Bandit 600 Mk2 speedo issue
wraith.horth
PostPosted: 21:04 - 16 May 2019    Post subject: Bandit 600 Mk2 speedo issue Reply with quote
This has most probably been covered but searches are not showing up and I am on a busy night shift. So here it goes
I have a standard set of gauges. Needle and digital ODO etc. It stopped working and works from time to time. I found the fuse had blown and replaced it. It worked for a test ride. Then went to start again and nothing. Occasionally it bounces the needles... sometimes even without the ignition switched on. Cant see and dry solder joints on the speedo PCB and no burnt tracks. Correct voltages going in where they should. What am I missing?
Nobby the Bastard
Harley Gaydar
PostPosted: 22:33 - 16 May 2019    Post subject: Re: Bandit 600 Mk2 speedo issue Reply with quote
You dodn't put the fuse in properly or the fuse is crap.
Replace the fuse.
A bad earth would cause it to blow the fuse all the time, bad power (i.e;. fuse side) wouldn't.
Triumph Sprint ST 1050
The last post was made 7 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 31.71 Kb
