1978 Suzuki gs550E Carburetor Help
ccorron2
PostPosted: 01:06 - 22 Jul 2019    Post subject: 1978 Suzuki gs550E Carburetor Help Reply with quote
Im hoping you can help me out. I've got a '78 gs550E and since I bought the bike it has had a misfire on cylinder three. I figured I might as well go through the carbs to get an idea of what shape they're in. So far everything looks good in them except for what I believe is the fuel adjustment screw that can be adjusted in the front of the float bowl. Two of these screw are pointed and I have two that seem to be dull or snapped off. I will attach a picture for you to see. I am having trouble locating this screw anywhere and was hoping someone could guide me in the right direction. Every website that has the carb diagram does not list nor show this screw.
Cam
jaffa90
PostPosted: 01:22 - 22 Jul 2019    Post subject: Reply with quote
Are you talking these screws?
https://www.ebay.co.uk/itm/323538077169
Usually with a coil spring.
ccorron2
PostPosted: 01:50 - 22 Jul 2019    Post subject: Reply with quote
Thanks for the quick reply! Those do in fact look like what i'm trying to find. Of course they are out of country and $60 lol. There are Carb rebuild kits on ebay for $16 a piece if you buy four and they are pictured but in the description they are not listed. Currently waiting to hear back from two different sellers to see if they are included in the kits.
Cam
PostPosted: 06:31 - 22 Jul 2019    Post subject: Reply with quote
Those are the idle mixture screws. I once had a fazer which had all four snapped off. Some goon has screwed them down hard and wedged the tips in the tiny drill hole, then backed them out leaving the tips broken and blocking the hole. Thankfully they poked through enough to tap them back loose so they would drop out.
Make sure you can see daylight through the holes on the broken ones. Also, don't use copaslip on them when you fit them if you ever expect to get them out again. Normal grease is fine.
A100man
PostPosted: 12:15 - 22 Jul 2019    Post subject: Reply with quote
Pete. wrote:
Some goon has screwed them down hard and wedged the tips in the tiny drill hole, then backed them out leaving the tips broken and blocking the hole. ..
I was that goon - on my XJ550/598 I forgot the spring when reassembling one of the carbs, as a consequence the needle was able to be screwed right down into its recess and sure enough the tip broke off on removal.. but without enough to poke through - ended up abandoning that carb as I would have needed a sub 1mm drill bit to remove it.
You might do better just to find a spare rack of carbs for the bits you need.
The last post was made 6 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 3.49 - MySQL Queries: 13 - Page Size: 44.35 Kb
