Street Triple Immobiliser Issue
Biggerishi
PostPosted: 11:15 - 01 May 2019    Post subject: Street Triple Immobiliser Issue Reply with quote
Hi,
My immobiliser has been having issues for a while now, it sometimes kicks in when I turn the key (a bit of jiggling with the handlebars/wires usually fixes it), sometimes it starts fine.
However now it won't start at all, and the immobiliser light just stays on.
I suspect that it's the antenna that is the problem, but is it possible to just replace the antenna, as I have the original key, or is the antenna itself linked with the ECU?
Can I use my spare key to bypass the antenna entirely using a universal Immobiliser bypass?
Hoping someone more mechanically inclined will know!
It's a street triple 2013 model.
recman
PostPosted: 11:22 - 01 May 2019    Post subject: Reply with quote
Jiggling with the handlebar/wires makes me think you may have had the same problem I had on my Street Triple.
My ignition cables fatigued and severed at the exit point of the ignition barrel.
https://i.postimg.cc/6Q7ZH59b/20180512-110855.jpg
Biggerishi
PostPosted: 11:32 - 01 May 2019    Post subject: Reply with quote
Yeah you're spot on, I did have some frayed and even a broken cable there, which I sorted out and fixed before, I'll have another check and make sure they are ok, but the immobiliser was still an issue after they were fixed.
Pigeon
PostPosted: 18:08 - 01 May 2019    Post subject: Reply with quote
Mine did exactly the same thing after 3 years and about 20k miles.
Bonnie's got a recall because of it i think, but not the striple.
The last post was made 7 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 39.7 Kb
