Full suspension removal (GSXR750 k5)
t121anf
PostPosted: 11:40 - 23 Jul 2019    Post subject: Full suspension removal (GSXR750 k5) Reply with quote
Hi,
I wish to remove my forks and rear shock to have them serviced, I've removed the forks before however I've never done the rear shock.
I have an AbbaStand with front front lift kit i.e.
https://abbastands.co.uk/images/products/display/abba-front-lift-arm-01.jpg
This allows me to get both front and rear wheels off the ground, is this suitable to use to remove the rear shock?
I'll be doing it in my garage so I could hang it from the rafters if it's really required.
Thanks
Easy-X
PostPosted: 12:41 - 23 Jul 2019    Post subject: Reply with quote
Just bear in mind a swing arm goes both up and down Smile Down mostly if you take off the shock(s)!
1198
PostPosted: 13:02 - 23 Jul 2019    Post subject: Reply with quote
Does your stand have the rear swinging arm resting on it? It appears to from the picture?
t121anf
PostPosted: 14:22 - 23 Jul 2019    Post subject: Reply with quote
Abba stand is connected to the swing arm pivot and the strap at the back which is used to lift the front is attached to a bobbin (used for paddock stands.)
Does that affect the situation?
The forks are my main priority, but I would prefer to get the whole lot done at once.
PostPosted: 14:41 - 23 Jul 2019    Post subject: Reply with quote
The front lift arm pulls the swing arm down, therefore if you remove the rear shock then the lift arm will no longer be holding the front wheel in the air.
Right? Laughing
t121anf
PostPosted: 16:10 - 23 Jul 2019    Post subject: Reply with quote
Makes sense, I'll have to hang it from the roof then.
1198
PostPosted: 19:51 - 24 Jul 2019    Post subject: Reply with quote
So it’s pulling the swing arm down? It should be possible to remove the shock at the back then but you’ll have no way to wiggle it to get it to line up when refitting it?
The last post was made 6 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.82 - MySQL Queries: 13 - Page Size: 51.13 Kb
