Brake bleeding issue Zontes Firefly 125cc 😤&
Garymcc1
PostPosted: 17:54 - 20 Jul 2019    Post subject: Brake bleeding issue Zontes Firefly 125cc 😤& Reply with quote
Hi all, New to the forum and in need of help. My brother in law has one of these Chinese Zontes Fireflys. He had an off a few weeks back and I've since replaced the damaged parts but the rear brake won't hold pressure.
I've pumped fluid through it to no avail. I ordered a rear caliper and piston and the fault is still present. I've notice the servo piston runs a hose to the rear And front caliper for some reason. The front brake is 100% working but it has 2 bleed nipples one for the front and I assume 1 for the servo??
My question is how the hell do. You bleed these brakes I've never had an issue working on any bike I've owned but this little thing is baffling me and I just want it gone and back to him now. 😂 PLEASE SOMEONE help me.
RhynoCZ
PostPosted: 18:12 - 20 Jul 2019    Post subject: Reply with quote
Is this it?
https://images.medialinksonline.com/imagestream/268450/1934904x1200x800_FFFFFF_E.jpg
If so, it appears the front and rear brakes are joined, not uncommon (Honda used this on various bikes, DCBS), a bit unusual on such low budget 125cc bike though. It could also be the ABS system, but I can't see any ABS ring on the front wheel.
Read here: https://moto.lexp.net/wiki/Bleeding_the_Brakes_%28Dual_Combined_Brake_System_%28DCBS%29%29_on_Honda_CBR1100XX_Super_Blackbird
Garymcc1
PostPosted: 18:14 - 20 Jul 2019    Post subject: Reply with quote
Yes that's the one it's a 2017 model no Abs on them. How would I go about bleeding that type of system? Thanks so. Uch for getting back to me.
RhynoCZ
PostPosted: 18:16 - 20 Jul 2019    Post subject: Reply with quote
There's no other imaginable reason why would they join the brakes, other than a dual combined brake system.
Garymcc1
PostPosted: 18:23 - 20 Jul 2019    Post subject: Reply with quote
Sorry I totally missed the link. Lol. I'll give it a go and hope it does the trick. Failing that I may have to give up or face going insane...... More so.
RhynoCZ
PostPosted: 18:29 - 20 Jul 2019    Post subject: Reply with quote
No need to be sorry.
If your model does not have such dual combined system, then you have air in the system, bleed it again. If it still doesn't hold ''pressure'' then it must be leaking, check for any moisture.
Could you make a picture of the rear caliper? Maybe the bleeding point is in not the ideal place (not on the top of the caliper), which is common, in which case reverse bleeding is advisable.
Garymcc1
PostPosted: 19:13 - 20 Jul 2019    Post subject: Reply with quote
I'll get some. Pics up ASAP.
Skudd
PostPosted: 20:03 - 20 Jul 2019    Post subject: Reply with quote
If they are linked you will have a pressure valve at the front that actuates when the front brake is used and pushes the piston in the unit. This then pushes a piston on the rear. You will need to push this back and forth to bleed the rear. My Varadero 1000 had linked brakes and there was a sequence to bleeding them, not a one man job either.
It was a pain in the arse, but once done brilliant.
Easy-X
PostPosted: 20:49 - 20 Jul 2019    Post subject: Reply with quote
I've got CBS on the Superlight. I expect the Chinese thought "ABS sounds expensive, CBS sounds almost as good and it don't cost feck all!"
The last post was made 6 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 60.42 Kb
