How to tell if an Air-cooled engine is getting too hot?
adengtg
PostPosted: 19:34 - 23 Apr 2019    Post subject: How to tell if an Air-cooled engine is getting too hot? Reply with quote
Hey guys, with all the nice weather approaching, i'm wondering how to tell if my bike is getting too hot and if there are any ways of keeping it cool? Ive got a 1999 Xj600S, they used to be air cooled but mine has a small-ish oil cooler as its a later model.
The past week has been stunning and with temperatures of 23° means that i've been out on some long rides and pushing my little restricted engine fairly hard on some roads. I can't help but feel paranoid that i'm going to overheat my engine or cause heat related damage somehow.
What ways are there to tell if this is the case when i'm out riding in hot weather? I did think of putting fans on my oil cooler and just wiring them into a handlebar mounted switch but i wouldn't be sure if it would do anything or be worth the hassle if it did. I'd be grateful if anyone could offer some advice or tips.
Thanks for the help!
Nobby the Bastard
Harley Gaydar
PostPosted: 19:43 - 23 Apr 2019    Post subject: Reply with quote
How do you tell if an air-cooled engine is too hot? It heat seizes....
Triumph Sprint ST 1050
adengtg
PostPosted: 19:45 - 23 Apr 2019    Post subject: Reply with quote
I'll try to look out for that then...
MCN
PostPosted: 19:56 - 23 Apr 2019    Post subject: Reply with quote
Glue a Thermistor onto the head. (Araldite it on.)
I'm sure you can find a device on eBay that has the sensor and an LED Display.
https://www.ebay.co.uk/itm/Digital-Led-Display-Thermometer-Fridge-Temperature-Gauge-Meter-Monitor-GF/113698757263?hash=item1a78f95a8f:m:mQ0qbPeLA2COUc5-Nh1nXjQ&frcectupt=true
good up to 110° Centipede. (It should be almost well cooked by then. )
https://www.go-araldite.com/products/araldite-product-selector#r_34_199
adengtg
PostPosted: 20:04 - 23 Apr 2019    Post subject: Reply with quote
Ok, thanks very much mate, ill try to rig that up sometime soon
Riejufixing
PostPosted: 20:32 - 23 Apr 2019    Post subject: Reply with quote
I reckon it'll cook your 110C thermometer, as well as the Araldite.
If you want to stick something to something hot, then silicone adhesive (as in instant gasket compound, etc.) will withstand much higher temperatures than Araldite.
Why do you think your bike will suffer in a mere 23C ambient temperature? Say for instance it's OK at a cool 15C. If ambient goes up to 30C, you've still only added a sort-of-potential 15C to the running temperature, and in real life you won't even get that, since heat will dissapate faster from a hotter object.
PostPosted: 20:34 - 23 Apr 2019    Post subject: Reply with quote
If it catches fire then it's getting too hot.
Robby
Dirty Old Man
PostPosted: 20:44 - 23 Apr 2019    Post subject: Reply with quote
It's air cooled. It was designed to operate over a wide range of engine temperatures. It was also designed for a global market, including sitting in traffic in sandy countries. You aren't going to hurt it.
Of course, might be a blessing if you do kill it it. One less divvy is always nice.
MCN
PostPosted: 20:53 - 23 Apr 2019    Post subject: Reply with quote
redeem ouzzer
PostPosted: 20:57 - 23 Apr 2019    Post subject: Reply with quote
Ignorance is bliss.
Plus what would you do if your engine got “to hot”?
I’ve had lots of oil cooled GSXR’s and never once worried about how hot they were getting.
Be a REAL MAN!
adengtg
PostPosted: 21:03 - 23 Apr 2019    Post subject: Reply with quote
GT200Fan79 wrote:
Ignorance is bliss.
I don't know what i'd do, thats the point.
adengtg
PostPosted: 21:04 - 23 Apr 2019    Post subject: Reply with quote
Trust me, if i could afford anything else, i wouldn't have a diversion.
chickenstrip
PostPosted: 21:12 - 23 Apr 2019    Post subject: Reply with quote
I can't afford anything else, but I still haven't got a divvy Laughing
RhynoCZ
PostPosted: 21:13 - 23 Apr 2019    Post subject: Reply with quote
Don't worry about it, as long as the revs match the speed (meaning, your not reving it while stationary) the engine won't overheat.
None of the air cooled machines that I have ever ridden/owned overheated and we do get 35°C+ summers here. In fact, I'd overheat sooner than the engine would.
The only thing one can do is to check the spark plugs. Those will tell you whether the mixture isn't too lean or the engine running too hot.
Other than that, I would not worry about it much. Just don't rev it when stationary and keep moving.
adengtg
PostPosted: 21:14 - 23 Apr 2019    Post subject: Reply with quote
The only thing one can do is to check the spark plugs. Those will tell you whether the mixture isn't too lean or the engine too hot.
Easy enough, thanks for the help mate.
RhynoCZ
PostPosted: 21:20 - 23 Apr 2019    Post subject: Reply with quote
To make things a bit more clear, lean mixture leads to overheating. Rich mixture has the opposite effect while washing out the lubricant off the cylinder walls, which leads to accelerated piston rings wear. Overheating might even happen when the mixture is perfect though, but it's unlikely on an air cooled engine.
Also, running too hot could alter the colour of the exhaust headers.
adengtg
PostPosted: 21:23 - 23 Apr 2019    Post subject: Reply with quote
RhynoCZ wrote:
To make things a bit more clear, lean mixture leads to overheating. (rich mixture has the opposite effect while washing out the lubricant off the cylinder walls, which leads to accelerated piston rings wear) Overheating might even happen when the mixture is perfect though, but it's unlikely on an air cooled engine.
Alright, i'll make sure to check this on the next spirited ride i go on.
Riejufixing
PostPosted: 21:24 - 23 Apr 2019    Post subject: Reply with quote
Widdle on it.
If it's running at the time, avoid widdling near the sparking-plugs.
RhynoCZ
PostPosted: 21:27 - 23 Apr 2019    Post subject: Reply with quote
There's no need to wait, once the spark plugs get ''heat'' damaged, they stay that way.
But, if the bike runs alright, I would not worry about it. Regular oil changes and basic maintenence is all I would do.
Yorkshire Geek
PostPosted: 21:28 - 23 Apr 2019    Post subject: Reply with quote
As the owner of a '96 you'll be able to smell it. Don't sit in traffic queues Smile
adengtg
PostPosted: 21:30 - 23 Apr 2019    Post subject: Reply with quote
Never do anyway
adengtg
PostPosted: 21:33 - 23 Apr 2019    Post subject: Reply with quote
At the moment, i'm running iridium plugs. Managed to get them cheaper than normal ones off the official NGK amazon page. Don't suppose you know if the wear looks different on them? i can always consult haynes but not sure if it would be different for iridium.
Riejufixing
PostPosted: 21:34 - 23 Apr 2019    Post subject: Reply with quote
Insufficient exhaust valve clearance causes that too (and retarded ignition timing, but is it adjustable on this engine?).
RhynoCZ
PostPosted: 21:39 - 23 Apr 2019    Post subject: Reply with quote
I'd say the insulator bit on both the iridium and regular spark plugs is about the same, so it will discolour the same with wear/damage. But again, I recommend less thinking more riding. Cool
adengtg
PostPosted: 21:40 - 23 Apr 2019    Post subject: Reply with quote
I can do that Smile
The last post was made 7 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 134.45 Kb
