Honda FES 125 swing fuel stutter problem
Teddington
PostPosted: 18:23 - 10 Jun 2019    Post subject: Honda FES 125 swing fuel stutter problem Reply with quote
I am new to the forum and have a problem with a 2010 Honda FES125 swing and wonder if anyone can help.
When running, the engine tends to stutter, with a small drop in revs and then return, under load it can stutter more. It is more prevalent in the 5000 to 7000 rev range. It sometimes cuts out at idle with no restart unless I switch off and turning on again. Checked and changed filters, fuel and spark plugs.
Is there any obvious issue known on these scooters? assume a fuel problem but unsure?
Teddy
cb1rocket
PostPosted: 23:38 - 10 Jun 2019    Post subject: Reply with quote
have you tried a new plug cap? There fairly common to break down. Also running on shell 97 helps too.
jaffa90
PostPosted: 23:53 - 10 Jun 2019    Post subject: Reply with quote
When was the last time the fuel injector and feed pipe cleaned?
cb1rocket
PostPosted: 09:22 - 11 Jun 2019    Post subject: Reply with quote
how would this be cleaned exactly? Additives?
jaffa90
PostPosted: 10:03 - 11 Jun 2019    Post subject: Reply with quote
By removal and pro cleaned and tested,
additives no.
Teddington
PostPosted: 10:53 - 11 Jun 2019    Post subject: Honda FES 125 swing fuel stutter problem Reply with quote
Many thanks
Will try new cap, yes cleaned fuel jets recently as part of solving problem, haven't tried different fuels but used additives to clean system too. Still no joy
jaffa90
PostPosted: 15:44 - 11 Jun 2019    Post subject: Reply with quote
"""yes cleaned fuel jets recently as part of solving problem""
Who mentioned fuel jets?
Teddington
PostPosted: 09:54 - 13 Jun 2019    Post subject: Honda FES 125 swing fuel stutter problem Reply with quote
Apologies, I mentioned fuel jets, I meant to say fuel injectors and feed pipe have been looked at recently and still a problem. Many thanks
hayes2865
PostPosted: 21:54 - 20 Oct 2019    Post subject: Re: Honda FES 125 swing fuel stutter problem Reply with quote
Did you ever resolve the problem with your s wing?
Honda 2013 S Wing 125cc
Teddington
PostPosted: 11:38 - 24 Oct 2019    Post subject: Honda FES 125 swing fuel stutter problem Reply with quote
Hi there, tried lots of things recommended on fuel issues, changed spark plug, plug cap, fuel pump, cleaned fuel lines and ejector but turned out to be an electrical fault linked to the fuse box. It was an intermittent issue apparently caused by a loose fuse. Seems to be working OK now. Hope this helps and thanks.
jaffa90
PostPosted: 21:29 - 24 Oct 2019    Post subject: Re: Honda FES 125 swing fuel stutter problem Reply with quote
Any conclusions help, we were led astray with the heading.
The last post was made 6 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.78 - MySQL Queries: 13 - Page Size: 65.78 Kb
