strange revs- high and wont return smooth and slow to drop
Ric
PostPosted: 15:59 - 23 Mar 2005    Post subject: strange revs- high and wont return smooth and slow to drop Reply with quote
when i rev it goes up and stays there and then drops down really slowly
basically sounds like im ragging it of a blip of the throttle
bit worring, assuming the change in heat has summin to do with it
Jrod
Page 3 Girl
PostPosted: 16:39 - 23 Mar 2005    Post subject: Reply with quote
Shocked
instigator
PostPosted: 17:30 - 23 Mar 2005    Post subject: Reply with quote
Zxr400er wrote:
Shocked
I'll second that.
So, it's definetely not something to do with a sticking throttle cable/contacts?
Does it do this straight from start up (I know you're not supposed to rev a cold engine that high) or jsut once it's completely warmed up?
Jrod
Page 3 Girl
PostPosted: 17:34 - 23 Mar 2005    Post subject: Reply with quote
Lower the idle? Confused
You HAVE to come on sunday, no excuses. Razz
alains
PostPosted: 17:39 - 23 Mar 2005    Post subject: Reply with quote
probably dirty throttle cable or the throttle itself . wd40 inside the cable , clean the throttle and lodging
Odie
PostPosted: 17:49 - 23 Mar 2005    Post subject: Reply with quote
Sounds like your carbs are out of balance, (more than one carb)?
swampy
PostPosted: 18:14 - 23 Mar 2005    Post subject: Reply with quote
Could be an air leak between the carb(s) and inlet manifold. My bike did this, and that was the cause Thumbs Up
Scotsman37
PostPosted: 18:32 - 23 Mar 2005    Post subject: Reply with quote
Possibly your throttle cable is rusted up and so get a cable oiler device + a tin WD40 to help free up the movement of the cable.
Ric
PostPosted: 19:14 - 23 Mar 2005    Post subject: Reply with quote
id tighten the cable too much last week, dunno y it changed now
roll on kwak sunday
Kye
PostPosted: 20:58 - 23 Mar 2005    Post subject: Reply with quote
Carbs are probably out of balance or an air leak in one, my ZXR did that and was fine after balancing the carbs
Ducati 600SS
Vespa PX125
The last post was made 21 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 61.62 Kb
