Looking for Digital Speedometer to replace Honda CLR 125.
Derma
PostPosted: 17:32 - 13 May 2019    Post subject: Looking for Digital Speedometer to replace Honda CLR 125. Reply with quote
Hello, First time on this forum, desperately looking for some help. There are a few other things I need help with but I will keep it simple today.
Currently looking to replace the analog speedometer on my Honda CLR 125. I should mention that it does not have a tachometer.
Looking for a Digital speedometer with a Tachometer that connects to the spark plug. Would also like it to read the speed from the drive cable. I am willing to buy a converter if I can find one.
The Ideal one would look like the Daytona 8K RPM Gauge but with more information.
Maximum budget is £150, less would be ideal.
From what I have researched the maximum RPM is 8.25k
PostPosted: 17:44 - 13 May 2019    Post subject: Reply with quote
RPM on that is probably more 9-10k, Honda single.
You'll have a hard time replacing it, I'd honestly just use what its got, otherwise its going to cost the value of the bike to get it working. Thumbs Up
Easy-X
PostPosted: 17:46 - 13 May 2019    Post subject: Reply with quote
£150 budget? You must really love that bike Smile
Not quite sure why you want digital speed but running off the drive cable?!
Cheap digital speedos are usually driven by sensor spotting a permanent magnet on the wheel whizzing by and then calibrating for wheel size on the gauge set up.
These things start around £20 from China Smile
RhynoCZ
PostPosted: 20:11 - 13 May 2019    Post subject: Reply with quote
Have a look at ali-china-express. Otherwise I have put a bicycle computer on the MZ. It indicates speed up to 120 km/h, which is more than enough and it costed me next to nothing.
Easy-X
PostPosted: 20:18 - 13 May 2019    Post subject: Reply with quote
When I was mad enough to contemplate putting a hand-made bike through the MSVA I actually got a cheapo LCD unit:
Has a digital gauge for RPM up to 12K, fuel level, battery status, shift indicator, high beam and signals...
RPM pulse input, magnetic speed sensor.... cost about £25.
Derma
PostPosted: 22:21 - 14 May 2019    Post subject: Reply with quote
When I first got the bike, the drive cable unit was destroyed so ordered replacement part from Germany and want to get the use out of it.
Also, I think the bike would look weird with the unit in place but not cable coming out.
And I do love the bike, it might be a hunk of junk, but I have had a lot of fun repairing it and I have a lot of plans for it. I am tempted to keep the original speedometer but it would be useful to know the RPM to set the idle screw etc.
Currently still deciding and thinking of options. Need to replace the headlamp unit first as the previous owner put a dirtbike style one on which is a minor failure on the MOT but we did a little bit of jerry-rigging to get it in compliance. Then I need to sort the carb out as it leaked loads of fuel, its been running fine for months but now its playing up.
The last post was made 7 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 48.81 Kb
