Head Gasket
Jrod
Page 3 Girl
PostPosted: 21:55 - 24 Mar 2005    Post subject: Head Gasket Reply with quote
Well she's gone! Sad
I've had a quote of £166 to fit a new one including the gasket and also to do the valve clearances whilst I'm there. I think thats pretty cheap! Anyone on here do it cheaper? Wink
Kawasaki sunday. Mad Mad Mad Sad
Sparks!
Sir Tart-a-lot
PostPosted: 21:58 - 24 Mar 2005    Post subject: Reply with quote
Crying or Very sad Indeed... told ya ZXR400's weren't great bikes to try and wheely Laughing
Jrod
Page 3 Girl
PostPosted: 22:00 - 24 Mar 2005    Post subject: Reply with quote
I blame Yams Wink . Last time we went wheelieng I blew my fork seals, this time the head gasket next time.....? Frame snappage? Shocked
instigator
PostPosted: 22:01 - 24 Mar 2005    Post subject: Reply with quote
Is getting a haynes manual not an option? Head gasket shouldn't be that hard I would have though. Confused ???
How much is it just for the head gasket itself? Or do you have to buy the full top end set?
Jrod
Page 3 Girl
PostPosted: 22:03 - 24 Mar 2005    Post subject: Reply with quote
I've got a workshop manual but It's alot of work and tbh I CBA. I Don't have all the tools and it's a big job to do. Ah well better luck next time. Wink
M1ke
Ped Boi
PostPosted: 22:16 - 24 Mar 2005    Post subject: Reply with quote
Whats big about it? All you have to do is drain the coolant, undo the 8 or so bolts on the head then insert a new gasket?
Am I missing something?
Jrod
Page 3 Girl
PostPosted: 22:18 - 24 Mar 2005    Post subject: Reply with quote
No, I'm missing something....mechanical skill. Wink If you wanna do it for me feel free..... Smile
M1ke
Ped Boi
PostPosted: 22:22 - 24 Mar 2005    Post subject: Reply with quote
Thats a good quote for the valve clearances as well, I say go for it if you cant do the gasket your self.
Jrod
Page 3 Girl
PostPosted: 22:25 - 24 Mar 2005    Post subject: Reply with quote
Not up to it then eh...... Wink Laughing
M1ke
Ped Boi
PostPosted: 22:35 - 24 Mar 2005    Post subject: Reply with quote
Neah I don't think so Razz
What ever you do, dont ride it far with it in that state, it will overheat once all the coolants evapourated into the engine and cause you a hell of a lot more trouble than a gasket.
If you must ride it, make sure the coolants nicely topped up, and keep checking the level. If the gaskets gone badly, coolant can find its way into your gear box causing the clutch to slip also.
instigator
PostPosted: 22:41 - 24 Mar 2005    Post subject: Reply with quote
Just what I was thinking. Nae bother Laughing Thumbs Up
Jrod
Page 3 Girl
PostPosted: 22:59 - 24 Mar 2005    Post subject: Reply with quote
It's more work than just a few bolts.... Confused
gimpy limp
PostPosted: 23:21 - 24 Mar 2005    Post subject: Reply with quote
shouldn't be hard, just a little more involved than this engine :
this is a DT50 engine but the principal's the same just abit more time consuming as those DT50 engines are very simple mechanically.
https://www.pre-auto.com/images/misc/dt-50-engine12headgasket.jpg
the thought of it is probably putting you off more than anything - you don't need any mechanical knowledge and you'll probably get away with one or two socket bits to take it all apart.
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
Jrod
Page 3 Girl
PostPosted: 23:22 - 24 Mar 2005    Post subject: Reply with quote
But you need to set the timing when you take the head off? All this is a bit confusing. Wink
gimpy limp
PostPosted: 23:24 - 24 Mar 2005    Post subject: Reply with quote
shouldn't be, just mark the timing as it is before you take it all apart, line it up how it was then. (btw i've never timed a bike engine just suggesting it)
PostPosted: 00:43 - 25 Mar 2005    Post subject: Reply with quote
Given that a new gasket is probably £30 that is probably a fairly good deal.
It is not a 5 minute job to change the gasket. At a guess, take the bodywork off, remove the carbs, remove the exhaust, drain the coolant, remove a crank end cover, set the engine to TDC, remove the rocker cover, remove the camshaft caps, remove the cam chain tensioner, tie the cam chain up so it doesn't drop into the engine, remove the cams, undo the head bolts and then remove the head. Check the head is flat (and if not get it skimmed), clean it all up and reassemble.
Jrod
Page 3 Girl
PostPosted: 00:50 - 25 Mar 2005    Post subject: Reply with quote
What cylinder would you put TDC? Or would you just set the crank pully to 0 degrees (does it have one Question going by cars here.)
Confused
gimpy limp
PostPosted: 00:52 - 25 Mar 2005    Post subject: Reply with quote
lol i'm just going by cars too Embarassed
mchaggis
PostPosted: 00:55 - 25 Mar 2005    Post subject: Reply with quote
Starting off with a 125 single is a nice way to get used to mechanical maintenance. Everything is nuts and bolts at the end of the day, it is all a giant metal lego set.
Things get complicated when fabricating or specialist tools become issues, but most maintenance really doesn't need those.
I hate to be rude, but you need to take better care of your bike. Less tart, more basic maintenance. If nothing else, it's far far far cheaper.
Blown gaskets and seals, knackered sprockets and snapping chains can really ruin your day, if not depositing you into a hedge along the way and chewing bits out of your engine.
Take care. Karma
I must not be a troll...
Mmmm, Guinness
gimpy limp
PostPosted: 00:58 - 25 Mar 2005    Post subject: Reply with quote
if it were me i'd give it ago - i've tought myself far more complicated things in my time that once you learn will save you a fortune in the long run as you can fix it yourself once you've dun it once.
is it the same with bikes as it is with cars in regard to using the right torque settings when doing it back up? do you have to take the bolts off and put them back on in sequence the same as you do with cars?
binge
Emo Kiddy
PostPosted: 01:18 - 25 Mar 2005    Post subject: Reply with quote
Take care. Karma
Thats cos he is always trying to wheelie. Buy a cheap nasty 2 smoker 125 field bike if you want to wheelie! Laughing
Jrod
Page 3 Girl
PostPosted: 02:13 - 25 Mar 2005    Post subject: Reply with quote
It's hardly my fault that my fork seals blew because I was being 'tarty' Confused The chain was me neglecting it a little yes. Blown head gasket..... If I was less tarty that wouldnt happen? Rolling Eyes
mchaggis
PostPosted: 02:16 - 25 Mar 2005    Post subject: Reply with quote
I might be confusing you slightly with another tart with the same bike. As such, accept my apologies. Thinking
Mmmm, Guinness
Jrod
Page 3 Girl
PostPosted: 02:18 - 25 Mar 2005    Post subject: Reply with quote
I'm confused. Laughing If i said I will just ride the bike with a blown head gasket becuase I need more anodised bits Wink Then fair enough. Razz The bike IS being fixed BEFORE I buy ANYTHING else. Thumbs Up Mr. Green Thumbs Up
Claud 14.7 to 1
PostPosted: 02:40 - 25 Mar 2005    Post subject: Reply with quote
Nope sounds about right Laughing , although everything bar the chain snapping is beyond control.
Damn you ZX400er , I have to ride alone now. Neutral ... Get workin'! Mr. Green
The last post was made 21 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 132.17 Kb
