ER5 rec/reg advice please
Ebbs73
PostPosted: 15:56 - 27 May 2019    Post subject: ER5 rec/reg advice please Reply with quote
Hello people
I'd just like a few pointers from you .
I have a Kawasaki er5 , I use it for all my dirty hardworking tours , 3 elephant rally's , dragon , and Stella alpina rally .
She works hard and has always been very good to me .
After this years elephant she needed love , I've gone all the normals , chain , sprockets , bearings and seals , fork seals etc .
I noticed the rev counter die as have read it's a sign of the reg/rec , my battery has gone dead a few times so I bought a MOSFET er5 , straight plug in .
All swooped over , easy .
After a run yesterday the battery was flat and I had to bump her , got home and started testing , I'm only getting 11.8 volts ish even when revving it , its the same voltage with the rec disconnected so I take it it's the battery giving that after a charge ,
I've got the book so I've tested the stator and I have 60 v on each yellow , tested the old rec and the readings are about right , so was it faulty ??
I haven't got the specs for the new one so I've emailed the company for them .
The only thing I'm worried about , I had the new one plugged in trying to test it hanging from the bike and after 2/3 mins running Christ it got hot .
Is this a sign it's faulty ?
Any ideas or where I'm going wrong would be appreciated
Thank you
Chris
Ebbs73
PostPosted: 16:18 - 27 May 2019    Post subject: Reply with quote
Just to say , I did search and there's loads of info on it but not regarding the heat .
Thanks
ThatDippyTwat
PostPosted: 16:27 - 27 May 2019    Post subject: Reply with quote
They're meant to get hot, and they need to use the frame as a heatsink.
By hanging it from the bike, you lose the ability to rid it of heat by conducting it. For best results, mount to frame with a *thin* smear of heatsink compound.
Ebbs73
PostPosted: 18:04 - 27 May 2019    Post subject: Reply with quote
Yeah that makes sense , I took it off just to aid testing .
Either one doesn't have an output at all .
Im losing the will to live now ,
Thank you
andy_uk
PostPosted: 18:47 - 27 May 2019    Post subject: Reply with quote
Here's a pretty good (in my opinion) reg/rec testing flow-chart.
Hope it helps.
Ebbs73
PostPosted: 18:59 - 27 May 2019    Post subject: Reply with quote
Thank you , I'll have a nose .
I've followed the ones in the Haynes manual , not sure if it's me or the book that's lost !
Robby
Dirty Old Man
PostPosted: 15:15 - 28 May 2019    Post subject: Reply with quote
Who did you get the reg/rec from? If it was suspiciously cheap, it may not be a MOSFET.
The symptoms sound like classic reg/rec failure. First time I've heard of a MOSFET failing, hence the interest in its origins.
PostPosted: 19:32 - 28 May 2019    Post subject: Reply with quote
Check under the LHS engine cover early doors. Just in case the alternator rotor has bombed. I'm not sure about yours but other EX500 variants had a habit of dropping poorly glued magnets off at high rpm. Mayhem ensues.
Ebbs73
PostPosted: 23:17 - 28 May 2019    Post subject: Reply with quote
I bought the rec/reg direct from them so all good .
I've put it back on with some heat paste , redone the connector , brand new battery ...
Still not charging , cleaned all the connectors and grease them .
I have the corrected voltage going in on all 3 yellows from the stator , the reg gets hot so I guess it's doing something .
Would I get 13.8 v ish on the red wire from the reg , what does the white do ?
I've been looking at the wiring diagram but it's starting to blur ?
I'll nose at the dropped magnet .
Thanks for the help and susgestions .
Chris
Ebbs73
PostPosted: 18:45 - 29 May 2019    Post subject: Reply with quote
May I pick your brains again .
I've been over every connector and cleaned them , I appear to be getting a charge but .
Form he diagram I have 2 wires the wrong way round and it charges ( white and brown )
I'm think the brown is the 12 v form the ignition and the white the charge .
If I have them as the book it doesn't charge , if I put them the other way round it charges but when you turn the key off it keeps running !
It will turn off with the main switch .
I'm losing the will to live .
Thank you
The last post was made 6 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 64.21 Kb
