2012 honda cbf600sa sprocket /gearing change?
hondacbf600sa
PostPosted: 03:07 - 13 May 2019    Post subject: 2012 honda cbf600sa sprocket /gearing change? Reply with quote
hi guys,
I have a 2012 cbf600sa and want to change the rear sprocket to achieve better highway RPMs. I believe the stock setup is 16/42. I was thinking of going to a 39 on the rear. any input would be much appreciated.
Thank you.
weasley
PostPosted: 08:30 - 13 May 2019    Post subject: Reply with quote
Your engine speed will drop by about 8%, so if you were at 6,000 rpm before for a given speed, it will be just over 5,500 rpm after.
You may need a shorter chain if the adjustment available is not enough.
Your acceleration will not be as good, but your fuel economy should improve, unless you compensate for the drop in gearing by opening the throttle more everywhere.
What are you trying to achieve? Reduced noise? Reduced vibration? Improved economy?
Easy-X
PostPosted: 11:03 - 13 May 2019    Post subject: Reply with quote
Basically more teeth on the front sprocket or less on the back sprocket reduces torque but increases speed.
Are you unhappy with the top speed in top gear? Are you willing to loose some bottom end in the chase for speed?
I don't know the bike personally but it doesn't look like something that would have any problem getting to 70. I hope you're not aiming to go over that speed on a public highway Wink
PostPosted: 11:43 - 13 May 2019    Post subject: Reply with quote
Unless your bike is screaming itself to bits, there's really no point.
I sit at 70mph and its roughly 3000/3500 rpm, maybe a little less.
Considering its 13k rpm, 3k is fuck all. Laughing It doesn't really do much until 7k, so unless you are like... really revving its tits off, there shouldn't be a need to adjust.
Easy-X
PostPosted: 12:13 - 13 May 2019    Post subject: Reply with quote
That sounds about right. I'd have thought getting anal about sprockets is something more for a performance racer... or small 2-smoke bikes where it'd have much more impact.
hondacbf600sa
PostPosted: 16:13 - 13 May 2019    Post subject: Reply with quote
thanks guys. Ya basically i want to reduce noise and vibration at highway speed so its a bit more relaxing. With the current setup at 60mph im doing about 46-4700 rpm. I understand for 600cc this is probably normal. im ok with losing a bit of bottom end, the thing goes like hell once the revvs come up, and im just looking to tour anyway.
The last post was made 7 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 46.8 Kb
