Zzr1100 d4, bogging down under load
dextersaurus
PostPosted: 16:44 - 17 Jul 2019    Post subject: Zzr1100 d4, bogging down under load Reply with quote
Hello BCF
It's been a while.
I got a zzr1100 as part of a swap last year, was alright then had issues with electrics. It never ran quite right, always hesitating and a bit smoky due to a few oil leaks.
Anyway, took it off the road and stripped it, replaced the wiring loom, valve cover gasket, spark plug gaskets and various other bits and bobs. Had the carbs off and cleaned them up, set float heights, balanced and sorted out the weird and wonderful mixture screws as they were all over the place.
Now, I can't get it running right.
It idles absolutely spot on, and revs well sitting still, but as soon as I take it out on the road and open it up it hesitates and dies, then goes like jobbies off a shovel, then bogs down again etc etc. Like it's getting no fuel and/or too much air.
I've checked the diaphragms and theyre all fine, slides all move at the same time. I've checked for air leaks, can't find anything. I've checked voltage going to the fuel pump, showing a healthy 12v when running, and I've had the carbs apart again to clean the jets just in case I missed something
No improvement.
My next steps are to replace the plugs and HT leads and if that doesn't work, bypass the fuel pump to see if that's what's causing the issue.
Any other suggestions? At my wit's end - great bike when it's going but getting it going seems to be a major issue Rolling Eyes
Tracey Suntan-King
PostPosted: 17:07 - 17 Jul 2019    Post subject: Reply with quote
Have you got any trousers on?
dextersaurus
PostPosted: 21:21 - 17 Jul 2019    Post subject: Reply with quote
I didn't, but I put some jeans on and tried again and no difference
dextersaurus
PostPosted: 12:22 - 19 Jul 2019    Post subject: Reply with quote
I'm getting closer and closer to setting this bike on fire.
This place used to be great for help Laughing
Easy-X
PostPosted: 13:15 - 19 Jul 2019    Post subject: Re: Zzr1100 d4, bogging down under load Reply with quote
Sounds like it's running lean... fuel supply issue Smile
RhynoCZ
PostPosted: 13:49 - 19 Jul 2019    Post subject: Reply with quote
Does it have ram air intake? Does the ''enrichment'' system work?
Bhud
PostPosted: 14:01 - 19 Jul 2019    Post subject: Re: Zzr1100 d4, bogging down under load Reply with quote
The bike runs better when it gets hot. Is that correct?
DJP
PostPosted: 20:49 - 19 Jul 2019    Post subject: Reply with quote
Blocked fuel tank vent?
Blocked fuel filter?
Internally collapsed fuel line?
I had similar symptoms once from a blocked fuel filter: Sufficient fuel got through to let it idle and give a few seconds of full throttle and then it would run out again. As the fuel flow increased the crap would get sucked up and block the filter.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
dextersaurus
PostPosted: 09:34 - 03 Aug 2019    Post subject: Reply with quote
That was my thought...
It does have ram air. The bit you're on about, is that the additional hoses that go straight into the carbs to up the pressure in the bowls at speed?
Nope, makes no difference.
No hissing when I open it, so don't think it's the breather. I've replaced the fuel filter so it can't be blocked. Fuel line maybe... Gonna buy a length of hose and replace it all, and see if it makes any difference.
I'm still thinking it's the fuel pump - once I get the extra hose through I'm gonna bypass it altogether and just hook it up as a gravity feed, see if it makes any difference.
Unfortunately I've broken my knee so the bike is gonna have to wait til I can walk again Rolling Eyes
mentalboy
PostPosted: 12:26 - 03 Aug 2019    Post subject: Reply with quote
What state was the old fuel filter? Unless you flushed the tank before fitting the new filter, there is a chance that the new one is already clagged.
Could be a line issue, mine melted because they weren't resistant to Ethanol and I had to replace all of them.
Bad luck about the knee! GWS.
Make mine a Corona.
dextersaurus
PostPosted: 10:42 - 04 Aug 2019    Post subject: Reply with quote
The old filter was fine to be honest, but replaced it just to be sure. Haven't flushed the tank but the petrol was new and there wasn't anything visible in the old filter. I don't think that's the issue.
It's all the standard fuel lines so I doubt that'd happen, but I do want to replace just to bypass the fuel pump.
If it's none of these, its beginning to look like it's the fuel pump. Thinking about it I might have forgotten to unplug the fuel pump when running the float bowls dry Thinking
Fizzer Thou
PostPosted: 14:33 - 04 Aug 2019    Post subject: Reply with quote
It sounds more like there is excessive air getting into the inlet because of the 'O' rings that seal the inlet manifold to the cylinder head.I have experienced this many times now.
One of the easiest ways to test is with the engine running,spray some WD40 around the inlets.When the engine revs change then you know where the air leak is Thumbs Up Wink
Not expensive either (joke....).Part number 92055
https://www.fowlersparts.co.uk/parts/3335264/zx1100-d5-1997-candy-amaranth-red-mica-gb/cylinder-head
Always have a 'Plan B'
mentalboy
PostPosted: 14:38 - 04 Aug 2019    Post subject: Reply with quote
Mine had standard fuel lines as well, but as a '94 D2 it was slightly older than yours. I would have expected your lines to have rotted out a few years back if they were the same type as mine, Kwak will have upgraded their lines but I'm not sure when ethanol resistant ones would have become standard.
Easy to spot though, just pull any one end off a fitting and it will leave a messy black residue, ethanol melts them.
Plugging up the pump will do it! Doh! Laughing
Make mine a Corona.
Grubscrew
PostPosted: 15:40 - 04 Aug 2019    Post subject: Reply with quote
I read your post with interest. I had a D4 with exactly the same issues, never did find out the problem.
I did all the usual bits, fuel cut off relay, pilot screw clean, valve gaps, plugs carbs flippin everything, still never ran correctly , same as yours......it seemed like a fuel/ air issue.......I even purchased a bank of vacuum gauges to try to balance the carbs. bastard bike...sold it on. However, chatting to a chap a few months ago and he’s suggested I should have looked elsewhere, ie the generator area/ stator etc, obviously by which time I sold it, but maybe that’s the place to look. Just a thought.
Frustrating it sure is.
FJR1300/CBR1000F
dextersaurus
PostPosted: 16:43 - 04 Aug 2019    Post subject: Reply with quote
I've tried spraying around the intake and carbs as this was my first thought, but did absolutely nothing at all. Ill change them anyway and see what difference it makes. Judging by the state of the rest of the gaskets, wouldn't surprise me if this was the issue!
I'll replace all the lines and see if that makes any difference.
So electrics is an interesting one - the whole reason I took it off the road in the first place was because the wiring loom had been hacked up and "repaired" so I put a new loom on it. I've measured voltage when running to make sure it's charging, and it's pretty much spot on. Tested voltage to fuel pump and various switches as well, all looks good.
Driving me insane. I can't walk right now so I'm gonna start buying bits and get them all fitted when I'm up and about again.
mentalboy
PostPosted: 23:55 - 04 Aug 2019    Post subject: Reply with quote
A set of decent gauges is a must have item for any Zed owner, Kwak carbs are notorious for throwing themselves out of balance on a regular basis. I used to try check the 1100 every 3000 miles.
Make mine a Corona.
Tarmacsurfer
PostPosted: 16:54 - 05 Aug 2019    Post subject: Reply with quote
I run an 1100C, had a similar issue a few years back and it turned out to be a coil shorting under load.
I've since switched out to coil packs from a ZX9R, much tidier (not that you'll be looking under there much) and engine feels somewhat more responsive. Given I was running old leads on OEM coils that's easily explained.
I'm immortal. Well, so far.
There is a gap of 247 days between these two posts...
dextersaurus
PostPosted: 10:38 - 09 Apr 2020    Post subject: Reply with quote
WELL THEN
Had an interesting discovery this week whilst playing about with the bike trying to get it started.
It wouldn't fire, so I took the tank off and as I placed it down I realised the tap was still on reserve.... But no fuel was coming out. It's not a vacuum operated tap, so there's clearly an issue there.
The tap was definitely working before, but it appears to have blocked right up.
I took the tap off altogether and plumbed a line from one of the other nipples on the bottom of the tank (with a filter) and it started right up.
I'm thinking that this bloody fuel tap has been blocked all along and thats been the cause of all of my headaches!
sickpup
Old Timer
PostPosted: 11:24 - 09 Apr 2020    Post subject: Reply with quote
It could be the problem but I doubt it. I would think it's a problem.
I don't think it is the main problem as the fuel required to run the bike under idle as well as running conditions would be from the float bowl not direct from the tap. As long as the float bowls had fuel in them it wouldn't be the tap.
I would be looking in the direction of compression as well as the pilot screws. The screws wear so the bottom end fueling drifts out.
If the hesitation is around 4000rom and it still has its original pipe it could just be the the flat spot where emissions were tested. If it has an after market pipe has it been re-jetted?
It could also as has been said be a coil, they tend to stutter at lower revs rather than higher when failing.
It definitely isn't the ram-air system.
dextersaurus
PostPosted: 23:14 - 09 Aug 2020    Post subject: Reply with quote
So I no longer own this bike but did manage to fix if for the new owner. Turns out there was a blockage inside the tank where the fuel goes from the bottom of the tank up to the fuel tap. That was blown out with some compressed air and the fuel started pissing through.
So yeah, a blockage all along! It now runs perfectly and pulls well, powerband in every gear and so on and so forth 😂
jaffa90
PostPosted: 00:23 - 10 Aug 2020    Post subject: Reply with quote
Full marks to Easy-X then.
The last post was made 6 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 120.49 Kb
