| Olly666 |
 Olly666 L Plate Warrior
 Posted: 19:03 - 28 May 2019 Post subject: 2005 YN50 Neo's digital speedo not working |
2005 YN50 Neo's digital speedo not working, any ideas ? Any common faults ?  |
| Easy-X |
 Easy-X Super Spammer
 Posted: 19:41 - 28 May 2019 Post subject: |
I would imagine it's cable driven rather than magnet + sensor.
If it was me I'd get it on the centre stand and unbolt the covers around the handlebars so you can get to the back of the speedo. At this point you might get lucky and find the speedo cable has just got loose and just needs screwing back in.
If not, unscrew it from the back of the speedo... top tip: stick a cable tie around the speedo cable just under the collar you're about to unscrew otherwise it'll just drop down the cable and you'll be fishing around for it like an idiot. Don't ask me how I know
The end of the actual cable in the sleeve will be a square shape. Spin the front wheel around and see if this square end rotates. If it does the the speedo is knackered. If it doesn't then the wheel end is knackered.
If it's the wheel side you might want to examine it before buying a new one. Take off the front brake, wheel and then you should see the only cable left being the speedo one. Carefully take this off the axle as some bits might fly out! There should be something like a cog inside that engages with a worm gear. Check the worm gear and cog for wear...
Hope that gives you some pointers! ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Olly666 |
| Easy-X |
| Riejufixing |
| Easy-X |
 Posted: 00:28 - 29 May 2019 Post subject: |
Hang on... when I say "digital" or "cable" I mean the input not the display
You can have an LCD speedo and it still have a mechanical cable input.
Does the back of the speedo have this:
https://i.imgur.com/E6RdxEZ.jpg ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Olly666 |
| Easy-X |
 Posted: 13:06 - 29 May 2019 Post subject: |
Soz, more scope for an easy fix with mechanical  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Meatybeaty |
 Meatybeaty World Chat Champion
| Easy-X |
 Posted: 18:15 - 29 May 2019 Post subject: |
Lol... there are two types for this bike (so it seems) mechanical cable driven and electronic sensor. OP says it's sensor. I would imagine it'll be a sealed unit at the wheel so not much to do  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 23:26 - 29 May 2019 Post subject: |
Define "not working". Blank display? Only shows zero? Shows random numbers when moving?
Throw us a frikkin bone here. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Olly666 |
There is a gap of 6 years, 52 days between these two posts... |
| Dougster7 |
 Dougster7 L Plate Warrior
The last post was made 1 year, 77 days ago. Instead of replying here, would creating a new thread be more useful? |
