best adhesive for ally to ally
trevor saxe-coburg-gotha
PostPosted: 07:14 - 02 Jun 2019    Post subject: best adhesive for ally to ally Reply with quote
Need some glue for aluminium to aluminium - bought a cheap shit side stand foot enlarger and don't think the fasteners are up to much, so want a belt-and-braces thang. Cheers.
colink98
PostPosted: 07:51 - 02 Jun 2019    Post subject: Reply with quote
https://www.thistothat.com/cgi-bin/glue.cgi?lang=en&this=Metal&that=Metal
Ride it like you stole it.
Hong Kong Phooey
PostPosted: 23:38 - 03 Jun 2019    Post subject: Reply with quote
I think the constant movement and pressure means something like a 3M VHB pad, or permanently flexible adhesive.
A glue that sets hard will crack eventually.
Either way it'll have to be spotless before applying, and oil/water resistant too.
Easy-X
PostPosted: 23:51 - 03 Jun 2019    Post subject: Reply with quote
I'd vote for JB Weld, it's about the best in class for epoxy-type glue.
PostPosted: 00:32 - 04 Jun 2019    Post subject: Reply with quote
Hong Kong Phooey wrote:
3M VHB pad
Is that the tape trucks are made from?
WD Forte
PostPosted: 01:46 - 04 Jun 2019    Post subject: Reply with quote
JB weld is good but as said, flexing could crack it over time.
I'd maybe drill a hole and put a countersunk bolt in from below and see how that went.
Failing that, just dump the ally one, make a steel plate and weld the fecker on and have done with it
bikers smell of wee
Hong Kong Phooey
PostPosted: 09:44 - 04 Jun 2019    Post subject: Reply with quote
3M VHB pad
Does your mummy know you do this yfpos?
Riejufixing
PostPosted: 10:11 - 04 Jun 2019    Post subject: Re: best adhesive for ally to ally Reply with quote
If you are using "aluminium to aluminium", why not use the same substance as "glue"? Bzz spark bzz job done. OTOH if it's a cheap crap thing why not try it wiith the supplied fixings and see how long it lasts, it may not be a problem.
PostPosted: 14:37 - 04 Jun 2019    Post subject: Reply with quote
Aluminium solder... Or get fasteners that do look like they are up to something.
Riejufixing
PostPosted: 14:57 - 04 Jun 2019    Post subject: Reply with quote
Lumiweld? I'd still be tempted to take it along to someone with a high frequency set and get it welded, for a trivial job like that cost would be similar.... but he bought a cheap foot anyway, so maybe that would defear the object of the exercise....
The last post was made 7 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 69.04 Kb
