| 8nisd10a |
 8nisd10a L Plate Warrior
| jaffa90 |
 jaffa90 World Chat Champion
| 8nisd10a |
| jaffa90 |
| BusterGonads |
 BusterGonads Trackday Trickster
| 8nisd10a |
| 8nisd10a |
| Robby |
 Robby Dirty Old Man
 Posted: 20:26 - 15 Jul 2019 Post subject: |
Well it sounds like this was your first rebuild, and you don't know what you're doing, so it could be lots of things.
Its running, but not making power. You didn't mention what the compression was after the piston replacement, or if you honed or replaced the barrel.
So, things I would be suspicious of:
1. Air leaks, inlet side.
2. Head gasket not sealing - gasket surface wasn't clean enough, head not torqued down, re-used gasket, knackered mating surface.
3. Head damage - bent valve, bent/broken valve guide, valve seat problem.
4. Fuelling - carb filthy, full of water, generally blocked.
That's without thinking about the bottom end. You didn't mention what you did to stop the knock, like getting a recon crank. |
| 8nisd10a |
| Nobby the Bastard |
| 8nisd10a |
| Robby |
 Robby Dirty Old Man
The last post was made 6 years, 216 days ago. Instead of replying here, would creating a new thread be more useful? |
