| c_dug |
 c_dug Super Spammer
| ThunderGuts |
 ThunderGuts World Chat Champion
| BTTD |
 BTTD World Chat Champion
| P.addy |
 P.addy Red Rocket
| owl |
 owl World Chat Champion
| P.addy |
 P.addy Red Rocket
| owl |
 Posted: 13:42 - 16 Apr 2019 Post subject: |
| Paddy. wrote: | | owl wrote: | Just be careful if you don't use it, some insurance companies specify it must be in use.
If you make a claim and say it was in use and then later the bike is recovered and it's not busted, could that land you in trouble? |
It was on when I parked it, prove otherwise. Recovered in good nick, thank god they replaced the lock for me. Most of the time, it ain't coming back. |
Point taken, it might come back though though, if it has a tracker fitted, but that's usually within hours if it does, after that it's likely gone.
My point though is just make sure you get your stories straight in the event of a claim, and check your policy documents, otherwise might end up like that poor Tracer fellow who was denied his claim for not having a disc lock. Did anyone ever hear more about that? ____________________ Observation is the greatest source of wisdom. |
| Pete. |
 Pete. Super Spammer
 Posted: 18:23 - 16 Apr 2019 Post subject: |
Bad luck Conan. Did they just pull the barrel out of the lock? You can get replacements quite cheaply from Motorworks. Even if they have broken the retainer in the barrel (likely) I have found a way of fixing it in successfully. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 20:01 - 16 Apr 2019 Post subject: |
| jnw010 wrote: |
I find this advise a bit confusing. If you don't use the steering lock and they steal it you're better off than if it gets damaged but they don't get the bike? Chances are you'll never see the bike again if they do get it, damaged steering lock or not.
I've personally never heard of a steering lock jamming on, has anyone else had that? Genuinely interested. I know lock cylinders can jam up if you've been filing them with WD40 for years, but I've had a few old bikes and never had a steering lock jam on. |
Most of the bikes I've had stolen turned up again. When the steering lock was on they have had various levels of damage I had to fix. From a minimum of a new lock barrel right up extensive damage resulting from repeated booting of the end of the handlebar inculding switchgear, throttle tube, broken lockstops, bent handlebars and a damaged bottom yoke.
Lockstops in particular can be a royal PITA to fix and can write a bike off because they are part of the frame.
I leave the keys in my bikes in the garage these days. Then if they are stolen and turn up again, there's a chance I don't have to go through all the rigmarole of fixing that shit again. Especially bikes with multiple locks. If they are standing in my garage, a lockstop isn't going to prevent them taking the bike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| c_dug |
 c_dug Super Spammer
 Posted: 22:58 - 16 Apr 2019 Post subject: |
| Pete. wrote: | Bad luck Conan. Did they just pull the barrel out of the lock? You can get replacements quite cheaply from Motorworks. Even if they have broken the retainer in the barrel (likely) I have found a way of fixing it in successfully. |
They just snapped the lock using the bars fortunately, a new barrel would sort it, just a pain in arse because the top box and panniers currently match the ignition. Also not sure what the deal is around the immobiser with a new ignition but I'm told that's not a problem.
I'm still trying to work out exactly what went on as it goes. I left the bike on the centre stand, with the steering lock and disc lock on. when I came back the bike was on its side stand with broken steering lock, but seemingly no damage to the disc lock at all.
The disc lock alarm is really sensitive though, so either moving the bike from the centre stand or snapping the steering lock would have had the disc alarm going off straight away for sure. If the alarm going off was enough to stop them then I don't understand how or why they did both, surely they'd have just given up the second it went off?
Also, why put it on the sidestand instead of just dumping it and running.
There's usually at least a little bit of understandable method in how thieves do their thing, I can't really wrap my head around it this time. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| stinkwheel |
 Posted: 23:06 - 16 Apr 2019 Post subject: |
I recently discovered you can dismantle most ignition locks and rearrange the wards to match your original key. There are loads of small springs so be warned. Youtube will help. Who knew?! ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pete. |
 Pete. Super Spammer
| barrkel |
 barrkel World Chat Champion
| chris-red |
The last post was made 7 years, 147 days ago. Instead of replying here, would creating a new thread be more useful? |
