| flik9999 |
 flik9999 Derestricted Danger
| jaffa90 |
 jaffa90 World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 03:50 - 30 Apr 2019 Post subject: |
Restricted it has about 13bhp. Unrestricted it has about 22.
How fast do you hope it will go? The most powerful of the kiddie-go-kwik two-smoke 125's had just under 30bhp, and couldn't quite nudge the ton. Only specially prepared homologation special variants ever did that... just. They were all about as slow as a forty year old four-stroke 250 commuter bike, and if you check specks there, little with 20-25bhp, struggled much over a genuine 80mph.
On what is now, at least an 18 year old bike, that was rather prone to kiddie-go-kwik abuse when it was new, let alone with two decades or more of contributory abuse, PERSONALLY, I would merely be slightly more gratelful that the dang thing went at all! And 70mph is as fast as anything is legally allowed to go in this country, so what does it really matter? If you want more oomph, then there are an awful lot of bikes that have it, and can help you loose life or licence that much sooner, and probably not waste so much money or frustration along the way... b-u-t....
On a bike of that sort, of that age? Trying to speculate whether it may or may not be restricted from how fast it tops out, or its frame number, is pretty futile and least of worries, really.
It could have had any number of owners fiddling it it in the last twenty years, and who knows how close to 'standard' it may or may not be, or which 'standard' it likely doesn't comply with anyway!
And, as said.. its a 125, and as fast as any bike is legally allowed to go in this country, does it really matter much? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
 - Super Spammer
 Posted: 08:31 - 30 Apr 2019 Post subject: |
It's about right. I had 2, one was fully de-restricted and would read just over 100mph (so probably around 90-95mph) with my skinny ex on it, the other was restricted and would read late 70's with my lardy arse on it, so probably around 72mph. I found the restricted one was rich at the top end though and actually went quicker with the throttle backed off slightly.
There are loads of differing restrictions depending on country of origin. My full power one was Italian and had restriction to the exhaust, which I found with an inspection camera. I got around this with a full Arrow system and a rejet. The restricted one was a UK bike and had a restriction to electronically restrict the power valve. All you had to do to disable this was remove a little plastic jumper with a little handle, which connected 2 wires in the little wiring box by the left of the cylinder head. You'll see what I mean if you look.
There's a poster who comes on here sometimes called Alains, who is an expert on all things NSR125. He has a great document with all his findings and can probably tell you the country of origin from your chassis number. What language are the safety stickers on the tank in? Mine were obvious Italian on the full power one and clearly English on the restricted one. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| Ice Burger |
 Ice Burger Nova Slayer
 Posted: 10:34 - 30 Apr 2019 Post subject: |
Your bike probably hasn't been fully derestricted, if not derestricted at all.
I've got my own fully derestricted Nsr 125.
It does 110mph, for a full derestriction you must remove the air intake restrictors and remove the exhaust restrictor. If you want higher top end speed you have to change the front sprocket too.
Essentially a good derestriction involves more air and fuel coming into the engine - and bigger bang, plus the exhaust gasses being able to flow out easier.
With a proper tune you can see the likes of 30hp if the carb is set up properly.
here's a guide
https://www.nsr125.com/derestrict.htm
PM me if you want help. |
| Polarbear |
 Polarbear Super Spammer
| Ice Burger |
 Posted: 11:16 - 30 Apr 2019 Post subject: |
| MarJay |
 MarJay But it's British!
 Posted: 11:20 - 30 Apr 2019 Post subject: |
| Ice Burger wrote: | Your bike probably hasn't been fully derestricted, if not derestricted at all.
here's a guide
That's hilarious. You realise that this forum came from NSR125.com, right? Also you realise that we all know a derestricted NSR125 can't do 110mph? Maybe *indicated* possibly? But not a true 110mph!
Quite a lot of the original membership of this forum had NSRs. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Ice Burger |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
 - Super Spammer
| redeem ouzzer |
| flik9999 |
 - Super Spammer
 Posted: 15:40 - 30 Apr 2019 Post subject: |
| flik9999 wrote: | Would a conpression test reveal if its restricted or knackered? |
It's performing about what a restricted NSR125 would do. My restricted late 54 plated one (must have been in a shop for a while unregistered), had a completely brand new top end, from barrel to piston, rings, small end, PV seals, head and gasket. It had an immaculately cleaned carb and a standard pipe. After 300 miles running in, it did 78-80mph on the speedo, so a real 72bhp or there abouts.
Compression testing will just tell you the bore/rings/piston state and considering mine was brand new engine wise, I doubt your's is that bad at that speed. It's just restricted.
What mileage is it and when were the piston/rings small end last replaced if ever? If restricted, they can go for up to 20,000 miles plus a bit more if you like a risk, before something detonates and causes damage.
Unrestricted, and pushing twice the power, I'd be doing a top end refresh about every 10,000 miles for road use. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| flik9999 |
 - Super Spammer
| alains |
 alains World Chat Champion
 Posted: 15:27 - 01 May 2019 Post subject: |
go here https://www.bike-parts.fr/honda-moto/recherche_vehicule/chassis/ZDCJC22800F008387/FRANCE
all models before 1998 begin by ZDCJC228
then you will see that your bike is from italy 1997 with a sport production identification
it's most probably that they have change the licencied system has been replaced by the standart system . so control that your CDI & valves control are unrestricted models
the id is printed on the short side opposit of the looms
the controler should be TV78 , the CDI should be CI626 (not CI626A)
do a compression test (must be 125 PSI minimum) under 115 must have the top-end reset .
do everything and keep me posted ____________________ the worst day fishing is better than the best day working |
| stevo as b4 |
 Posted: 16:34 - 01 May 2019 Post subject: |
I agree with blue tbh!
I'm not necessarily say de-restrict a reliable good running bike that's just a daily rider to work or general A-B hack. Performance two strokes and daily use don't really sit together happily and who wants doubts about if it'll melt down on the way to work, or have to spend a weekend a month with the engine in bits and waiting for spares?
But back on topic, as Blue said take an Italian 125 sports bike around a decent technical track and it'll batter the shit out of a wobbly poorly braked and poorly sprung 250 four stroke twin that TM loves to mention.
Let's indulge him in his only as fast as a 250 mindset,
as there were some relatively fast 250's on top speed (not acceleration mind). A Honda VT250 could have up to 38-40bhp in the most powerful variants, and should in an ideal world do 100mph plus 5-6mph more regularly.
A Suzuki GSX250E was tested by MC mechanics at a best of 90/92 mph true. The Superdream, Z250, etc etc would all be about the same at best, and in the real world of hills and headwinds could be going a fair bit slower most of the time.
They were quite heavy too, as well as spindly chassis, crap brakes and old school tyres that you can't get in sticky push it to the limit compounds. Not only that you'll lose the centre stand if not both ends of the bike, long before a Mito etc has put a scratch on its hero blobs.
On a track there's no way an old 250 could beat a 125 cc sports bike it's physics! |
| flik9999 |
| flik9999 |
| flik9999 |
 - Super Spammer
| flik9999 |
| Fin |
 Fin World Chat Champion
 - Super Spammer
The last post was made 7 years, 61 days ago. Instead of replying here, would creating a new thread be more useful? |
