Replacing Disc brake pads.
BoYSiE
PostPosted: 13:38 - 26 Mar 2005    Post subject: Replacing Disc brake pads. Reply with quote
Hi, i have a just fitted new front disc pads for my scooter, but when i pull my front brake it seems to not release the disc brake properly, so the pads are rubbing opn the disc brake.
Do i need to wear them in a little? as i havent been out on it yet, i dont weather this is normall when you fit new pads.
Thanks,
Odie
PostPosted: 14:58 - 26 Mar 2005    Post subject: Reply with quote
Did you clean the piston/s before you pushed them back into the caliper?
BoYSiE
PostPosted: 15:51 - 26 Mar 2005    Post subject: Reply with quote
Confused No i didnt, is it possible that some dirt or grit is on them, how do i wash them and what shall i wash them with?
nick.h
PostPosted: 18:04 - 26 Mar 2005    Post subject: Reply with quote
i used petrol when i did mine, that and a screw driver, a piece of wood, to force the pistons back.
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
BoYSiE
PostPosted: 18:16 - 26 Mar 2005    Post subject: Reply with quote
Ok thanks, seems a bit better, I'll take her out a little bit later once these dark clouds go.
mr jamez
PostPosted: 18:26 - 26 Mar 2005    Post subject: Reply with quote
Use brake fluid to clean the pistons, as other things like WD40 or petrol might damage the rubber seals.
The last post was made 21 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 47.35 Kb
