Pegaso 650 backfires into the intake... SOLVED!
RhynoCZ
PostPosted: 19:05 - 14 Jul 2019    Post subject: Pegaso 650 backfires into the intake... SOLVED! Reply with quote
What to look for? Valve clearances adjustment done, electrics sorted, carburetors cleaned and having stock jets and setup, no ''visible'' air leaks as far as I can tell, fresh fuel and spark plug...
I'm clueless. Confused
It starts alright but in just a few seconds after that it starts to backfire into the airbox. Then, the engine stalls. Cold/hot does not matter, the engine does run, roughly, if held in high revs.
Easy-X
PostPosted: 19:24 - 14 Jul 2019    Post subject: Reply with quote
Backfiring into the airbox implies the intake valve was open when the boom came...
Timing or sticky valve?
WD Forte
PostPosted: 19:33 - 14 Jul 2019    Post subject: Reply with quote
I had to google a pegaso 650.........
(you can expect a strongly worded letter in green ink soon)
I assume it's an early twin mikuni version?
Phuctyfino of course but guesses
As backfires are usually caused by lean mixture or pre ignition and it cuts out
The Tarot cards tell me to looK at the fuel taps first to check they give a good steady flow.
If they're just dribbling they'd probably fill the float bowl enough to start but go dry when
asked for more.
this would lean out the mixture and possibly cause backfires and such.
vac taps are notorious for this.
Exhaust header leaks can make it pop back a bit but probably not stop the motor
Dont know what system it uses, but an ignition fault like a component breaking down
as it heats up then causing false triggering might give it conniptions
bikers smell of wee
RhynoCZ
PostPosted: 19:46 - 14 Jul 2019    Post subject: Reply with quote
Yes, Mikuni carburetors. It's an Italian - German (BMW F650GS) - Japanese parts bin mashup.
steve the grease
PostPosted: 21:55 - 14 Jul 2019    Post subject: Reply with quote
The reason it backfires into the inlet is because the combustion process is still taking place when the inlet valve(s) open. So why is that? Either the timing is so retarded that the combustion process is starting so late that it's still burning when the inlet opens, OR the mixture is so far off ( generally weak) that the combustion process takes all day, so that its still burning , blah bla inlet , blah blah. Headers hot are they?
Robby
Dirty Old Man
PostPosted: 21:11 - 15 Jul 2019    Post subject: Reply with quote
Check the timing.
sickpup
Old Timer
PostPosted: 18:34 - 16 Jul 2019    Post subject: Reply with quote
The blanking olug is missing off one of the balancing points. Really it is.
RhynoCZ
PostPosted: 14:10 - 17 Jul 2019    Post subject: Reply with quote
The timing is perfect, and there is no such a thing as balancing points. The mixture is lean, though.
sickpup
Old Timer
PostPosted: 15:48 - 17 Jul 2019    Post subject: Reply with quote
Oh yes there is. The bike is a single but uses a twin barrel carb with balance vacuum take off points in the carb tops or at least the uk models did. Check again.
RhynoCZ
PostPosted: 16:14 - 17 Jul 2019    Post subject: Reply with quote
It's the year 2000, the last gen. with carburetors, and it's just not there. A friend of mine just obtained a ''new'' ECU for the bike, so will try that as well.
If the ECU is faulty and the ignition happens too soon or late, it could also, theoretically, cause the issue.
I mean, it's Italian, so it is expected for the electrics to fail, at some point at least.
sickpup
Old Timer
PostPosted: 12:01 - 18 Jul 2019    Post subject: Reply with quote
you're right its not listed in the parts on the fiche and yet I can see it in the picture on the engine side of the carb. Check under the carb top to see if there should be an o ring to seal and blank off.
ADSrox0r
PostPosted: 19:40 - 18 Jul 2019    Post subject: Reply with quote
Depends, if it's a 95/96 those Mikuni don't have balancing ports. It looks like they do but they're actually blanked off. The UK model also had a stamped in idle jet.
Coincidentally, my old Peg is sat at the back of the workshop with the very same symptoms. I'm almost certain it's carb fuckery but I just don't have time/notion for stripping it and buggering about (again) I also think the sprag clutch is ferked (very common on these) Pfff.
RhynoCZ
PostPosted: 20:03 - 18 Jul 2019    Post subject: Reply with quote
And the ''new'' ECU did not help, back to the drawing board.
EDIT: I googled a bit more and found some people use acetone and compressed air to clean the idle jet in order to fix the issue. Well, all the carb bits were in the ultrasonic cleaner, but I guess it's time to try the acetone and air method now.
ADSrox0r
PostPosted: 07:33 - 19 Jul 2019    Post subject: Reply with quote
You said the carbs are cleaned, are the seals and diaphragm sound?
It's a pain with a stamped in idle jet but you can remove it if you're careful (I haven't as yet, I'm told you can)
Oh and for reference, what are your mix screws set at?
RhynoCZ
PostPosted: 09:02 - 20 Jul 2019    Post subject: Reply with quote
Cleaned and taken apart again for the acetone + compressed air thing. Did not help. It still backfires into the left carburetor. *the left one only Thinking
The diaphragms are like brand new, all the seals as well. However there might be one issue, that wouldn't cause this. Many of the o-rings had to be replaced due to deterioration and the new o-rings, although being up to spec, are a bit thicker, as they are not damaged/compressed yet, so when the manual says give it 3,5 turns, the idle jet might not get into the exact same position as it used to. But that alone would not cause such horrid engine running.
Riejufixing
PostPosted: 09:42 - 20 Jul 2019    Post subject: Reply with quote
Still spitting back? Inlet valve problem (sticky, bent, seat damaged...)?
jaffa90
PostPosted: 10:05 - 20 Jul 2019    Post subject: Reply with quote
Long shot, try a denser air filter (rubber foam) .
RhynoCZ
PostPosted: 10:38 - 20 Jul 2019    Post subject: Reply with quote
The valve clearances are up to spec (checked again) and the crank rotates with no excessive resistance. Maybe, just maybe the intake valve seat on the left hand side is damaged or even the valve itself missing some bits, however the owner refuses to take the head off, at this point. Thinking
@Jaffa: It runs an airbox, doing that would not solve the issue, as it's always the left carburetor, that runs like crap.
jaffa90
PostPosted: 11:11 - 20 Jul 2019    Post subject: Reply with quote
Not to solve it but does it make it a little better or worse.
My brandnew KLV 1000 was spitting back (very weak mixture)at a certain rev range until a power commander was fitted.
Sister Sledge
PostPosted: 11:27 - 20 Jul 2019    Post subject: Reply with quote
Is this bike running one intake valve for one carb and another intake valve for another carb?
If it is then surely a damaged valve is a likely cause?
CCM 404 DS
jimspeed
PostPosted: 19:41 - 20 Jul 2019    Post subject: Reply with quote
I think I would do a compression test followed by a leak down test at this point.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
RhynoCZ
PostPosted: 14:35 - 24 Jul 2019    Post subject: Reply with quote
It's fixed now and it was the pressed in jets! More acetone, more cleaning, runs alright now. What a stupid design. Confused
The last post was made 6 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.06 - MySQL Queries: 13 - Page Size: 115.28 Kb
