| stupot |
 stupot L Plate Warrior
| jaffa90 |
 jaffa90 World Chat Champion
| stupot |
| jaffa90 |
| stinkwheel |
 Posted: 21:51 - 26 Jul 2019 Post subject: |
There is a high chance the needle valves are badly corroded and are sticking in their seats due to ethanol corrosion. Seen it on other EX500 derived bikes. The solution is to replace them with modern, viton tipped ones which are ethanol proof.
Check your airbox isn't full of fuel, the last one I saw was and there was convincing meltiness suggesting it had been on fire with me riding it. Presumably put itself out again.
Do not fiddle with the fuel air screw. I 100% garauntee this is not your problem unless someone else has moved them. And I'd suspect on a '99 bike that's been sitting for a while, that would be too much like hard work, the heads of them probnably shear/burr the instant you tried to move them.
EDIT: also check the main power connection from the main fuse. It's a big fat, (usually white) wire running from the 30A fuse holder to the ignition switch. It's located on top of the starter solenoid. Follow the big fat wire from the battery positive to find the starter solenoid. On top of it is a red cap covering the 30A fuse with wires coming out of it. Take the top off, inspect the fuse and terminals for green powdery corrosion and wiggle the wires going into it. Do not be surprised if one comes off in your hand. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stupot |
| stinkwheel |
| sickpup |
 sickpup Old Timer
| stupot |
| stinkwheel |
 Posted: 21:01 - 30 Jul 2019 Post subject: |
Was the master cylinder rebuilt too or just the calliper seals?
If it's losing pressure without moving, there is a leak. If fluid isn't coming out, it's leaking back into the master cylinder.
If you're having to pump the lever after having moved the bike, it's more likely you have a warped rotor.
Out of interest, what was the air filter blocked with? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 6 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
