| Calumh96 |
 Calumh96 Two Stroke Sniffer
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| Pigeon |
 Pigeon World Chat Champion
| doggone |
 doggone World Chat Champion
| Sister Sledge |
| P.addy |
 P.addy Red Rocket
| RhynoCZ |
 RhynoCZ Super Spammer
| RhynoCZ |
 Posted: 19:50 - 02 Jun 2019 Post subject: |
To check the clutch, there is nothing simpler, than riding at about 30-40mph, using the top gear, and suddenly open the throttle. If the engine starts dying, shaking... the clutch is good. If the revs go up while the motorcycle is not accelerating accordingly, the clutch is not good. The engine should never overpower the clutch, if it does then something is wrong. The sooner the clutch slips, meaning lower gears, the more fecked it is.
Also, check the oil regularly, not just when something goes wrong. Normally it's the camshaft that suffers from the lack of lubrication first. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Calumh96 |
| P.addy |
 P.addy Red Rocket
| BusterGonads |
 BusterGonads Trackday Trickster
| Tdibs |
 Tdibs Traffic Copper
 Posted: 20:58 - 03 Jun 2019 Post subject: |
So as above, just in case it needs saying another time.
Your clutch is slipping. It'll sound like someone riding an automatic scooter.
This can be for a variety of reasons, the easiest of which to check and fix is that the mechanism that disengages the clutch (so the lever, cable and pushrod) is not fully returning to the resting position. Hacving the same effect as the lever being slightly pulled in all the time.
After that, you're looking at the clutch itself which means draining the oil, taking off the RHS engine cover and having a look at it. The two most common causes in there are either badly worn clutch plates (there will be a minimum thickness in the workshop manual) and a notched clutch basket, which will be obvious to look at.
There can be various other causes too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Qyburn |
 Qyburn Renault 5 Driver
| Pigeon |
| P.addy |
 P.addy Red Rocket
The last post was made 6 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
