Yamaha Fazer 600 2002 Gearbox Help
10kovako
PostPosted: 23:25 - 07 May 2019    Post subject: Yamaha Fazer 600 2002 Gearbox Help Reply with quote
Hi,
I’m a bit stumped by an issue. This being that about 80% of the time to go upward from 2nd gear I have do repeatedly push the gear lever up until it goes in. Whilst I’m pushing it feels like I’m at the highest gear and it doesn’t allow me to go any higher. Can’t force it either. But after 5 tries it shifts. Revving it does nothing. It had this issue just with 3rd, but when I put a new clutch in the issue stopped altogether. 200 miles later, it’s started again. Also works immediately if I downshift then upshift again. Only from 2nd onwards but the worst is 2nd to 3rd.
What could it be? Hopefully doesn’t need a rebuild! Bike has 41,000 miles on it.
There is some free play in the gear lever shaft too don’t know if that is normal. (Side to side)
Let’s do this
jaffa90
PostPosted: 23:58 - 07 May 2019    Post subject: Reply with quote
A little free play side to side is ok, from what you say it`s a clutch problem so what oil is in the engine ? (hopefully it`s clutch friendly)???
10kovako
PostPosted: 09:33 - 08 May 2019    Post subject: Reply with quote
Thanks for the reply,
Yes it’s motorcycle oil, good stuff too. How could it be a clutch issue if it works when I go a gear down and then go up again?
Let’s do this
Hong Kong Phooey
PostPosted: 10:24 - 08 May 2019    Post subject: Reply with quote
If you tighten the clutch cable does that make any difference?
10kovako
PostPosted: 10:52 - 08 May 2019    Post subject: Reply with quote
There are 3 places I can adjust the clutch, by the handle, in the middle, and by the clutch. Which ones(s) should I do?
Let’s do this
chickenstrip
PostPosted: 12:48 - 08 May 2019    Post subject: Reply with quote
There was a gearbox gremlin Yamaha had on a few bikes of this age. The R6 I think had it the worst, but Thundercats were also prone, and maybe the Fazer too. Even the Fazer 1000 had it on occasion, until Yamaha apparently did a fix in about 2003.
I can't remember the exact nature of the problem, perhaps others could confirm? I seem to remember the problem actually did need a strip-down to correct.
pompousporcup...
PostPosted: 14:09 - 08 May 2019    Post subject: Reply with quote
the gear issue as far as i know on the older yamahas was that changing gear sloppily or at high revs from first to second would round the dogs on the second gear, meaning it would slip out of gear at high rpm.
R6s and Thundercats were apparently prone to it.. mine never did it but then i used to short shift into second and just rag second gear, rather than red lining first /shrug
the selector forks can also bend iirc making certain gears difficult to engage
PostPosted: 19:03 - 08 May 2019    Post subject: Reply with quote
When you say that the lever feels like you're in top gear, is it that it won't actually move or that it moves but has no weight to it when it does?
Kawasaki Jimbo
PostPosted: 19:53 - 08 May 2019    Post subject: Reply with quote
I have a similar problem on a similar era Yamaha, although it's atypically not affecting 2nd gear. At the moment I've shut it in the garage and am in denial but I strongly suspect the forum is right, it'll be an engine out job to replace a bent shift fork. Check your gear shift linkages first. Fingers crossed!
https://www.bikechatforums.com/viewtopic.php?p=4633104&highlight=#4633104
pompousporcup...
PostPosted: 09:41 - 09 May 2019    Post subject: Reply with quote
i love my r1 but admit the thing is a ticking time bomb Sad
R1stu
Shrek!
PostPosted: 10:04 - 09 May 2019    Post subject: Reply with quote
Could be the detent spring. Happend to my 02 r6. Its basiclyba spring inside the selector, that either comes off, or brakes. Gives all sorts of 2nd gear issue, has there us not the pressure to fully engage the shafts.
Simple job it seems, just needs selector cover off.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
10kovako
PostPosted: 00:29 - 11 May 2019    Post subject: Reply with quote
Sorry for the late reply! If it was a bent fork or something surely it wouldn’t go away for a little bit and come back?
Issue is just 2-3rd but is now creeping to 3-4. And when I pull the lever it feels like it’s in top gear, nowhere to go.
Also pops into neutral really easily. No clutch is needed.
Sometimes I have to do it twice till it goes in, sometimes just twice.
Getting carbs balanced on the 22nd so will ask him to take a look at it!
Let’s do this
10kovako
PostPosted: 00:30 - 11 May 2019    Post subject: Reply with quote
I’ve loosened it in fact, and that seems to help a bit.
Driving to the netherlands on the 28th so trying to get it sorted by then!
Let’s do this
10kovako
PostPosted: 00:36 - 11 May 2019    Post subject: Reply with quote
To clarify it won’t actually move
Let’s do this
PostPosted: 15:58 - 11 May 2019    Post subject: Reply with quote
My money is also on the star wheel or detent. I'd be having a good look inside the clutch cover. Get a gasket and have the cover off.
It's the bits in this video here. The star shaped wheel behind the part you see moving is held in place by the sprung-loaded arm (the detent arm):
https://youtu.be/aiTAyP2C6X0
trevor saxe-coburg-gotha
PostPosted: 16:26 - 11 May 2019    Post subject: Reply with quote
There is a similar problem on some Kawasakis and Suzukis. The cure is very simple. Re-grease the selector. In the photo below, you can see the foot peg and the selector that the toe hooks under or presses.
https://www.picclickimg.com/d/l400/pict/183354318983_/Kawasaki-ZX9R-1998-1999-C1-C2-NINJA-Left-Gear.jpg
The parts that need cleaning and greasing are those. The foot rest part fits into the toe part - and unless the "female" part of the latter and the "male" part of the former are cleaned and greased it's not uncommon for gear selection to become extremely problematic.
See if the Yamaha has a similar type of selector arrangement.
I have read of several people replacing entire gear boxes on Kawasakis only to encounter the exact same problem! Eventually they suss out that it's just for want of a bit of cleaning and greasing of a simple, basic part.
Last edited by trevor saxe-coburg-gotha on 17:35 - 12 May 2019; edited 1 time in total
10kovako
PostPosted: 10:43 - 12 May 2019    Post subject: Reply with quote
I’ll give the gear selector a good clean. Perhaps I should move the unit up/ down a notch or two?
Will ask my local garage to take a look at the spring see if anything is wrong with it!
Issue is still from 2-3rd. Still don’t understand why it went away and then came back!
Thank you though guys
Let’s do this
PostPosted: 17:33 - 12 May 2019    Post subject: Reply with quote
Soz - I didn't attach the photo. I'll edit my post now.
10kovako
PostPosted: 17:51 - 12 May 2019    Post subject: Reply with quote
Cleaned and re-greased all of the joints. Sadly that’s not the problem.
In general today it’s been doing it less often but does it from 3-4 gear now too. Bit stumped. Going to go into my local and ask on Tuesday what he thinks. If it’s an engine out job it’ll be cheaper to just buy a used engine.
Let’s do this
PostPosted: 21:09 - 12 May 2019    Post subject: Reply with quote
It's the same w/ my bike - zx9r. Apart from faring panels, ebay has loads of spares. Inc. engines.
The last post was made 7 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 108.52 Kb
