Are flat/flush electrical plugs even a thing?
GSTEEL32
PostPosted: 23:03 - 01 Apr 2019    Post subject: Are flat/flush electrical plugs even a thing? Reply with quote
I have a sofa.
It's covers literally every millimetre between the skirting board between two walls.
Once placed, it'll cover a couple of wall sockets which ideally I'd like to access.
Do plugs / extensions exists which don't sit as proud as a conventional 13amp plug?
Is cutting the material on the side of the sofa the only option available ?
Google doesn't seem to help, but maybe I'm using the wrong terminology. ....
Thanks.
PostPosted: 23:09 - 01 Apr 2019    Post subject: Reply with quote
I've run an extension lead out the back of a socket as a spur; 20 years later, still no fires or deaded kittens.
GSTEEL32
PostPosted: 23:13 - 01 Apr 2019    Post subject: Reply with quote
I was thinking of doing the same, but it's within an extention to the main house, so I'm sure it's already a spur.
Can you spur a spur? ... I thought that was a no-no?
PostPosted: 23:18 - 01 Apr 2019    Post subject: Reply with quote
Only if you want every sparky in a 20 mile radius go into a Part P rantathon gammon meltdown.
GSTEEL32
PostPosted: 23:37 - 01 Apr 2019    Post subject: Reply with quote
Hmm... I might have to blank it off and move it perhaps. ... seems like a lot of aggro for very little payoff. Cheers shaggy.
Freddyfruitba...
PostPosted: 00:33 - 02 Apr 2019    Post subject: Reply with quote
So how about replacing the socket with a fused connection unit; you'd have a flex coming out of a knockout on its bottom edge, leading to a trailing socket. Unconventional, but I'd have thought kosher and safe?
The last post was made 7 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 48.26 Kb
