you really want a soundbar? My bro-in-law has a Bose one and it sounds weird. IMO not as good as my set-up which was half the price (used £30 pioneer amp, new tannoy floor standers which we £99). Very good Bass, sound comes from each side and sounds more natural, plus you get a better stereo sound.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
PostPosted: 12:09 - 22 Mar 2019    Post subject: Reply with quote
mpd72 CPT wrote:
As daft as it sounds, a decent set of pc speakers with a sub and tweeters can sound very impressive on a tv.
I just have a 2+1 set plugged in the headphone socket. The bass has to be kept low because it’s a lot richer than you’d expect fir £30.
Agreed, I had a nice Logitech set with sub and it was real nice.
Courier265
PostPosted: 15:36 - 22 Mar 2019    Post subject: Reply with quote
I bought a soundbar about 14 months ago, it's connected to the USB port for power and plugged into the headphone socket.
I bought it from Amazon, it was £22 at the time (now £25) but the
sound quality is actually better than the TV's own speakers. The TV is
an old LCD TV which has decent speakers. The only reason I got the
soundbar was because when the TV packs up and I get a new one, the
latest TV's now LED come with crap speakers. (unless you spend shit
loads of cash)
https://www.amazon.co.uk/gp/product/B01LZWBFAT/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
PostPosted: 21:23 - 22 Mar 2019    Post subject: Reply with quote
Or
Buy 2 heavy speaker stands (spiked feet).
Buy 2 powered *monitors (each unit has 2 amps each driving their own speaker).
Enjoy the best sound quality.
5" woofer smaller room.
8" woofer for bigger rooms.
Pjay
PostPosted: 21:41 - 22 Mar 2019    Post subject: Reply with quote
My advice if you really want to go for a soundbar is to forget TV brands, they are shite in comparison to soundbars from Sonos. Either buy one or listen to your TV speakers whilst saving for one.
Dont compromise, you'll regret it otherwise.
struan80 - I'll go first - satisfied tick 1
recman
PostPosted: 12:22 - 23 Mar 2019    Post subject: Reply with quote
My old LG TV sound was poo so I bought an LG soundbar to enhance things.
This worked well, I was pleased with the overall improvement.
Then I bought a new 4k LG telly and the sound quality from it is such that the old soundbar is now redundant.
GSTEEL32
PostPosted: 22:26 - 30 Mar 2019    Post subject: Reply with quote
I happened to be in Morrisons one day and found a Samsung soundbar and separate woofer for around £100 I think.
Without a doubt, probably the best £100 quid I've ever spent on tech. It improved the Samsung TV no end. It massively helps that the soundbar automatically syncs to the TV remote on the 1st fire up, I've since ditched the soundbars' remote.
As a powerful Bluetooth speaker, the soundbar also comes in handy as a speaker in its own right .....
The last post was made 7 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 91.03 Kb
