Honda NSR 125 jumps up to max rpm in neutral
pwb
PostPosted: 19:06 - 18 May 2019    Post subject: Honda NSR 125 jumps up to max rpm in neutral Reply with quote
Hi, my daughter has a NSR 125 2001, Its okey when she drive it, but at neutral or when holding the clutch in the engeine can jump up to 11-12.000 rpm. This also happens when starting it and when the choke is turned off then the enigen very often jumps up tp 11-12.000 rpm. Has to turn it off or put it in gear and realse clutch to have it come down. We have cleaned the carburetor and there isnt any leak in the manifold. The gas wire is ok and the carburetor piston is all the way down. How is it possible to jump up to max rpm when the airflow is close? It dosent do it when there is load on the engine, only when its runnign in neutral or with the clutch in.
pwb
PostPosted: 06:28 - 19 May 2019    Post subject: Reply with quote
No, it doesn't make any sense, i have started it and the same thing happens, i have taken of the air filter to see the caburetor piston and its closed. When chock is on it dont rev to max rpm, but if i start it, let the chock on for some time, take off the chock and give it a litle throttle and then reaelse the throttle and the carburetor piston is closed it could go 2-3 sec and it could rev up to 11-12.000 rpm. Sometime its hard to stop with the killswitch when this happen, but the ignition always work, the killswitch allways work, but in 50% of the high rpm trouble it doesn't. I have coated the manifold with some rubber since it is old and have som cracks on it, but it wasnt cracks all the way through, but i sealed it with some liquid rubber just to be sure. But i will try to spray some carburetor cleaner arround it later today to check.
Hetzer
PostPosted: 07:37 - 19 May 2019    Post subject: Reply with quote
Try a new spark plug.
Tankie
PostPosted: 08:39 - 19 May 2019    Post subject: Reply with quote
initial thought says "air leak"
1198
PostPosted: 08:43 - 19 May 2019    Post subject: Reply with quote
Then a new rear tyre if the new spark plug proves pointless?
Hetzer
PostPosted: 08:51 - 19 May 2019    Post subject: Reply with quote
I had a bike that did the exact same thing, it was caused by deposits on the plug glowing red hot and igniting the fuel-mix even with the ignition turned off. I have no idea how it caused enough mix to be drawn into the cylinder with the throttle closed but it happened. A new plug fixed it.
Easy-X
PostPosted: 09:27 - 19 May 2019    Post subject: Reply with quote
Given how easy it is to eyeball a spark plug gotta be worth a look!
If I had the time I'd be looking at: throttle, throttle cable & carb. Probably even go as far as stripping the carb down and really giving it a good clean (also might notice anything cream-crackered on carb if lucky.)
PostPosted: 09:32 - 19 May 2019    Post subject: Reply with quote
More info required but it does indeed point to an air leak or split intake rubber. If (as seems to be the suggestion) it's randon and not every time then suspect an air leak between the carb and cylinder.
Could also be a loose jet in the carb.
First, check the carb is not loose on the rubber and then check the rubber is not split. After that, pull the carb and get it fully apart.
pwb
PostPosted: 13:02 - 19 May 2019    Post subject: Reply with quote
Removed airfilter, the carburetor piston is at bottom. Started it up with chock on, took off chock, it runs okey for 1 min, gave it a litle throttle then it goes crazy, jumps up to 12.000 rpm. Ingition off, killswitch off, still running, carburetor piston is at bottom, put my hand in front to chocke the air, didnt feel any vaccume but thats correct since the pistion is at bottom, took 2-3 sec before the egine shut down. My hand was wet with gas after holding it tight in front of the carburetor but thats normal i think?
pwb
PostPosted: 13:27 - 19 May 2019    Post subject: Reply with quote
Tried to spray startgas all over between carb and cylinder, didnt do anything with the rpm.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:08 - 19 May 2019    Post subject: Reply with quote
Your throttle is stuck fractionally open. The most likely cause is the cable is over adjusted.
Triumph Sprint ST 1050
PostPosted: 17:18 - 19 May 2019    Post subject: Reply with quote
Could be any of a number of things. No1 cause is something sticking on the throttle controls. Remove the throttle cable from the throttle tube. Does the throttle spin freely on the bar or is it a little stiff to turn. If it doesn't spin totally free clean it all up with some sort of degreaser and dry it out then re-assemble with NO LUBE WHATSOEVER. Should now spin like a top.
If the tube is free tu turn push and pull the cable in the sheath. It should feel light as a feather, if there's any drag remove it completely and clean the first few inches each end.
If neither the cable nor the throttle tube on the bar were sticky check the throttle slide is free and has no burrs. Someone might have put the slide in backwards and picked up a small burr on the slide where it hits the stop screw. This can cause a burr which can stick even once it's put in the right way round again.
If none of the above shows a problem strip the carb and look inside the bowl.
pwb
PostPosted: 19:18 - 19 May 2019    Post subject: Reply with quote
This is how the carb looks like when this happens.
alains
PostPosted: 08:27 - 25 May 2019    Post subject: Reply with quote
very often when the cable begins to split it does that
replace the cable (a special with a splitter around the oil pump)
ref : 17910 KBS 900 £28,46 at david silver spares
The last post was made 6 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 108.62 Kb
