| chris-red |
 Posted: 14:17 - 09 Apr 2019 Post subject: Garage flooring Options (again) |
My long awaited garage is nearly done, For reasons I CBA to go into it has taken far longer than expected and the base isn't as smooth as I would like.
However currently all the brickwork is up, the steel to support it is going in Saturday as are the side doors, the Roof should begin the week after, and the week after that the roller door will arrive.
The base is solid but slightly lumpy in a fair few places, it will need a screed of about 5mm.
My question is will a latex screed such as this set hard enough to withstand abuse from side stands or when I throw my spanners on the floor after fucking something up.
I will be putting an epoxy floor paint over it.
The other option is PVC tiles such as Ecotile. But this is about 4 times the price.
https://www.bikechatforums.com/download.php?id=102214 ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| t121anf |
 t121anf World Chat Champion
| J4mes |
 J4mes World Chat Champion
 Posted: 09:23 - 10 Apr 2019 Post subject: |
Fucking expensive to tile it, but if you're gonna be there for 40 years its probably the best way.
I've a double garage to do, 30 square meters, but theres about 500 other household tasks that want the time and money first  |
| Bubbs |
 Bubbs World Chat Champion
| Freddyfruitba... |
| J4mes |
| t121anf |
 Posted: 13:16 - 10 Apr 2019 Post subject: |
| barrkel |
 barrkel World Chat Champion
 Posted: 16:39 - 10 Apr 2019 Post subject: |
I put down PVC tiles on my garage floor. They show a little bit of denting if a bike on a centerstand has been in one spot for a while, but are otherwise sturdy. Easy to sweep clean, doesn't generate dust like concrete, just about ok to kneel on if you need to (the little grip mouldings are a bit poky).
If I did it again, I wouldn't choose black. A lighter colour is better for visibility all around, and it's easier to find things against a lighter background. OTOH if I had some brighter colour, I might be complaining now about how dirty it gets. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| hellkat |
 hellkat Super Spammer
 Posted: 19:12 - 10 Apr 2019 Post subject: |
Go checkerplate or go home.
Oh wait ...
 ____________________ Not nearly as interesting in real life. |
| owl |
 owl World Chat Champion
 Posted: 19:16 - 10 Apr 2019 Post subject: |
Another vote for tiles
https://i.imgur.com/WF6jtRe.jpg
*not mine ____________________ Observation is the greatest source of wisdom. |
| hellkat |
 Posted: 19:20 - 10 Apr 2019 Post subject: |
Wow, tarts palace  ____________________ Not nearly as interesting in real life. |
| Grubscrew |
 Grubscrew Scooby Slapper
| Ribenapigeon |
 Ribenapigeon Super Spammer
| Suntan Sid |
 Posted: 18:59 - 11 Apr 2019 Post subject: |
I notice there's been a mention of "porcelain" tiles.
A bit of advice, assuming the garage floor in question is, merely, a concrete base, even if you heat the garage the addition of porcelain tiles will, inevitably, mean your feet will be like blocks of ice, if you spend any time in there during cold weather!
Guess how I know. ____________________ "Everybody needs money, that's why they call it money!"  |
| J4mes |
| bugeye_bob |
| MCN |
 MCN Super Spammer
 Posted: 23:21 - 11 Apr 2019 Post subject: |
Look at Havwoods.
I bought 'SMOOTHING COMPOUND MXS110' from them to repair the fcuk up I made when I laid my garage floor.
It is quick setting.
You can walk on it within a hour of mixing.
It sets as hard as a hoowur's heart in about 24hrs
You WILL need to treat that bare/raw concrete no matter what you put down to stop moisture coming through.
Havwoods sell Marldon products.
You need a primer.
Then a Damp Proof Membrane (DPM) that is a two-pack that rolls on like thick paint. Sets in about 1 hour to a hard as fcuk coating.
Then you mix and pour and spread the 'smoothing compound'.
I got this advice from a building consultants in Hamilton (Scotland) but they use Havwoods as a supplier for their floor stuff.
My floorspace is quite large so it took a lot of material to cover.
But it does a very nice job.
I would buy:
A bit fat roller and a pole for it. It's about 18" wide.
A plaster whip.
And a SDS drill to drive the whip. If you use a normal drill it may burn out the motor like mine did. You cannot mix fast as you will make bubble which will not have time to disperse before setting. Can be an issue if you are too greedy mixing to fast.
Buy some spikey shoes. So you can walk on your smoothing compound to spread properly.
I would do the same thing to the next concrete floor lay I fcuk up.
The whole deal shouldn't be much more than £200. Which is well worth it when you see the end product. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| BTTD |
 BTTD World Chat Champion
 Posted: 09:41 - 12 Apr 2019 Post subject: |
Plasfloor plastic tiles. Worth a look. I have half my garage floor covered in these (I keep meaning to do the rest, but something else always takes priority). The yellow ones are relatively light, but they do show dirt so need bit of a mop once a year.
I've also seen thick rubber mat tiles https://www.machinemart.co.uk/p/grassmats-gms014-17-8k-garage-tiles-and-edging/ which look interesting. They might need a bit of ply for under a side stand, but look like they would save a dropped tool or two.
My lock up garage didn't have a dpm and the floor was lumpy and rough and sloped towards the back. I put a dpm in and a 2" to 3" screed on top. I used a sharp sand 3:1 cement mix with a lot of SBR added into the mix. The screed is very hardwearing and does not dust off. It came out dead smooth and would have been dead flat if my father in law hadn't been helping me. He kept troweling the mix in one area to push it down to level, resulting in other areas getting pushed up slightly rather than scraping off to level. It isn't much, but it's fcking annoying when the sections I did on my own are dead right. |
| t121anf |
| kingmunky |
 kingmunky L Plate Warrior
| sickpup |
 sickpup Old Timer
| chris-red |
 Posted: 14:58 - 13 Apr 2019 Post subject: |
There is a DPM down and the slab went down in November I think it's OK.
Funny you mention patio doors, I put them in today.
https://i.imgur.com/CM0oBv0.jpg
The steel also went in today, I still need to paint that one side (it was face down) but it's raining and I CBA.
https://i.imgur.com/Ge7WT82.jpg
I also ran (well my mate did) conduit behind the steel for the leccy and I put a bit of pipe through to run an airline.
https://i.imgur.com/f4huNo0.jpg
Budget is knackered now, again long story, I don't think I can afford to get a tiller and I've never tiled before and don't trust myself to do a vaguely decent job. The roof goes in starting Tuesday,(covered in the budget) the rest of the electrical the floor and the paint/any extras will be going on a credit card. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| sickpup |
 sickpup Old Timer
| Grubscrew |
| chris-red |
 Posted: 13:05 - 15 Apr 2019 Post subject: |
I don't want to have a floor 2"+ thick!
As for waiting, not really an option anymore, The house, shed and garden is a total dump full of tools and stuff that needs to go in. We do not want to lose another summer with essentially no garden It's already long overdue, and both me and my missus are fed up living like that. I also need to do a sizable amount of work on my TDM(s) My 'Good' one, is no longer allowed in London so I have an 07 one that is, however this new one isn't to to my standard, I need to swap a lot of bits over wire in all my accessories. I also need to swap engines and get the old one ready for sale. Not stuff I can do out a garage. This should have all been done in advance of the ULEZ but winter and lack of garage meant it didn't.
It's worth considering though. I figure I'll try the plastic tiles, with the idea that it is at least semi permanent. If it doesn't work out at a later date I'll get it tiled properly. From what I have seen the plastic tiles are very saleable so I should recoup a lot of the cost if I choose to go a different route. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
The last post was made 7 years, 163 days ago. Instead of replying here, would creating a new thread be more useful? |
