| digifixuk |
 digifixuk L Plate Warrior
| Easy-X |
 Easy-X Super Spammer
| WD Forte |
 WD Forte World Chat Champion
| Easy-X |
 Posted: 23:11 - 04 Jun 2019 Post subject: |
Easy Start isn't a "fix" it's a diagnostic tool  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Robby |
 Robby Dirty Old Man
 Posted: 08:20 - 05 Jun 2019 Post subject: |
Just to be clear, the injector is working when it isn't fixed in place on the bike. Can you give some more info here:
- is it still connected up to the bike wiring and fuel supply, just pointing away from the bike?
- is it producing a fine mist of petrol, or a pathetic dribble?
I'm thinking of two possibilities:
1. The injector is working, but there is very little fuel pressure or the line is full of air that needs bleeding out. Bleeding out the air can be done by just cranking the engine, as the injector operates it will squeeze out whatever is in the line. If the pressure is down, I would be looking again at the fuel pump and making sure it works, has a good fuel supply, and isn't full of air. Not sure if these use a one or two line fuel system.
2. Electrical. Either the wiring is dodgy and is shorting out when the injector is installed - giving it a wiggle will help diagnose where the problem is, if you wiggle it and it runs then you've found the bad wire.
Otherwise it could be the injector shorting out when installed on the bike. This shouldn't happen, but could be possibly in some circumstance with really knackered wiring. |
| digifixuk |
 Posted: 12:38 - 05 Jun 2019 Post subject: |
| Robby wrote: | Just to be clear, the injector is working when it isn't fixed in place on the bike. Can you give some more info here:
The Injector worked at the garage that cleaned it but not even a dribble on the connected to the bike,there is 12volts on the Injectors power connectors, fuel comes out of the fuel hose when disconnected from the Injector, I thinkk that there might not be enough fuel pressure but have nothing to measure the output with, |
| Easy-X |
 Posted: 13:00 - 05 Jun 2019 Post subject: |
This might help:
https://ybr125owner.blogspot.com/2014/06/yamaha-ybr-125-fuel-injection-system-fi.html
TBH I'm having a hard job working it out from the YBR wiring diagram but if your injector is switched earth then yes you would see +12V power but the injector might not be activated at the appropriate time by the ECU.
Two likely possibilities: low fuel pump pressure (clogged with crap from the old rusty tank maybe?) or a totally co-incidental fault like a safety cut out (e.g. side stand switch knackered, that sort of thing.) ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| digifixuk |
| Islander |
 Islander World Chat Champion
The last post was made 7 years, 149 days ago. Instead of replying here, would creating a new thread be more useful? |
