Chain Breaker/Riveter
LustyLew
PostPosted: 10:48 - 04 Jun 2019    Post subject: Chain Breaker/Riveter Reply with quote
Hi all,
My chain on the CB500x has too many tight spots for my liking, so it's coming off for new.
Opinions on split link chains are 50/50, so looking to get a rivet link and just bite the bullet and the get splitting/riveting kit.
Any recommendations on which kit to get?
Budget isn't particularly huge.
I've seen Draper, Sealey and BikeIt's offerings. They all look the same. Probably the only difference is the quality control. But they look very straightforward to use.
Ideas?
ThatDippyTwat
PostPosted: 10:51 - 04 Jun 2019    Post subject: Reply with quote
Cheap DID tool clone, but with a genuine DID pin. Both available online. Works, lasts, cheaper than a full DID tool.
Hong Kong Phooey
PostPosted: 11:24 - 04 Jun 2019    Post subject: Reply with quote
Don't bother pushing the pin, a hacksaw goes through the chain nae bother.
I bought a cheap clone and the ball bearing end was knackered after one chain.
Now I just borrow one from a mate, not sure which his is though.
To make life easy, do the rivet at the back sprocket rather than struggling at the middle of the free chain run like wot I did once.
Confusion
PostPosted: 12:32 - 04 Jun 2019    Post subject: Re: Chain Breaker/Riveter Reply with quote
You have three jobs to do:
1 Break the old chain
2 Press the plate on to the new rivet link
3 Flare the soft ends of the pins on the new rivet link
There is no current technology which will allow you to
remove the pins in a single operation. Always grind the
heads off the riveted pins before you try to push them
out. As your old chain is knackered, you may as well
cut it off with a hacksaw or cutting disc.
Pressing on the new outer plate is a critical part
of the job. Push in very small increments using
the width of the adjacent links as a reference. Make
sure the plate pushes on evenly. Cheap nasty chain
tools tend to push off-square, so that you get the
correct width on one pin and a squashed O-ring
on the other.
I have one of these. Mine is Nielsen branded. Nasty Chinese shite.
Not particularly straightforward to use because it has no limit
when pushing on the side plate. The DID tool and it's clones are
designed to stop when the plate is 'home'.
Ideas?
The best cheap riveter I have seen is the AFAM chain tool.
It doesn't have a breaking pin, but this is not really an issue
since all the other "chain breakers" can't break a good quality
Japanese chain anyway.
The AFAM tool does a good job of pressing on the new
plate and flaring the soft rivets. My mate has one and it
is still in perfect condition after riveting 3-4 chains.
The press plates have a similar design to the DID tool,
so in theory, you can't press the plate too far.
https://www.afam.com/en/chain-accessories/afam-easy-riv5-handy-chain-riveting-tool/
https://www.youtube.com/watch?v=skX2GhrB2Oc
Bandit 650SA, ZZ-R1100
Nobby the Bastard
Harley Gaydar
PostPosted: 16:06 - 04 Jun 2019    Post subject: Reply with quote
You only need to flare it enough that the plate cannot pull off. The flaring doesn't add any additional strength.
Triumph Sprint ST 1050
kgm
PostPosted: 18:28 - 04 Jun 2019    Post subject: Reply with quote
If you have a set of calipers or micrometer you can be fancy and measure the width of the flare and plates to ensure its as specified by the manufacturer.
As for rivetting tools the whale is the best but expensive. I've used a DiD clone which did the job absolutely fine with some care taken. I've also used one of the other generic type ones with shitty pins. They work as long as you go slowly, I found the best way to avoid breaking pins is to add a little pressure and back it off slightly before adding more pressure. Add too much at once and the pins just break.
I've also read the AFAM ones are decent.
Just take a Dremel or grinder to the old chain. If you need to split some links off of the new chain either buy a decent splitter or use the backing off method above.
Pigeon
PostPosted: 23:02 - 04 Jun 2019    Post subject: Reply with quote
Try and get the [ style, rather than the 2 halves you have to keep joining /re-joining.
Because you make so many 1/4 -1/2 turn adjustments to get the correct plate width and flare.
I've used this very cheap one as well as this slightly more expensive Bergen one
The £12 tool did 2 chains and i then bent a pin. But it was probably my miss-use to be fair.
The Bergen one (£20), the pins seem slightly better perhaps.
Ultimately though, was happy to use the £12 set. If it only last 2-3 chains, not a massive expense given the cost of the chain and the mileage in between changes.
Get a cheap chinese digital micrometer too. Thumbs Up
EDIT: I ground down pins as per peoples recommendations. Wouldn't want to press a pin out without having done so.
EDIT2: I meant a Vernier Caliper, not micrometer Embarassed
As per Islanders post. Thumbs Up
Islander
PostPosted: 09:00 - 05 Jun 2019    Post subject: Reply with quote
I have the Draper tool and it's fine for occasional use which is all the majority of riders need anyway.
Cut through the chain or grind the heads off of the rivets on the master link as advised and take things slowly when you rivet the new one - it's better to slightly underdo things rather than overdo them. You'll feel the head deform as you tighten the tool and that's the time to stop and check.
A vernier caliper is far more useful than a micrometer for general use and is the preferred tool for measuring rivet head diameter anyway.
sickpup
Old Timer
PostPosted: 11:08 - 09 Jun 2019    Post subject: Re: Chain Breaker/Riveter Reply with quote
LustyLew wrote:
Hi all,
Ideas?
The tool you get is dependant on the chain type you get.
If it has solid pins you need a whale tool to flare the edges, if its a dimpled pin you can use a whale tool but the DiD tool is a lot better.
Angle grinder with cutting disc to remove regardless of type.
Fisty
PostPosted: 18:08 - 09 Jun 2019    Post subject: Re: Chain Breaker/Riveter Reply with quote
Both of my chain tools will allow you to remove hard and soft links in one operation.
Sadly my Whale one was stolen.
Fatter and faster than Fret
LustyLew
PostPosted: 16:08 - 11 Jun 2019    Post subject: Reply with quote
Hi all,
Thanks for the advice...
In the end, a mate came round with one of the Sealey riveters... Yes, it bent! Laughing
Luckily we managed to get the chain on and it seems secure.
I will save up for a DID one I think!
PostPosted: 19:28 - 11 Jun 2019    Post subject: Reply with quote
I always rivet the solid pins with 2 hammers. I use a digital caliper to measure the spread to be sure it won't pull out.
The last post was made 6 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 79.75 Kb
