anyone with a VFR haynes/clymer manual
Robby
Dirty Old Man
PostPosted: 19:46 - 04 Nov 2002    Post subject: anyone with a VFR haynes/clymer manual Reply with quote
does anyone have a VFR400 manual with instructions of how to dismantle and rebuild the fuel tap, and which pipes go where.
i've got it rebuilt and its leaking a little bit of fuel, just dripping it. i sealed up around the top of the tap so i think it could be one of the little pipes coming off it.
yeh. confusing stuff, i had little leaks with no obvious reason.
PostPosted: 19:52 - 04 Nov 2002    Post subject: Reply with quote
MY flat mate's got the NC30 one lying around somewhere I think... I'll scan the pages if you want it and I can find it.
Robby
Dirty Old Man
PostPosted: 20:40 - 04 Nov 2002    Post subject: Reply with quote
yes please. cheers G.
Stew
If it's good enough for top race teams...
PostPosted: 22:09 - 04 Nov 2002    Post subject: Reply with quote
You might have a broken O-ring or knackered daiphragm(SP?) in the fuel tap mate.I had a similar problem after a daft mechanic put the vacuum hose on the wrong connection of the fuel tap, my solution was to buy a new (well used) tap assembly from a breakers yard. Cost me £15 and sorted the problem.
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
Robby
Dirty Old Man
PostPosted: 23:40 - 04 Nov 2002    Post subject: Reply with quote
the o ring is fine and the diaphragm doesn't sit flat on it own, but with a little work i can get it to sit flat between the 2 plates. the big problem i have is where the vacuum hose and spring are meant to go, i need to see the exploded drawing of the in the manual to see how to reassemble it.
if is really is knackered, and theres a fair chance there seeing as when i took it apart it was fully of very thick rust, i'll get one off partfinder.
PostPosted: 23:57 - 04 Nov 2002    Post subject: Reply with quote
Sorry, been a bit busy/lazy tonight... I'll do it tommorow morning or unch time.
The last post was made 23 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 46.2 Kb
