| rosel9009 |
 rosel9009 L Plate Warrior
| MarJay |
 MarJay But it's British!
| rosel9009 |
| blurredman |
 Posted: 14:56 - 13 May 2019 Post subject: |
Standing voltage of the battery
VS
Voltage readout of the engine running/lamps on. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| jaffa90 |
 jaffa90 World Chat Champion
| rosel9009 |
| Easy-X |
 Easy-X Super Spammer
| P.addy |
 P.addy Red Rocket
| ThatDippyTwat |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 20:21 - 13 May 2019 Post subject: |
If you get no DC voltage on the battery while the engine is running, don't forget to check for AC voltage between the three yellow wires coming out of the stator of your charging system, before you run and replace the rectifier/regulator unit. You should see anything between 30V and 60V while the engine is running. If you can't see any AC voltage between any of the wires, the stator is dead. If you can see some AC voltage between at least one combination of three wires, on of the widninds is dead and the rest is going to die soon enough.
Burned stators are not uncommon. Manytimes caused by dirty connections, that put more strain on the windings of the stator.
EDIT: I would guess the stators is located under the left hand side engine cover.
Yep, left hand side.
https://partsdepot.cz/picown2/417338.png ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
The last post was made 7 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
