Maximum cornering: theoretical
ThunderGuts
PostPosted: 08:58 - 27 Mar 2019    Post subject: Maximum cornering: theoretical Reply with quote
Morning all,
The other weekend I did a ride out with a friend; I was on my basic and elderly ER5 and he was on a modern BMW S1000XR. Clearly his bike was significantly more advanced than mine, but nevertheless we had a great ride out and at the end he remarked about how despite the ER5 being such a basic bike, it still did everything that day his did. We then got talking about cornering capacity. Now, I know there are a lot of variables on this so let's just set a few things straight first;
- Assume both bikes have the same rubber compound (tyres are obviously different sizes though)
- Assume the test area is perfectly flat with no undulations/ripples or surface imperfections
- Assume both bikes are being ridden by the closest thing to a computer, i.e. perfectly consistent rider with no errors
With these things in mind, which bike is likely to ultimately be able to corner harder? Instinctively I'd think the BMW given it's broader tyres, sportier setup etc., but I'm not so sure it's quite as simple as that?
Clearly if you throw in real world issues, like an undulating road surface, I'm sure the advanced suspension on the BMW is going to give it an advantage on top of any others it already has.
Just an interesting topic for discussion; what do people think?
TG.
pompousporcup...
PostPosted: 11:08 - 27 Mar 2019    Post subject: Reply with quote
the s1000 for sure.
chassis development, steering geometry, tyre profiles(because of the size) and computer aids are going to help the newer bike out handle and out corner the er5..
that said. i was consistently being overtaken into and out of corners by pesky er5/cb500s at cadwell, bikes that had half the cc and were much older than the one i was riding.
ThunderGuts
PostPosted: 12:13 - 27 Mar 2019    Post subject: Reply with quote
pompousporcupine wrote:
the s1000 for sure.
I was really thinking more about the ability to pull the most G force as opposed to handling which, as you say, has a lot more to do with the bike itself as you're changing direction as opposed to just introducing more and more lean.
TG.
PostPosted: 12:39 - 27 Mar 2019    Post subject: Reply with quote
Beemer because of ground clearance.
ThunderGuts
PostPosted: 12:43 - 27 Mar 2019    Post subject: Reply with quote
Yeah I could imagine that being an issue actually! The absence of one of my hero pegs suggests that the previous owner discovered that too (or managed to knock it off during one of it's drops).
TG.
Sister Sledge
PostPosted: 12:54 - 27 Mar 2019    Post subject: Reply with quote
I'm not clued-up on the suspension. Do they have computer aided stuff in the shocks on those? Just that I think it would go a long way towards keeping rubber touching the surface and thus having enough grip.
I must be going back many decades here but I once watched a race at Langbaurgh race track at Middlesbrough.
https://www.teessideautodrome.co.uk/
It was between 250cc bikes. The race was on the kart track and wasn't a long lap but did include some 'interesting' corners.
In the race the majority of bikes were 250lcs but one stood out - an old CZ 250 with the square tank, mega finned air cooled engine etc. The CZ won the race!!
The reason was more about power delivery than anything else and half those lcs fell off in their attempts to outrun the CZ. That CZ had a smooth power delivery and not a peaky tuned engine.
CCM 404 DS
ThunderGuts
PostPosted: 12:58 - 27 Mar 2019    Post subject: Reply with quote
Indeed, hence the remark about being on a completely smooth and perfect surface where presumably suspension becomes a lot less relevant as even really bouncy stuff should just settle in under the load.
TG.
Kawasaki Jimbo
PostPosted: 13:50 - 27 Mar 2019    Post subject: Reply with quote
A narrower tyre will turn in more quickly.
https://www.conti-bike.co.uk/tyre-tech-talk/tyre-size-matters/
the wider the tyre, the more lean you need to get through a corner. As you lean the bike over, the contact patch moves away from the centre like of the bike towards the shoulder of the tyre. The further the contact patch from the centre, the wider the arc the bike wants to run, and the slower it steers too.
Jim Mc
PostPosted: 15:11 - 27 Mar 2019    Post subject: Reply with quote
Hmm, wonder who wrote that, doesn't seem correct to me.
PostPosted: 15:54 - 27 Mar 2019    Post subject: Re: Maximum cornering: theoretical Reply with quote
Given it's perfectly flat and you're looking for consistent cornering speed ( I presume), suspension isn't going to come into it too much. If you're talking a fairly quick turn in and getting on the power again, better suspension will make a difference.
Ground clearance may well be an issue as mentioned - though hanging off decently can mitigate this.
The bigger tyres will allow the BMW to 'key' with more surface, but it's also got more weight to keep on track.
DJP
PostPosted: 17:42 - 02 Apr 2019    Post subject: Reply with quote
All else being equal, on a perfectly smooth track, the greatest cornering ability would belong to the bike with the most ground clearance.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
PostPosted: 17:45 - 02 Apr 2019    Post subject: Reply with quote
If ground clearance is a limiting factor - with a rider hanging off decently it often isn't, at least outside of motogp tyres - and of course depending on the radius of the turn etc.
redeem ouzzer
PostPosted: 17:49 - 02 Apr 2019    Post subject: Reply with quote
The ER5 has a steel frame, damper rod forks and crossply tyres. These are not things conducive to fast cornering.
Be a REAL MAN!
stevo as b4
PostPosted: 18:53 - 02 Apr 2019    Post subject: Reply with quote
Lots of theoretical bollocks.
You and your mate with the BMW are never going to be equal riders of the same exact ability, skill, and confidence no matter what you both do.
As you and I know, theoretical doesn't mean naff all out in the real world, and there's no theoretical perfect or flat roads and exact constant radius and road surface friction bends anywhere on the highway either.
Therefore it's down to the rider. If BMW rider isn't very good but the ER5 rider is fast, smooth and confident, then who do you think will corner the quickest?
If the slowest rider is on the slowest bike, then again it's pretty obvious where that's ending up too.
ThatDippyTwat
PostPosted: 19:04 - 02 Apr 2019    Post subject: Reply with quote
As said, it's largely down to the rider in most legal conditions in the UK. I regularly pass a mate that rides an '09 R1 on my '96 Viffer. That should never happen. I'm not a particularly fast rider these days either. But he's almost scared of corners, and makes it easy to nip up the inside, around the outside. He absolutely slaughters me on straights, he has something like 80HP more and 40KG less, but he's on the brakes so bloody early, I reckon I could probably take him on something like an RS125 or a Mito, let alone a VFR or any capable sportsbike. It doesn't matter what youre riding if you can't use it properly.
Bozzy.
PostPosted: 20:33 - 02 Apr 2019    Post subject: Reply with quote
I’d imagine the BMW still being the more capable bike. I think you’d need to be on a track to really see a difference though, as riding on a public highway would still be the limiting factor.
SV650S>>>Street Triple R
MCN
PostPosted: 21:04 - 02 Apr 2019    Post subject: Reply with quote
BMW.
Because of rules, laws and customs.
recman
PostPosted: 21:13 - 02 Apr 2019    Post subject: Reply with quote
Get yourself a Street Triple and take the piss out of him.
ThunderGuts
PostPosted: 08:40 - 03 Apr 2019    Post subject: Reply with quote
To be fair, he's both a more skilled and confident rider than I am and clearly real world riding is a whole different ball game - the whole discussion came up because I think we were ultimately getting to the basics of the physics, i.e. taking out all the variables (rubber, rider, surface, suspension) and just thinking about pure cornering physics and how much difference things like bike geometry, weight, centre of gravity etc.
TG.
MCN
PostPosted: 19:53 - 03 Apr 2019    Post subject: Reply with quote
It is all related. If it wasn't then there probably would not be a demand for tyre, suspension, frame, brakes and geometry performance in bikes.
A more accurate test is maybe an ABS DTC bike against it's More basic sibling. With the same rider on the same course.
It is always 'opinion biased' when mates compare. Mostly.
Some say a 600 is faster around a track than a 1000.
It isn't but there are a lot of folk who are fast on any bike.
What a minefield subject with too many correct opinions. Very Happy
Kawasaki Jimbo
PostPosted: 20:40 - 03 Apr 2019    Post subject: Re: Maximum cornering: theoretical Reply with quote
Just to note that the BMW S1000XR- that's the tall 'adventure sports' machine, not the road racer.
Penny Coin Penny Coin
Given those three controlling factors I'd say you're left with which bike has the shortest wheelbase, sharpest geometry and lightest weight. I guess if there was no suspension at all that would be it (apart from my earlier tyre width comment). Suspension will react to braking and acceleration by changing the wheelbase/ geometry as the front dives or the rear pushes into the ground. If the suspension wallows or returns too quickly the bike will be unsettled and time will be lost. Given perfect suspension and two bikes matched in all other factors the faster cornering one will have better brakes on the entry and turn in, and better acceleration between apex and exit.
TaffyTDM
PostPosted: 22:14 - 03 Apr 2019    Post subject: Reply with quote
Also : who had the bigger hangover?
Old Git Racing
PostPosted: 14:07 - 04 Apr 2019    Post subject: Reply with quote
If I couldnt corner harder and faster in any circumstances on the beemer I'd give up riding.
OGR
The last post was made 7 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 120.31 Kb
