A push for E10... anything to be worried about?
Easy-X
PostPosted: 00:47 - 17 Jul 2019    Post subject: A push for E10... anything to be worried about? Reply with quote
https://www.bbc.co.uk/news/science-environment-49003496
E10 as in 90% petrol 10% bio-ethanol.
Is that enough of a change to affect our bikes?
For cars you can fit flex-fuel sensors and run from 0% to 100% ethanol and anything in between. I assume you could do the same for an EFI bike?
UnknownStuntm...
PostPosted: 06:59 - 17 Jul 2019    Post subject: Reply with quote
Will changing the fuel affect bikes? Of course it will, but perhaps not in the boxes you're thinking. imho higher ethanol content rots tanks, hoses and tubes not specifically designed for it. So older bikes will need more fettling when this goes ahead. You can put additives in to combat the effects, or put fuel in with no specific ethanol content.
ThunderGuts
PostPosted: 07:13 - 17 Jul 2019    Post subject: Reply with quote
I suspect this side of it will mean they'll continue to be availability of 5% ethanol fuel for quite a while alongside the 10% ethanol fuel, a bit like 4 star ran alongside unleaded for ages before eventually becoming LRP, and even that was around for a good while. I suspect the only bikes around by that point that will be sensitive to 10% ethanol fuel will probably be cherished bikes and the owners likely to have made any such changes themselves
TG.
Alex A
PostPosted: 07:39 - 17 Jul 2019    Post subject: Reply with quote
Yes: https://www.deformedfueltanks.com
PostPosted: 08:22 - 17 Jul 2019    Post subject: Reply with quote
Add water, syphon off the good stuff.
redeem ouzzer
PostPosted: 10:45 - 17 Jul 2019    Post subject: Reply with quote
It’s the equivalent of running a bike on piss.
Be a REAL MAN!
doggone
PostPosted: 11:24 - 17 Jul 2019    Post subject: Reply with quote
Since a lot of other countries use 10% or higher it can't be causing major problems, I'd be most worried about reduced fuel stability in bikes barely used through winter, I think ethanol is more hygroscopic for a start.
Bhud
PostPosted: 12:05 - 17 Jul 2019    Post subject: Reply with quote
There is also significantly less energy per cc in ethanol than there is in petrol, so where this E10 is posited in the market is going to be critical. It's got to be the cheapest/bargain basement option, or else nobody would buy it.
I expect the market for petrol to diverge from the mass market bulk model into various specialist products. I don't envisage sports/classic car people opting for the cheapest option at the pumps, but other types of customer, such as the polished German banger lot, the school-run prams, econo-boxes, etc. will probably just decrease their use of the car while continuing to buy the cheapest option at the pumps (or the only option at Asda, etc.) This means a diminishing market as these types slowly drift towards electric if they can afford it. All of which means that the prognosis for E10 in the fuel market is questionable. Regardless of laws and regulations, you will always be able to buy Aspen/Murco ethanol-free petrol - it will just cost more and will be a specialty product.
EDIT: to add a couple more thoughts regarding the destructive effects... It seems that fuel lines may degrade and dissolve with ethanol, which can cause problems in fuel systems (especially with bits of rubber in carbs). People have found bits of modern rubber fuel line in their carbs, blocking up jets and passages. However, the jury is out on that one. One thing I know for sure, and you don't need to be a chemist to figure this one out: ethanol is a substance that evaporates. This means modern petrol shouldn't (in theory) leave varnish residue in the fuel system, but on the other hand, water and associated problems (e.g. rust from fuel tanks) can cause problems in fuel systems. There may therefore be a solution to this problem by means of an additive that's water-absorbing and which dissolves in petrol...
PostPosted: 18:33 - 17 Jul 2019    Post subject: Reply with quote
It's not good in an early 90's sportsbike. it can destroy the fuel lines and lead to a catastrophic vehicle fire among other things.
I'm just back from Europe and we had to leave a couple of fuel stations because all they had was E10. EVERYTHING else was E5 but at least it was labelled as such unlike in the UK where you literally take a chance on it.
In quite a lot of fuel stations, all the 95 octane fuel was E10. The 98 (super) was E5.
I'll be taking a bottle of additive next time I go to Europe. Bunged a load of V-power through it as soon as I got home.
If they do use E10, it needs to be clearly labelled because it can be dangerous in some vehicles. Anything made ofter 2000 should be ok with it.
Alex A
PostPosted: 19:08 - 17 Jul 2019    Post subject: Reply with quote
It caused a fuel leak in a 2011 Ducati I owned, and could with many bikes (5+ years old) fitted with plastic tanks. So no it isn't OK.
Sister Sledge
PostPosted: 19:12 - 17 Jul 2019    Post subject: Reply with quote
Not too sure with mine but things such as fuel lines I can work ahead of the change. My main issue is my plastic fuel tank. I'm unsure just what type of plastic it is.
CCM 404 DS
PostPosted: 19:19 - 17 Jul 2019    Post subject: Reply with quote
Fair do's. Looks like both newer Ducatis and Kawasaki have issues.
https://www.acem.eu/component/content/article/2-non-categorise/33-e10
I'll quote it here because the site seems to be down.
BMW Motorrad
All models are compatible with E10. However the number of octanes needs to be compatible with the model according to user handbook.
BRP
All models belonging to the L-category are E10 compatible.
Ducati
Ducati Desmosedici 990 RR, Vehicles registered as from 18/05/2007
Ducati Diavel 1198, Vehicles registered as from 27/10/2010
Ducati Diavel 1198 ABS, Vehicles registered as from 27/10/2010
Ducati Diavel 1198 Diavel Carbon, Vehicles registered as from 27/10/2010
Ducati Diavel 1198 Diavel Carbon ABS, Vehicles registered as from 27/10/2010
Ducati Hypermotard 1100, Vehicles registered as from 15/02/2007
Ducati Hypermotard 1100 evo, Vehicles registered as from 02/07/2009
Ducati Hypermotard 1100 evo SP, Vehicles registered as from 29/09/2009
Ducati Hypermotard 1100 S, Vehicles registered as from 15/02/2007
Ducati Hypermotard 1100 S+, Vehicles registered as from 02/07/2009
Ducati Hypermotard 1100+, Vehicles registered as from 02/07/2009
Ducati Hypermotard 796, Vehicles registered as from 02/07/2009
Ducati Monster 1100, Vehicles registered as from 10/07/2008
Ducati Monster 1100 ABS, Vehicles registered as from 14/10/2009
Ducati Monster 1100 evo ABS
Ducati Monster 1100 S, Vehicles registered as from 10/07/2008
Ducati Monster 1100 S ABS, Vehicles registered as from 14/10/2009
Ducati Monster 659
Ducati Monster 659 ABS
Ducati Monster 696, Vehicles registered as from 15/01/2008
Ducati Monster 696 ABS, Vehicles registered as from 14/10/2009
Ducati Monster 796, Vehicles registered as from 04/02/2010
Ducati Monster 796 ABS, Vehicles registered as from 04/02/2010
Ducati Multistrada 1200 , Vehicles registered as from 04/12/2009
Ducati Multistrada 1200 ABS , Vehicles registered as from 04/12/2009
Ducati Multistrada 1200 S Pikes Peak Special Edition
Ducati Multistrada 1200 S Sport , Vehicles registered as from 04/12/2009
Ducati Multistrada 1200 S Touring , Vehicles registered as from 04/12/2009
Ducati Streetfighter 1098 , Vehicles registered as from 12/01/2009
Ducati Streetfighter 1098 S , Vehicles registered as from 12/01/2009
Ducati Superbike 1098 R Corse , Vehicles registered as from 30/10/2007
Ducati Superbike 1198 , Vehicles registered as from 03/09/2008
Ducati Superbike 1198 SP , Vehicles registered as from 03/09/2008
Ducati Superbike 848 evo , Vehicles registered as from 20/05/2010
The above list related to Ducati vehicles was extracted from official documents published by the Italian Environment Ministry which can be downloaded her
Harley Davidson
All Harley-Davidson models from Model Year 1980 are compatible with E10 fuel.
All models before this model year should use RON 98 fuel.
Honda
All Honda motorcycles and mopeds produced for the EU market since 1993 can use ethanol-blended gasoline up to 10% although carburettor-equipped models could experience poor driveability in cold weather conditions.
Kawasaki
E10 fuel compatible Kawasaki motorcycle models:
Kawasaki model - Model year (and onwards)
KLX125 - 2010
D-Tracker 125 - 2010
KLX250 - 2008
Ninja 250R - 2008
Ninja ZX-6R - 2007
ER-6n - 2006
ER-6f - 2006
Versys - 2007
Z750 - 2007
W800 - 2011
VN900 - 2006
Z1000 - 2009
Z1000SX - 2011
Ninja ZX-10R 2006
ZZR1400 - 2006
1400GTR - 2008
VN1700 - 2009
VN2000 - 2008
KTM
KTM motorcycles and ATVs are compatible with E10 from model year 2000 onwards.
Peugeot Scooters
All Peugeot Scooters from model year 2000 are E10 compatible.
Piaggio
Most models over 50cc belonging to the Piaggio Group are compatible with E10 from 1.1.2011 onwards. Piaggio does not recommend use of E10 on Mopeds (i.e. 50cc) currently in production. A full list of E10 compatible Piaggio models will be published soon on https://www.dsa.minambiente.it/DirettivaCarburanti (in Italian).
Victory Motorcycles
All Victory motorcycles can use gasoline that has been blended with up to 10% ethanol (E10). Check fuel’s octane rating for compatibility with the vehicle according to the owner’s manual.
Suzuki
2002 Model Years and onwards - all motorcycles can use E10 with no problems.
1992-2001 Model Years – some models can use E10 fuels and some models cannot. The user should contact his national importer for clarification.
1991 Model Years and earlier – RON 98 (no bio-fuel content) must be used.
Triumph
All models, starting from Model Year 1990, are compatible with E10.
Yamaha
All Yamaha models from Model Year 1990 are compatible with E10.
Alex A
PostPosted: 19:26 - 17 Jul 2019    Post subject: Reply with quote
Alex A wrote:
As per link above, it's more than Ducati:
"The issue is not specific to Ducati, and has been reported on the web with motorcycles from other manufacturers including Aprillia, Triumph, KTM, MZ, Moto Guzzi, and Bimota.
The tanks that are affected by this problem are reportedly made of PA6 polyamide plastic and were manufactured from 2005 to 2010. At least some of the tanks were outsourced by the manufacturers and were made by Acerbis."
The last post was made 6 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 84.92 Kb
