Bike Lift Logistics Question
johnsmith222
PostPosted: 16:20 - 08 Jul 2019    Post subject: Bike Lift Logistics Question Reply with quote
Hi guys,
I'm thinking of getting a small bike lift for a single garage. The only potential issue is there is not much space in the garage, as I have a workbench at one side, and racking at the other side.
I have a single sports bike and I was wanting to park the bike on the lift. The bike doesn't have a centre stand, so would be on a side stand.
The lift would be something like this:
https://cdn.manomano.com/hydraulic-motorbike-motorcycle-bike-lift-ramp-service-shop-bench-1000-lbs-450kg-P-3154542-8899056_2.jpg
Is there any issues I might be missing that you think I've not considered, that could make getting the bike parked up a faff?
Some things I've considered are if the lift is wet then it might make it easier to drop the bike. Also the lift is going to raise the height a bit to the floor so I'll need to be careful.
Thanks for your help!
PostPosted: 16:42 - 08 Jul 2019    Post subject: Reply with quote
I had one (Shaggy has it now).
I used to run the Fazer 600 up it no problems and that didn't have a centre stand as it had been removed for track days.
Anything heavier and I'd either want some one there to steady the bike 'just in case' or I'd get off and walk it onto the ramp.
Triumph Trophy Launch Edition
Islander
PostPosted: 18:51 - 08 Jul 2019    Post subject: Reply with quote
What about an Abba Skylift?
PostPosted: 20:46 - 08 Jul 2019    Post subject: Reply with quote
Only downside I've found is that the drive to the garage is uphill gravel, so pushing the bike onto it needs a good heave to get it started and keeping the momentum going.
Not a fault with the ramp, and at some time in the future I'll be looking at having it sunk into the floor - just want to be certain of how I'm going to arrange the garage before committing to fucking up the floor Smile
It does make life much easier though, my knees and back thank it, and Polarbear Smile
PostPosted: 22:18 - 08 Jul 2019    Post subject: Reply with quote
My mate installed one of those in his garage by cutting a rectangle out of the floor about a foot deep and re-concreting, thus setting the lift so the deck was at floor level.
ADSrox0r
PostPosted: 06:39 - 09 Jul 2019    Post subject: Reply with quote
I got a Skylift, expensive but bloody brilliant and saves a ton of space when not in use.
Grubscrew
PostPosted: 15:27 - 09 Jul 2019    Post subject: Reply with quote
I’ve got one just like that.
Flipping heavy, a bit of a pain if you have to store it somewhere, and it could do with swivel casters both ends, not just one end.
The hydraulic ram is meaty enough, but mine lost oil after a couple of years from the lowering screw in the side of the ram. Took it apart, what a crap bit of machining as the o ring was supposed to seal the thread Rolling Eyes , smoothed it and all’s good.
Handy bit of kit though. I have a Fiat on mine at the mo.
FJR1300/CBR1000F
ZebraDriver
PostPosted: 18:28 - 09 Jul 2019    Post subject: Reply with quote
I have one similar to that. Mine is sunk into the garage floor. To use it I have to lift a panel at the side of the lift and attach the foot pedal. Being sunk into the floor you don't need the ramp but you do need to make a plate that covers the hole that is exposed when the lift is up (its embarrassing when you fall down the hole as you work on the bike).
I also discovered that you have to put wooden blocks (or similar) at the corners otherwise it tips over when you stand on it with the lift down and you have to bolt on the front wheel clamp when you are going to use it, because its a great trip hazard if its left in place when the lift is not in use.
The last post was made 6 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 57.2 Kb
