EFI to Carb conversion
Easy-X
PostPosted: 00:49 - 18 May 2019    Post subject: EFI to Carb conversion Reply with quote
More of a thought-experiment than anything else...
Plenty of bikes like mine were originally carburettor-based and later got swapped to EFI. As EFI is a "black-box" system which is effectively unalterable I was just wondering the advantages/disadvantages of taking it back to old-skool stylee?
I would imagine one would at least need a carb, CDI unit and possibly a new coil. Plenty of rewiring ofc but nothing too tricky if the "original" non-efi wiring diagrams are available. And obviously you have the joys of pissing about with jets and mixture screws.
After that, what would happen about the emissions? I don't see anything in the MoT manual apart from exhaust noise. Cheating the London ultra low emission zone might also be a concern.
And finally, would it actually make any tangible difference? Certainly HD owners have previously been spitting chips over EFI so it must be worth doing for some engines.
temeluchus
PostPosted: 05:02 - 18 May 2019    Post subject: Reply with quote
Some motors might not have crank sensors, so that might make fitting an older style standalone ignition a bit fun.
Wiring up a TCI style electronic ignition is trivial, and shouldn't present a problem for anyone who understands electrics.
The inlet manifold(s) might present the greatest challenge tbh.
stevo as b4
PostPosted: 07:41 - 18 May 2019    Post subject: Reply with quote
Obviously not your 125 are you looking at messing with again?
Personally if I had an EFI engine and didn't need to have a carb for weight or waterproofing reasons then I'd always look to keeping the EFI system and making it reliable and rideable if not already.
For an out and out race engine or anything with forced induction, particularly if I was attempting to run it on modern shit pump fuel, I'd not consider anything other than EFI personally.
Oh and why do you always keep banging on about emissions? Unless you live in the ULEZ and have to ride 2007> bikes, then emissions are a misnomer for bikes.
Saying that though, emissions when looking at say Euro 7> and manufacturers needing to deliver better mpg and maintain good performance, is a set of hurdles they will really struggle with. Its a triangle that you can only ever get close to one corner at a time, at the expense of the other points.
Currently they are even sacrificing engine life and repairability to meet emissions/mpg/ performance.
Hetzer
PostPosted: 08:29 - 18 May 2019    Post subject: Reply with quote
An EFI is eminently "alterable" with a PC or similar.
Easy-X
PostPosted: 11:04 - 18 May 2019    Post subject: Reply with quote
No, not something I was aiming to do on my bike! Someone said something on another thread that set off a chain of inquiry. The mad thought was "10 gazillion articles on carb to efi... I wonder if anyone's done it the other way?"
Crank sensors, yes... not thought of that. Inlet manifold... I would guess if the design was originally carb but converted that wouldn't be a problem (if old parts still available) but a freshly designed EFI bike would be a challenge I guess.
With regards to emissions I care only slightly about the environment as in, why not if you're not sacrificing much but I'll have a read up on Euro7 specs. I live just on the edge of London and my previous "eco as in free congestion charge" Euro 4 ultra-low-emissions diesel that we were all told to buy is now the bad man so not only did I have to start paying congestion charge a couple of years ago I now also have to pay another £12.50 to enter the ULEZ with it Sad
I pretty much bought a motorbike on a whim and now it's saving me £22.50 + parking every trip into town! Funny how life turns out Smile
PostPosted: 11:58 - 18 May 2019    Post subject: Reply with quote
Look. A kit to replace the EFI system on your Enfield Bullet with a Mk 1 concentric Amal carburettor.
https://accessories.hitchcocksmotorcycles.com/accessory-shop/amal-carburettor-conversion-kit-efi-models/22197
Really.
In fairness, Enfield owners DO like to piss around with their exhausts, air filters, cams and compression ratios and the carbs are very well understood by now. They could also just plug in a dynatune box, but where's the fin in that.
One thing most people don't realise is most FI bikes have a fuel pump in the tank which may well need to be replaced with a tap (and definately if you're relying on an Amal needle valve to stop petrol pissing everywhere!).
Easy-X
PostPosted: 16:06 - 18 May 2019    Post subject: Reply with quote
Really.
I read that as Anal...
Anyhoo, I suppose we're getting to the point where carb and EFI have diverged so much they're practically separate species.
Sad that treehuggers are killing off such classic tech. As a programmer I think I can fairly say, with some authority that I fecking hate computers and the all unnecessary automation. 9/10 times its a solution looking for a problem.
stevo as b4
PostPosted: 16:59 - 18 May 2019    Post subject: Reply with quote
I'm no tech head, but on a water cooled four stroke engine, emissions aside you can with the right design, parts, electronics and experience make an engine that runs better and stronger over a wider percentage of the rpm/load range with EFI.
You'd have more area under the curve than with the most expensive race carb money can buy, but only if it's done right without compromise. EFI sometimes gets a bad press for ruining bikes or making them less rideable. But it's unfair as they are injecting for reasons like noise and emissions and mpg. Put EFI on a level playing field with carbs (maximum power everywhere) then all you have against EFI left is weight and complexity. Cost isn't even far apart now.
The only place I don't like to see EFI is on two strokes, as firstly it's pointless trying to clean up dirty stinking oil burning obsolete engines, and secondly I've never seen EFI make one run better. Things like overrun fuel cut of isn't friendly to two stroke engines and you therefore can't apply it in the same way. You also don't get time at high revs in the operating cycle for EFI to work, so a wet manifold (carb) is the way to go.
Easy-X
PostPosted: 23:15 - 18 May 2019    Post subject: Reply with quote
Yes, I mentioned something about 2 strokes and Euro 4 a while back. It seems, for top models, they can do a variant of EFI that is at least "okay" versus the carb version. But when you study all the things they needed to do to get it to work you pretty much come up with something of comparable complexity to a 4 stroke engine and then... what's the point?
PostPosted: 23:40 - 18 May 2019    Post subject: Reply with quote
Nah.
The ONY way to go for the future of 2t motors is EFI with forced induction and no fuel circulating around the crank. There is no need for strokers to burn oil.
However, there is no willingness to invest in the R&D to make this possible. The industry decided to shitcan strokers when they stopped using them in moto GP bikes.
Amen. For example why does my fucking central heating boiler have a bastarding computer in it? It has five input wires and three things to do. It can have the burner on or off and one or both pumps running. yes, there are a whole series of "AND" logic safety systems to stop it exploding but a simple relay would do it. And my washing machine.
Even a simple electronic project these days, they reach straight for a programmable system. Use an arduino where a 555chip and a handful of transistors would do.
Easy-X
PostPosted: 23:53 - 18 May 2019    Post subject: Reply with quote
OMG... now you're talking my language! Did you ever get one of those booklets from, was it Tandy/Radio Shack?, on the 555 and all the pages looked like graph paper?
The things you could do with a monostable multivibrator... aye them were the days... when I were a lad...
The last post was made 7 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 75.86 Kb
