fuel consumption
leolion
PostPosted: 16:13 - 09 Jun 2019    Post subject: fuel consumption Reply with quote
Sorry for being a muppet but at a steady 55mph what would be more economical,1 cyl,2cyl,3cyl or 4 cyl?
RhynoCZ
PostPosted: 16:27 - 09 Jun 2019    Post subject: Reply with quote
Would those hypothetical engines have the same power output?
Nobby the Bastard
Harley Gaydar
PostPosted: 16:28 - 09 Jun 2019    Post subject: Re: fuel consumption Reply with quote
It's not that simple. Generally, the more power from a given amount of fuel means more cylinders but at a constant speed?
The one with the fairing...
Triumph Sprint ST 1050
leolion
PostPosted: 16:37 - 09 Jun 2019    Post subject: Reply with quote
within reason.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:10 - 09 Jun 2019    Post subject: Reply with quote
leolion wrote:
within reason.
In that case, definately the one with the most slippery fairing.
PostPosted: 17:12 - 09 Jun 2019    Post subject: Re: fuel consumption Reply with quote
Yes.
PostPosted: 19:09 - 09 Jun 2019    Post subject: Reply with quote
Back in the other thread you started, I wrote:
Back away from the spreadsheets...
Still holds. Just ride the fucking thing.
Easy-X
PostPosted: 01:12 - 10 Jun 2019    Post subject: Reply with quote
For fuel efficiency you might want to start with the power to weight ratio rather than the number of cylinders.
For example, of the bikes I'm looking at the moment:
Honda Rebel: 33.5kW for 190kg = 176W per kg
HD Street 750: 43kW for 223kg = 192W per kg
Kwak Vulcan S: 45kW for 229kg = 192W per kg
This is only a basic starting point but it gives you a ball park before you get into how well the engines are tuned.
Also consider that every bike has a certain amount of unavoidable "dead weight" (e.g. the rider but also little niceties like wheels and fuel tank, brakes etc.) before considering the engine weight. The proportion of dead weight vs engine power mostly favours the bigger bikes but lets have a look at something much bigger:
HD Fat Boy: 64kW for 304kg = 210W per kg
So for almost 100kg more weight there's barely any substantial usable power gain. It still looks like the Fat Boy might be a better bet from just the numbers but then you have to take into account it wants high octane fuel...
temeluchus
PostPosted: 05:05 - 10 Jun 2019    Post subject: Reply with quote
aerodynamics and rolling friction is the bigger factor on cruising fuel economy than weight. It's why a lot of cars cruising on the motorway are more economical than many bikes.
Weight affects economy when you are braking and accelerating.
PostPosted: 06:42 - 10 Jun 2019    Post subject: Reply with quote
A late 80's, piston ported 100cc 2-stroke should return considerably in excess of 100mpg at 55mph.
A C90 would also be well up there pushing 3 figures too.
A "vanilla" 350 bullet would be returning mid 80's mpg and should mamage to do 55mph under most circumstances.
So on that basis, a single cylinder.
But do you want to ride one of those bikes?
trevor saxe-coburg-gotha
PostPosted: 06:53 - 10 Jun 2019    Post subject: Re: fuel consumption Reply with quote
no
Robby
Dirty Old Man
PostPosted: 08:25 - 10 Jun 2019    Post subject: Reply with quote
The one with the most efficient engine, that is working at its optimum efficiency around 55mph.
I could now spout all kinds of barely understood shite about peak torque, pumping efficiency and specific fuel consumption. Even if I was accurate on the numbers, it wouldn't translate into real-world use.
At 55mph, just about anything you might be considering will return in excess of 70mpg. Fuel burn not worth measuring beyond that point.
1198
PostPosted: 13:46 - 10 Jun 2019    Post subject: Reply with quote
To help / confuse you more, if this is in ‘whats cheapest to go to work on’ you need to start considering running costs too.
Are you able to service it yourself? Are tyres cheap? What’s the depreciation like? Insurance?
A brand new bike that does 80-100mpg but costs you a large percentage of the total purchase cost over a couple of years and which you had serviced by a franchised dealer (for the warranty) would most likely be more real world money out of your pocket than a bike a few years older that does say 50-60mpg but only loses a few hundred pounds at most in depreciation (if at all) and is serviced by Fred the local motorcycle dealer...
ThunderGuts
PostPosted: 14:23 - 10 Jun 2019    Post subject: Reply with quote
Fuel has a fixed quantity of energy available per litre (or gallon if you prefer). The majority of fuel burned in even the most efficient engine is still waste heat, but this proportion increases with inefficiency.
I'm not convinced that number of cylinders is the biggest factor, but typically 4 pots tend to be more performance orientated than 2 pots (not always, but typically).
Fuel injected will be more efficient than a carb'd bike as the former should provide the fuel quantity needed more accurately. Faired bikes should be more slippery in the air, so should be better. Weight is largely irrelevant at a constant speed on the flat.
Just look at the book figures and see what they suggest . . . don't expect to get the figures they quote, but they're reasonable for a like-for-like comparison.
TG.
chickenstrip
PostPosted: 14:25 - 10 Jun 2019    Post subject: Reply with quote
Hello Mr. Leopussy Smile
How do you propose to get any fun out of life?
PostPosted: 15:02 - 10 Jun 2019    Post subject: Reply with quote
A couple of hours on Fuelly.com, some Swarfega and a box of tissues.
PostPosted: 15:04 - 10 Jun 2019    Post subject: Reply with quote
* Green Swarfega. Not orange.
chickenstrip
PostPosted: 15:13 - 10 Jun 2019    Post subject: Reply with quote
Worrying how that occurred to me, too Pale
leolion
PostPosted: 16:34 - 10 Jun 2019    Post subject: Reply with quote
in all honesty im just trying to fill the time until death happens, i like to think that life is deaths waiting room and a bit like a doctors appointment your never sure when your going to called in.There is no fun to be had in waiting.
PostPosted: 16:36 - 10 Jun 2019    Post subject: Reply with quote
Nor spreadsheets or querying the mpg. Ride it, enjoy it, don't look too much into it.
leolion
PostPosted: 16:38 - 10 Jun 2019    Post subject: Reply with quote
its painful spending a fiver in 30miles though i thought id achieve much better than that.
chickenstrip
PostPosted: 16:39 - 10 Jun 2019    Post subject: Reply with quote
Just killing time, till time kills me Smile
Take your own book or magazines to read Wink
chickenstrip
PostPosted: 16:41 - 10 Jun 2019    Post subject: Reply with quote
Shocked I thought you had an MT07, not the fuckin Space Shuttle!
leolion
PostPosted: 16:46 - 10 Jun 2019    Post subject: Reply with quote
exactly!!!!! i thought it was a bit juicy.
chickenstrip
PostPosted: 16:53 - 10 Jun 2019    Post subject: Reply with quote
So given we know that you're not caning it everywhere (not even faintly close Laughing ), have you considered your bike might have a problem that needs addressing, rather than you going off and considering a different bike to reduce your fuel consumption?
The last post was made 7 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 137.15 Kb
