CBR 125 engine cut out
Steffan
PostPosted: 22:44 - 23 Apr 2019    Post subject: CBR 125 engine cut out Reply with quote
My first post on here. I'm looking
for some help, bought a 2008 CBR 125r and it's turned into a proper ball ache, when I hit high revs the engine cuts out, it'll start back up fine, but always fails on high revs, I've changed the oil, spark plug, air filter and ignition coil, and run a couple of tanks of injector cleaner through it, yet it's no better. Any help would be appreciated.
jaffa90
PostPosted: 23:11 - 23 Apr 2019    Post subject: Reply with quote
Sounds like fuel supply and pressure problem but you know that so when were the fuel filters changed and then a pressure test and injectors cleaned being a 11 year old bike ?
Steffan
PostPosted: 23:22 - 23 Apr 2019    Post subject: Reply with quote
Not had it long, the guy I bought it off lied through his teeth regarding the bike, it's had no such tests with me yet, chipping away at it on my days off. A friend suggested it could be a faulty rev limiter/sensor? Breather pipes are fine as well, forgot to say.
jaffa90
PostPosted: 23:41 - 23 Apr 2019    Post subject: Reply with quote
It could be this or that, it could be a faulty T.P.S. telling porkies.
At the end of the day it`s short of fuel at the top end revs.
Steffan
PostPosted: 23:51 - 23 Apr 2019    Post subject: Reply with quote
I'll carry on working at it, one area at a time, eventually I should figure it out.
Nobby the Bastard
Harley Gaydar
PostPosted: 07:49 - 24 Apr 2019    Post subject: Reply with quote
How about you fix my broken fairing in the hopes of it solving your problem?
Randomly replacing parts isn't really a sensible option for fault finding.
Triumph Sprint ST 1050
Steffan
PostPosted: 08:22 - 24 Apr 2019    Post subject: Reply with quote
I'm not randomly doing anything, I'm checking and replacing what needs doing anyway, as the bike has been neglected, but if along the way these parts/jobs could be connected to the listed problem, hopefully It'll show itself as I do them. Maybe if you get your fairings fixed it may make your comments more useful 😂
Nobby the Bastard
Harley Gaydar
PostPosted: 08:37 - 24 Apr 2019    Post subject: Reply with quote
So why did you race the ignition coil?
Does your bike have a socket for a diagnostic tool?
Does it make some flashing lights when you first turn it on?
Steffan
PostPosted: 09:10 - 24 Apr 2019    Post subject: Reply with quote
Diagnostics socket I'm not sure about yet, only had the bike about two weeks, got to fit working on it during my days off, I doubt it though, but i will look into it.
Replaced coil as it's an old bike, they break down over time and it was a quick and cheap job to do. Obviously I'm looking for the exact cause of the fault, but as I go, I'm replacing worn parts and giving it some maintenance which it's over due.
I'm no expert on bikes, I have a basic knowledge I suppose.
Nobby the Bastard
Harley Gaydar
PostPosted: 10:05 - 24 Apr 2019    Post subject: Reply with quote
You wasted money on the coil.
Steffan
PostPosted: 10:13 - 24 Apr 2019    Post subject: Reply with quote
It was cheap and easy to do, now it won't need doing for a while, I'm ok with it. No, starts on the button each time, nothing obvious there, no lights or anything like that.
The last post was made 7 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.42 - MySQL Queries: 13 - Page Size: 64.74 Kb
