Deflated
kramdra
PostPosted: 13:27 - 09 Jul 2019    Post subject: Deflated Reply with quote
I either have an intermittently slow/fast puncture, or someone at work is letting it down. Soapy spray shows no bubbles, the valve is new, and good. Holds pressure overnight, flat after a couple hours at work. I have not checked pressure after arriving at work but appears full with thumb press. I will start checking!
I did check 5 miles into my 30mile journey and it was fine.
Tire is a rear road 5 with two puncture repairs. One is new, the other appears good, and has freshly applied liner sealant to be sure.
Fisty
PostPosted: 13:54 - 09 Jul 2019    Post subject: Reply with quote
I had this many years ago, dull bastard at work letting my tyres down because i "parked in his space".
Cover the valve and cap in a thin smear of grease when you park up, if it gets tampered with you will be able to see.
I resorted to valve caps that lock with a grub screw.
Fatter and faster than Fret
RAYK47
PostPosted: 14:00 - 09 Jul 2019    Post subject: Reply with quote
If it's not going down overnight then I think you have the answer.
PostPosted: 14:13 - 09 Jul 2019    Post subject: Reply with quote
Agree with Fisty. Valve caps with grub screws. Thumbs Up
Triumph Trophy Launch Edition
Fisty
PostPosted: 14:14 - 09 Jul 2019    Post subject: Reply with quote
Also.
TYRE
Bhud
PostPosted: 15:54 - 09 Jul 2019    Post subject: Reply with quote
Permanent ink all over the valve cap when you leave it parked (in your usual place at the usual time). You'll find the culprit away from his desk, futilely washing his hands, or avoiding you all day.
Andy_Pagin
PostPosted: 16:12 - 09 Jul 2019    Post subject: Reply with quote
Once in a while you'll find a tyre does this for no apparent reason, my current front BT023 which has never had a puncture loses about 10psi after 100 miles of leasuerly commuting. Last tyre didn't so the rim's probably ok.
Smok3y666
PostPosted: 16:28 - 09 Jul 2019    Post subject: Reply with quote
Jizz on the valve will sort it.
pepperami
PostPosted: 17:37 - 09 Jul 2019    Post subject: Reply with quote
Hmmm.? Wanking over your bike before starting work?
I hope the car park cctv catches that on camera Shocked !
Would make one hell of a funny you-tube vid.
bugeye_bob
PostPosted: 18:04 - 09 Jul 2019    Post subject: Reply with quote
https://www.ebay.co.uk/itm/LOCKABLE-FINGER-F-OFF-CAR-DUST-VALVE-CAPS-lock-anti-theft-van-bike-tyre-alloy-/281889224494?_trksid=p2385738.m4383.l4275.c10
https://i.ebayimg.com/images/g/CPkAAOSwll1Wz2kW/s-l1600.jpg
You have an answer.
Easy-X
PostPosted: 19:02 - 09 Jul 2019    Post subject: Reply with quote
Go straight to HR and file a harassment claim. Say you can't name names for fear of reprisals... waffle on about the "culture of fear" in the workplace. They love all that shit Twisted Evil
Sister Sledge
PostPosted: 20:13 - 09 Jul 2019    Post subject: Reply with quote
If it's not someone letting it down, I once had a tyre which would slow leak but only if left parked in a certain position. It had a tiny puncture which leaked only when the rubber around the hole was slightly distorted with the machines weight.
CCM 404 DS
Kawasaki Jimbo
PostPosted: 20:21 - 09 Jul 2019    Post subject: Reply with quote
New items have to be suspect unless it was leaking before. I once had a valve stem which would leak only when pushed to one side (it would leak at the base), and I avoid heavy and right-angled valve caps for the same reason. Centrifugal force has an influence.
1198
PostPosted: 21:15 - 09 Jul 2019    Post subject: Reply with quote
So it only ‘leaks’ when parked at work for what, ten hours a day? Doesn’t leak during the other 14? That seems odd...
I’m not sure I’d be looking for a puncture, more like someone I’ve pissed off / someone who thinks they’re funny...
Jewlio Rides Again LLB
PostPosted: 23:07 - 09 Jul 2019    Post subject: Reply with quote
Could be anyone the sanctimonious OP has pissed off, TBH.
Anyone at all.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
steve the grease
PostPosted: 23:24 - 09 Jul 2019    Post subject: Reply with quote
When you leave school they talk about joining the adult world. Sadly the adult world is full of people who behave like children.
kramdra
PostPosted: 02:20 - 10 Jul 2019    Post subject: Reply with quote
Fuuuuuu
I was wrong. It is a slow/fast intermitent leak. Its lost 20 psi in the 4 hours Ive been home. This is good, it means the bastards at work are not currently fucking with my bike, but raises the question Where is the leak. It has a new puncture repair, plus I pulled glass from a deep cut, also I noticed there was no violent pop of the bead, it seated smoothley with no sound, but appears fully seated.
RAYK47
PostPosted: 06:30 - 10 Jul 2019    Post subject: Reply with quote
Time for a new tyre I think. I won't bother trying to find it.
Hong Kong Phooey
PostPosted: 09:26 - 10 Jul 2019    Post subject: Reply with quote
Squirt soapy water everywhere, tyre, valve, valve seat, valve cap off and inside valve, all round the rim where it meets the tyre, inside the rim and hub, even the cast spokes.
Cast wheels can form microscopic cracks anywhere, not just the rim.
Losing that much air should be obvious.
Easy-X
PostPosted: 10:40 - 10 Jul 2019    Post subject: Reply with quote
Take the wheel off and fill a paddling pool...
Bhud
PostPosted: 11:52 - 10 Jul 2019    Post subject: Reply with quote
Every time I've had a problem like that, it's been a rim leak.
DJP
PostPosted: 20:18 - 12 Jul 2019    Post subject: Reply with quote
Just a thought: Check that the valve core is firmly screwed in.
I had this recently - I could hear a tiny hiss after checking the rear tyre pressure. Turned out the valve core had almost unscrewed itself.
A quick turn with a valve tool and all is well again.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
kramdra
PostPosted: 11:47 - 13 Jul 2019    Post subject: Reply with quote
Soapy water did not reveal the leak. Ages ago I bought from Lidl, a small bicycle can of tyre sealant for 2 quid. About the size of a toothpaste tube. I did use it, worked well, holding pressure, tho I note it has added significant back pressure when inflating, makes little air pump work a lot harder. This stuff foams and expands. There was none visible to indicate where the leak came from.
Undecided if I will strip the tire off for inspection, it has 3-5k miles left in it.
Bought a tin of bead sealer, plus some aluminium screw in valves. I will have another look at getting a in wheel TPMS.
PostPosted: 11:58 - 13 Jul 2019    Post subject: Reply with quote
Putting it in water and then using a ratchet strap to force pressure onto the tyre would show it.
The last post was made 6 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 117.92 Kb
