| P.addy |
 P.addy Red Rocket
| Pete. |
 Pete. Super Spammer
 Posted: 13:57 - 24 Mar 2019 Post subject: |
Get your arse round to mine this afternoon. ____________________ a.k.a 'Geri'
| P.addy |
 P.addy Red Rocket
| Nobby the Bastard |
| chris-red |
| Nobby the Bastard |
| P.addy |
 P.addy Red Rocket
| Fisty |
 Fisty Super Spammer
| G |
 G The Voice of Reason
| P.addy |
 P.addy Red Rocket
| G |
| Fizzer Thou |
 Posted: 13:32 - 25 Mar 2019 Post subject: |
I worked on a 4XV R1 a while ago and the owner complained of juddering in the front end under braking.He took the bike to his local bike shop in Wandsworth and they said that the headrace bearings just needed tightening.But after a track day at Brands the situation arose again,most probably due to the different conditions that a track imposes on a machine.
Knowing that Suzuki use very little grease on assembly at the factory,I would also look at the condition and adjustment of these bearings.
Is it worth changing the fork oil while you are about it?It is not like the factories to use a quality oil and even after 5,000 miles the oil goes distinctly thin and damping suffers accordingly  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Pete. |
 Pete. Super Spammer
 Posted: 12:10 - 31 Mar 2019 Post subject: |
Paddy popped round this morning. Turns out that one of the new disks isn't the same thickness all the way round. I've seen this before with aftermarket disks.
I measured the LH disk and it was 0.061mm fatter one side than the other. The RH disk was only a couple of digits different all the way round. So we put a clamp on the LH brake line and Paddy took it for a test - it was braking smooth as silk. ____________________ a.k.a 'Geri'
| Sister Sledge |
 Sister Sledge World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 14:45 - 16 Jun 2019 Post subject: |
Just updating this.
Popped round to Petes today with new disks and (sorry....) a tyre to replace.
The bike is now 100% perfect.
I'll attach pictures once they load, but essentially the disk bolts were well stuck in there which meant I needed Pete's help to undo them, and Pete needed tools  |
| P.addy |
 P.addy Red Rocket
 Posted: 20:34 - 16 Jun 2019 Post subject: |
| Pete. |
 Pete. Super Spammer
 Posted: 21:48 - 16 Jun 2019 Post subject: |
Those bastards put so much threadlock in there it wicked up onto the bolt shoulder and effectively bonded the bolts into the thread, the disk and the counterbore. Even my mains-powered impact wrench struggled with a couple of them. ____________________ a.k.a 'Geri'
| colink98 |
 colink98 Could Be A Chat Bot
| Easy-X |
 Easy-X Super Spammer
| P.addy |
 P.addy Red Rocket
| Pete. |
 Pete. Super Spammer
The last post was made 7 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
