Kwak GT550 engine
Baffler186
PostPosted: 11:00 - 17 May 2019    Post subject: Kwak GT550 engine Reply with quote
I'm about to take my engine apart before I rebuild the entire bike. It had 41000 on the clock and has been standing for 17 years. The engine turns over freely. Is there anything that should definitely be changed given it's mileage and 17 years outside?
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
pepperami
PostPosted: 12:01 - 17 May 2019    Post subject: Reply with quote
When you say take it apart, how much apart do you mean?
Top end only ?
Fully apart?
If fully apart , you might as well put new bearings in it, and new seals as well.
Seals can go hard and fail after a long period of standing.
Robby
Dirty Old Man
PostPosted: 13:11 - 17 May 2019    Post subject: Reply with quote
The question suggests a lack of knowledge.
You're either rebuilding the engine to fix a problem, or to make sure everything is within tolerance so it will last another 40k.
You won't know what needs replacing until you have the engine stripped and various wear items measured and checked against the workshop manual.
If there is nothing wrong with it, don't pull it apart. You'll cause more damage by disturbing a good engine - usually through mistakes in the strip and reassembly, like not getting gasket faces clean enough or using too much gasket goop and blocking an oilway.
PostPosted: 14:58 - 17 May 2019    Post subject: Reply with quote
What's a kawasaki GT500?
Presumably you either have a Kawasaki GT550 or a Suzuki GT500?
Bhud
PostPosted: 18:50 - 17 May 2019    Post subject: Reply with quote
If it ain't broken, don't fix it.
I have one or 2 incomplete old bike engines laying around for when I want to tinker. I wouldn't pull apart an engine from a working bike without very good reason. There's a lot that can go wrong, and even if nothing goes wrong, it can get expensive.
Shaft
PostPosted: 22:55 - 17 May 2019    Post subject: Reply with quote
According to the Show & Tell post, it's a GT550.
Which leads me to agree with others, don't mess with things until you know they're broken, those motors are bullet proof and it's just about run in at 40K, unless you have more background on why it was laid up.
You've said it turns freely (presumably you've got it on the mainstand and spun the back wheel with it in gear) so if you're happy that it's made a few revolutions, check it's got enough oil in it (that doesn't smell of petrol) fill it with fresh fuel, connect it to a big battery and fire the bugger up.
It's not going to start first time, which will give the oil pressure time to build up, so just keep spinning the thing until it either runs, or flattens the massive, fully charged car battery you've got it connected to.
If the former happens, providing it doesn't sound a bucket of bolts (keeping in mind that era of Kwak motor isn't the quietest) then polish your cases and move on.
If it won't run, then go investigate why.
kgm
PostPosted: 23:39 - 17 May 2019    Post subject: Reply with quote
+1, basically. Don't be surprised if they're some little oil leaks though and I'd check the valve clearances and chuck in new oil and filters first though.
PostPosted: 09:23 - 18 May 2019    Post subject: Reply with quote
Another for not pulling apart unless it's buggered.
Even if you don't damage anything, seals and gaskets aren't going to be cheap.
Just not worth it unless you are doing it to learn about stripping engines and it doesn't matter when you screw it up.
Triumph Trophy Launch Edition
.Chris.
PostPosted: 13:21 - 19 May 2019    Post subject: Reply with quote
Presumably you're talking about a GT550?
I understand the temptation but as others have said above, it's probably better to try and get the engine running before deciding whether to strip it down. Ideally, if it runs you'd take the bike for a ride in order to assess the state of the gearbox, and if any issues (like a smoky exhaust) emerge when the engine gets hot. Obviously this is not possible if the rest of the bike is in bits, unless you leave the engine until last.
At the very least make sure you do a compression test, and check the valve clearances before you strip the engine down. You need to be able to rotate the cams in order to check them, which you don't be able to do with the head off. Adjustment of the clearances is by shim under bucket, and requires the camshafts to be removed in order to adjust them, so it makes sense to set them correctly if you're taking the head off for any reason.
If you do decide to strip the engine and split the cases (which you should only do if you're absolutely sure what you're doing), make sure you replace the cam chain and primary drive chain. Due in part to having no effective tensioner, the latter is a known weak spot on these engines - not in terms of the engine blowing up, but they get loose and cause a rather unpleasant rattling sound, especially at idle. Oddly the primary chain is quite a bit cheaper bought from Kawasaki (~£45) than the aftermarket ones I've seen (~£120). The same goes for the cam chain. I don't know if there's a quality difference.
Chris
1985 Kawasaki Z550F
ZRX61
Victor Meldrew
PostPosted: 05:47 - 21 May 2019    Post subject: Reply with quote
First step:
Pull the plugs, put a squirt of MMO in each pot, replace plugs & walk away for the week.
They're not one night stands, they're auditions.
trevor saxe-coburg-gotha
PostPosted: 07:03 - 21 May 2019    Post subject: Reply with quote
They usually do, tbf. Mr. Green
Baffler186
PostPosted: 07:50 - 21 May 2019    Post subject: Reply with quote
Typo - Kwak GT550
Baffler186
PostPosted: 07:51 - 21 May 2019    Post subject: Reply with quote
mpd72 wrote:
It certainly does when the OP doesn't even know what model his bike is.
WTF is a Kawasaki GT500, a scaled down version of the GT550?
It was a typo, don't be alarmed. GT550
PostPosted: 08:04 - 21 May 2019    Post subject: Reply with quote
Engines last far longer than suspension components, bushes, bearings, linkages, brake parts, tyres, seats, grips, peg rubbers... I could go on forever.
Chassis first, then engine.
Baffler186
PostPosted: 08:53 - 21 May 2019    Post subject: Reply with quote
Yes that's right. My first mistake was stripping it all down without getting the engine running first, but I didn't want to start it without inspecting it first. It has been stood for years. So I plan to take everything apart, see if the gearbox is ok, replace the head gasket (there looks to be a dark oil patch in one place). Then try to start it after cleaning and rebuilding the carbs and getting new coils
bikenut
PostPosted: 09:55 - 22 May 2019    Post subject: gt550 Reply with quote
gt550 stood for 17 years.......
get a manual and you know of cmsnl for the exploded views.
study the exploded views.........
How far down have you stripped the engine and i hope you have been careful about the buckets and shims.
Any stuck valves and how is the clutch basket ?
How is the transmission drive chain and cam chain and rubbers ?
some special tools needed and be carefully with the flywheel and clutch basket centre nut.
Sometimes its prudent to slacken some engine nuts/bolts with the engine in the frame,using the back brake, which is why you enquired probably.
Oil leak, oil seal deformed??
nuts about bikes
redeem ouzzer
PostPosted: 10:28 - 22 May 2019    Post subject: Re: gt550 Reply with quote
I am going to start negging every single post where you mention CSMNL.
Be a REAL MAN!
Teflon-Mike
tl;dr
PostPosted: 10:48 - 22 May 2019    Post subject: Reply with quote
Didn't the GT550 have air-shocks on the back, with a notoriety for deflating? Or was that just the 750?
ISTR that it was aggravated by the Schrodinger valve and folk pumping them up to tyre pressure and more, like 30psi, when they were only supposed to take maybe 3 or 6psi...
I also STR that as a favoured dispatch-hack, there was an infamous bodge to the shocks that involved a push bike inner tube and or repair kit...
Shaft crown-wheels, I also seem to recall were something of a pain, especially on high-mile London dispatchers, where up-down the box riding the whole time, didn't so much see the pinion's prematurely wear, but the shaft bearings and knuckle joints, which if not tackled properly, 'then' would knock out the pinion.
Ergo... on a GT550... I would suspect whatever the mileage, and 40K would seem suspiciously low for that model, personally, I would be a LOT more concerned about 'other-stuff' than the motor, which as mentioned tended to be pretty bullet-proof. Given the age and duration of deraliction, I would have some concern over anything rubber, and be watching for oil-leaks every-where... but, unless it was leaking like an incontinent old dog, or making more smoke than an 80 a day inmate in the care home; I would be inclined to leave the motor as much alone as I could, for the time being.
PostPosted: 16:35 - 23 May 2019    Post subject: Reply with quote
The biggest issue will be the electonic dash. It will also have rusted out the tank behind the two plastic kawasaki badges.
But OP is no longer reading.
Bhud
PostPosted: 16:54 - 23 May 2019    Post subject: Reply with quote
Oh, he's reading all right.
I suggest joining kzrider.com, reading everything they've got, introducing yourself and asking lots of questions. That's what I did when I got mine.
bikenut
PostPosted: 09:56 - 24 May 2019    Post subject: exploded views Reply with quote
why??
A wonderful free resource, not everyone knows about it.
It will even show you whats involved replacing the engine output shaft, if you dont already know of course.
Spread the gospel, get prices and part number etc. etc. etc....go do gods work for me, there's a good chap.
No i don't work for cmsnl but really appreciate the exploded views and even get parts from them from time to time.
Long live cmsnl.
There are other sources of info as well but cmsnl is usually my fiorst port of call, for info etc.etc.etc.. its up to you......
nuts about bikes
The last post was made 6 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 121.32 Kb
