New biker with oil level issue
Denial
PostPosted: 05:49 - 25 May 2019    Post subject: New biker with oil level issue Reply with quote
Hi guys, thanks for the add.
Total newbie question about an oil level issue.
I have a Sym wolf 125 which suits my needs fine. It has an oil light that has started to flash. So I checked the level in the oil level window. Here is where I have got confused a bit.
I have tried several things. I have put oil in (500ml to see if there was a difference, the light stays on). I have siphoned oil out (thinking I had over filled it. The light stays on). The level just doesn't change in the oil window either.
A. On centre stand it shows as full, covering the whole window
B. On side stand, it shows as completely empty
C. On level ground (with someone helping to hold the bike) it is full, covering the window
Either way, the light flashes. There are no leaks, just a blinking light and a full/empty window viewer!
Anybody got some advice to get me back on the road?
Your patience with a novice is very much appreciated. Mr. Green
temeluchus
PostPosted: 06:35 - 25 May 2019    Post subject: Reply with quote
Typically you want the oil level to be half way up the glass or thereabouts. Often there will be level markings on the cases or on the glass itself, but halfway is a safe bet otherwise.
Is the bike running ok? No loud knocking or banging noises or clouds of smoke out of the exhaust? No oil leaks?
You might just have a loose wire to the oil pressure sensor or a faulty sensor.
Denial
PostPosted: 07:32 - 25 May 2019    Post subject: Reply with quote
Thanks for the quick reply.
No knocking or smoke. Hope it is just a sensor thing. Assume that means a trip to a garage to fix.
But now I have to sort the oil level out in the meantime. Am i right in thinking it should be on the centre stand and i need to drain off enough to bring it in between the lines? Was unsure because it is over full when level but completely empty on the side stand. Could not get clarification online and the manual is useless.
doggone
PostPosted: 07:49 - 25 May 2019    Post subject: Reply with quote
When you say flash is it steady on and off like an indicator?
Or flickering as if it wasn't connecting very well.
You might be able to find the sensor, they are sometimes located poorly and get road debris over the connector causing half-on bulb effect, just cleaning it up might fix that.
It's there to indicate low oil pressure rather than low oil directly.
If it comes on and stays on don't ride it, if oil pump has failed the engine will seize in minutes.
Flickering on and off is much more likely to be a sensor fault assuming the level is adequate.
Barely at the window would still be 'adequate' there a decent volume below that the pump can draw from.
Denial
PostPosted: 08:05 - 25 May 2019    Post subject: Reply with quote
It is a steady on and off. So if oil pressure issue, is that a simple fix?
Will start to siphon out the oil I put in. Cheers for the reply.
PostPosted: 08:16 - 25 May 2019    Post subject: Reply with quote
Oil pressure switches are prone to failure, in exactly the way you describe. They are easy to change so I'd get a new one and fit it first.
If you had a light which was flashing on idle only AND it was coupled with any odd noises like a hollow-sounding knock or rattle then that would indicate an engine problem causing low oil pressure but from what you say it does point to a dodgy oil switch.
PostPosted: 10:22 - 25 May 2019    Post subject: Reply with quote
This manual
https://www.manualslib.com/products/Sym-Wolf-125-5904199.html
says it has a dipstick but I suppose a later model might have been changed to a window.
It also says check on the centre stand so \i would go along with that. Mid window oil level while on the centre stand. Thumbs Up
Triumph Trophy Launch Edition
Riejufixing
PostPosted: 10:25 - 25 May 2019    Post subject: Reply with quote
Just in case, I would not be tempted to use your bike until you know that it's OK.
Easy-X
PostPosted: 17:25 - 25 May 2019    Post subject: Reply with quote
Unless stated otherwise oil level should be checked on level ground with the centre stand. Most windows have max and min lines. Get the oil to below the max line. (My engine/gearbox seems to run much better with the oil closer to the max line than the min line.)
As well as that your oil cap might incorporate a dipstick too. Take it out, clean replace, take it out again... should reflect what you see in the window.
Flashing would seem to indicate a fault rather than actual low oil pressure. Swap sensor, check connectors and wiring condition.
Denial
PostPosted: 18:27 - 25 May 2019    Post subject: Reply with quote
Thanks for all the replies.
One final check. Should the pilot be between the lines at cold temperature or is that after running the engine for a few minutes?
Islander
PostPosted: 19:07 - 25 May 2019    Post subject: Reply with quote
When the engine is off and the oil has settled. Thumbs Up
chickenstrip
PostPosted: 19:42 - 25 May 2019    Post subject: Reply with quote
Denial...
Is dat de big river in Egypt?
It's ok, you'll get used to me Shifty
PostPosted: 20:19 - 25 May 2019    Post subject: Reply with quote
chickenstrip YFPOS wrote:
Denial...
Liberated.
chickenstrip
PostPosted: 22:06 - 25 May 2019    Post subject: Reply with quote
The silence of confusion...
PostPosted: 22:50 - 25 May 2019    Post subject: Reply with quote
confusion...
https://www.youtube.com/watch?v=WQZiMINd8YQ
Sister Sledge
PostPosted: 06:36 - 26 May 2019    Post subject: Reply with quote
confusion...
I could do sexual things with that. The video thing not chickenstrip. Unless they want to aswell?
CCM 404 DS
chickenstrip
PostPosted: 12:14 - 26 May 2019    Post subject: Reply with quote
Sister Sledge wrote:
We are not amused.
Islander
PostPosted: 13:04 - 26 May 2019    Post subject: Reply with quote
We are aroused.
FTFY Razz Laughing
chickenstrip
PostPosted: 13:11 - 26 May 2019    Post subject: Reply with quote
Islander wrote:
chickenstrip DID NOT wrote:
We are aroused.
FTFY Razz Laughing
Oil level dammit, oil level!
stevo as b4
PostPosted: 16:47 - 26 May 2019    Post subject: Reply with quote
Drain the lot out into a measuring jug and see how much comes out? Then look in the manual for the right amount of clean fresh oil to fill it with. This will also tell you if you had under or overfilled it before.
While your at it you might as well clean or replace the oil filter and any applicable filter housing gasket etc.
Then see if the oil light goes off with the engine running.
Don't place much significance on the oil level window. They are notoriously inaccurate at times and often get misty or dirty and thus become hard or impossible to read. Therefore I'd be draining and measuring the oil regularly and filling it with the known quantity of new oil, and not paying any attention to the silly little window. If you do an initial 500mile oil change you'll be able to gauge oil consumption in case it needs interim top ups too.
Denial
PostPosted: 18:32 - 27 May 2019    Post subject: Reply with quote
Awesome responses guys. I will get right on with it and let you know how it goes.Thanks for all your help. Laughing
The last post was made 6 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 116.89 Kb
