Bike weight vs Rider weight
NakedBiker
PostPosted: 19:05 - 31 May 2019    Post subject: Bike weight vs Rider weight Reply with quote
Recently switched to a lighter bike and noticed how much nimbler it felt turning and in the corners.
So it got me thinking, if lighter = better handling, does the rider losing weight also make the bike handle better or is it solely down to bike weight?
i.e. Would the difference be the same if the rider lost 10kg of body weight compared to the bike losing 10kg instead?
NakedBiker
RhynoCZ
PostPosted: 19:13 - 31 May 2019    Post subject: Reply with quote
There's more to it just than weight.
The frame geometry, tyres and how far the wheels are apart, the suspension system... all that is the deciding factor.
Lighter rider = faster bike. Thumbs Up
stevo as b4
PostPosted: 19:27 - 31 May 2019    Post subject: Reply with quote
Think it also depends on the rider to bike weight ratio too.
On a heavy big stable bike it's not going to notice an extra 10-20kg of rider weight or a reduction of that weight and there's some theory to heavier bikes handling bumpy roads better and the suspension working more effectively too. Its so much a can of worms though as a big heavy 240kg bike might have very sophisticated high quality suspension and a 100kg bike might have really budget basic stuff.
Im about 75kg and that's a big percentage of my bikes 95kg weight, so it's bound to affect the bikes handling more than if my bike was 200kg. There's a possibility that a light rider might be too light to make a heavy bike handle well too, and that there's an ideal ratio of rider to bike weight for every standard spec machine.
I'd suspect that Dani Pedrosa is too small and light to make a Kawasaki GTR1400 handle at its best or at least to get the best out of the bike?
Kawasaki Jimbo
PostPosted: 19:37 - 31 May 2019    Post subject: Reply with quote
With a middleweight bike the rider is about one third of the combined weight of bike and rider. I'm not sure at what point in a rider's diet he/she would see an improvement in handling but you'd feel fitter and more mobile.
It was said that little Dani Pedrosa was a hugely strong and gifted rider hampered by a lack of body weight when trying to wrestle a MotoGP bike.
I quite fancy a lightweight bike for short trips. I've found myself trickling the R1 along narrow country lanes enjoying the view thinking, "This is the wrong bike." On the other hand, it copes well, and deals with the A-road blast back home too, which a much smaller bike wouldn't do with the same alacrity.
Kawasaki Jimbo
PostPosted: 19:39 - 31 May 2019    Post subject: Reply with quote
Ha! I took a long time to post that, and now see Dani Pedrosa got a mention already.
grr666
PostPosted: 21:15 - 31 May 2019    Post subject: Reply with quote
It's easier to diet than strip weight from a bike IMO.
PostPosted: 22:06 - 31 May 2019    Post subject: Reply with quote
Being a big (fat) lump I've always liked big heavy bikes that don't mind lugging my fat arse around.
The smallest bike (other than our Fazer 600 hack) I have owned in years was a stripple.
Loved the bike and it handled my weight well but I never would have kept it over a Goldwing or my Trophy or even a big adventure bike like the Tiger Explorer I had.
So, It's a huge combination of things. Bike physical size, your size, bike engine size, suspension, tyres, set up etc. etc.
One thing I did learn with the Stripple, when you have quality suspension with a myriad of settings, get it set up for you by someone who knows what they are doing. It makes on hell of a difference.
PostPosted: 22:13 - 31 May 2019    Post subject: Re: Bike weight vs Rider weight Reply with quote
The issue you have is not overall weight, but if you go below a certain load on the bike then the suspension stops working properly. The suspension on a modern bike is designed to work within a certain load range. So to some extent if you're still within that range but don't weigh a lot, you'll get better performance out of the bike. If you drop beyond that range though? You'll find it becomes a hard ill handling pig with no confidence inspiring properties.
If you need to lose weight from the bike then unsprung mass is the way to go, which is why lightweight wheels are a big deal in terms of bang for the buck.
Kentol750
PostPosted: 22:22 - 31 May 2019    Post subject: Reply with quote
Grr666 is right. Less pies, more horses. It's simple, gsxr1000 tested with a 10stone guy on it doesn't handle the same with 15 stone on it.
Some bikes.
Jewlio Rides Again LLB
PostPosted: 23:59 - 31 May 2019    Post subject: Reply with quote
Bikes have adjustable suspension to negate rider weight. Look at McPint, he's a fairly big lad and he can make them bikes shift.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
MCN
PostPosted: 06:05 - 01 Jun 2019    Post subject: Reply with quote
Physics. Mass. Moments. Inertia.
E=MC2
Power to weight is a big part of the equation.
Divide the Rider weight and bike weight by the BHP/KW.
stevo as b4
PostPosted: 10:08 - 01 Jun 2019    Post subject: Reply with quote
Surely that only matters if your mate is the skinny bloke and your the fatty? I'm sure a GSXR 1000 would with a simple twiddle of the suspension adjusters shrug off another 5 or 10St like it's nothing, though I get your point about power to weight.
chickenstrip
PostPosted: 11:44 - 01 Jun 2019    Post subject: Reply with quote
Unless you're a huge person on a tiny bike, or a tiny person on a huge bike, I don't think it matters all that much as far as riding on the road is concerned. There are so many other factors to slow you down, it becomes a bit immaterial, especially as, as others have said, most road bikes have adjustable suspension settings to cope with a fairly wide range of load.
Competition is another matter.
PostPosted: 12:05 - 01 Jun 2019    Post subject: Reply with quote
Those two things are... not really associated...
So part of the reason John McGuinness is fast is because he's big and can dominate the bike on a bumpy TT course. He wouldn't be a great short circuit racer. But it's hardly the case that he rides a stock FireBlade around the mountain course.
The suspension will be designed and assembled for his specific weight. Adjustment has pretty much nothing to do with it apart from fine tuning setup. You can't adjust a standard bike to suit someone outside of it's designed range which is usually around 12-16 stone.
PostPosted: 12:07 - 01 Jun 2019    Post subject: Reply with quote
A tiny person on a big bike... let me tell you it does matter. There are plenty of bikes I couldn't get on with just because I wasn't (and am not) really heavy enough to allow the suspension to work properly.
I think a big person on a small bike has less of an issue. Even if they overload the suspension a bit, at least it still moves.
chickenstrip
PostPosted: 12:26 - 01 Jun 2019    Post subject: Reply with quote
I did kind of suggest that. But on the road, there are so many other things which mean you aren't going to get the very best possible out of your bike that for most people it's not a huge issue, not least due to the fact that unless you're on a top-of-the-range sports bike, your suspension is not likely to be of the highest quality anyway, and the majority won't pay out the extra to optimise it.
PostPosted: 12:37 - 01 Jun 2019    Post subject: Reply with quote
I heard the most disturbing thing on a motorcycling podcast recently... Apparently the BMW active suspension system doesn't suit riders under 12 stone in weight, and you can't even send it away to have lighter springs and stuff put on it because the computers can't be recalibrated to suit. So effectively I can never ride a BMW 'Sport' model, because the suspension will never work for me.
Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
chickenstrip
PostPosted: 12:42 - 01 Jun 2019    Post subject: Reply with quote
I thought you wanted a Z1000SX? So not a problem for you really.
Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile
PostPosted: 14:50 - 01 Jun 2019    Post subject: Reply with quote
The problem being that a) I quite fancied an S1000R as a 'fun' bike at some point and b) pretty much all bikes will end up that way at some point which puts me a bit out of luck.
I do want a Z1000SX but not really for pure desire reasons, but mainly because it will be good for my commute but then has some of the attributes I fancy in a 'fun' bike such as decent power and modern suspension and brakes. If I didn't have to commute I'd go with a naked - as mentioned likely an S1000R or similar.
chickenstrip
PostPosted: 14:55 - 01 Jun 2019    Post subject: Reply with quote
So if you move closer to work so that you don't have to commute any distance, you can continue to get upset about not being able to ride the BMW Very Happy Laughing
If it's that much of a problem, it will probably get sorted on future models, or they'll lose sales.
PostPosted: 15:55 - 01 Jun 2019    Post subject: Reply with quote
Or he can just put some weight on?
PostPosted: 16:20 - 01 Jun 2019    Post subject: Reply with quote
Laughing Laughing Good one yeah. Put on 20% bodyweight? I train with weights three times a week, I regularly do over 100 sit ups etc and I can't pack muscle on. Fat isn't an option as I feel rough if I'm only half a stone overweight, and if I were two stone overweight (which is what it would take to reach what some people have suggested is the minimum) I'd probably be wider than I am tall.
Plus.. move closer to London? Are you crazy? I can barely afford to live in Basingstoke! Laughing
thx1138
PostPosted: 16:34 - 01 Jun 2019    Post subject: Reply with quote
My 12 stone on my Beta 300cc 2 stroke, no complaints
friends that weigh 15 or 16 stone, all upgraded the suspension.
the 200cc vanvan, seems to handle just the same with or without a pillion
chickenstrip
PostPosted: 17:34 - 01 Jun 2019    Post subject: Reply with quote
Damn, looks like you'll have to settle for some mundane alternative, like maybe a V4 Tuono instead Sad
First world problems bro! Laughing
stevo as b4
PostPosted: 17:08 - 02 Jun 2019    Post subject: Reply with quote
Aren't those V4 Tuono things supposed to be really evil bikes that make Suzuki TLS's look sensible and stable and boring?
Im sure I've read that people find the KTM 1290 less of an animal and at least useable, but that those V4 Aprilia's are unridable a rapid way to hospital without the electronic safety blanket turned up to 11? Laughing
The last post was made 7 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 147.52 Kb
